Question about Kenmore 63942 Dryer
My inglis dryer model YIED7200TW (not even listed on the their models) is not heating but running with just cool air.
Not sure where the element is located and how we can access it as the panel of the dryer is attached to the whole body of the dryer. this was bought in 2008 model YIED7200TW. is this model obsolete or not fixable anymore? If that will be the case, I won't be buying this brand anymore or any brand under whirlpool company. this is so frustrating to fix. thanks.
dididsaythat
  • 291 Answers
SOURCE: Inglis Dryer
You really need a volt / ohm meter to check for Continuity & Volts
Its well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
Posted on Oct 14, 2007
SOURCE: I NEED OWNERS MANUAL TO KENMORE DRYER
goto sears.com and under parts type the model# hit enter. Then type manual and it will cost you $2.30.
Posted on Oct 16, 2007
aborcass
  • 2651 Answers
thiknin you need a service guide , not owners manual( only tell how to operate} ther is a schematic/ wiring diagram locate with inthe console itself usually taped to the back wall behind the timer
Posted on Apr 03, 2008
TheMobilian
  • 8220 Answers
SOURCE: kenmore dryer model #86870100 runs but no heat
this kit mounts on the heater element chamber. The small one will be open. The big one failed also because it is rated to shut down @250°F. The little guy is rated at 300°F. NOTE: when this limit fails it is a sure sign of a blockage of lint somewhere.8e8a912.jpg
Posted on Dec 15, 2008
aasc
  • 1606 Answers
SOURCE: Kenmore Model 110.96585200 No heat!
You probably have a bad thermal cut-off . This is the small thermostat , located at the top of the element housing . This " thermostat " should read infinate resistance ( no resistance ) . You can put the 2 wires togather , and see if heat comes on . pt # 3399848 . Both thermostats , should read 0 resistance . They are normally closed . The thermal cut-off , will not reset itself , if open . This is a safety t-stat , for when dryer gets too hot , and will have to be replaced .
Posted on Nov 11, 2009
Testimonial: "Great advice "
My maytag centennial dryer dryer wont heat up what could be the problem
model number should be listed,Gas or electric? sounds like your thermal fuse has popped or element is broken and needs to be replaced a continuity check can be performed on both
Feb 18, 2015 | Maytag Dryers
My Inglis dryer is overheating. How do I troubleshoot this problem? Thanks...
did you remove the metal duct to the left of the t-stat and thermal fuse?usually this gets filled with lint and will take out either the thermal fuse or the high limit,pull it off and clean it,also if the vent line is long,you can stick a leaf blower into the end of it and blow it out.most problems i find in dryers is from lint buildup.
Dec 06, 2011 | Whirlpool Inglis IP8200 Dryer
How do I remove the heating element from an inglis dryer #yied7200tw
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Feb 22, 2011 | Whirlpool Inglis IP8200 Dryer
Dryer is not heating up electric dryer vent is clean and lint trap is clean no heat at all just cool air
First make sure the heat setting is set for heat. If you dryer is connected to a fuse panel, Check to make sure that BOTH 30 amp fuses are good. If both fuses are good (check with a multi meter not just visual) you will have to check the electrical circuite for the heating system. I'm not really sure what make or model you have so if its a Inglis,Roper,Kenmore or Whirlpool you will have to remove the rear panel and first visually check all the wires to make sure non are burnt off, If wireing looks ok check the resistance of the element and all the thermostats to make sure the complete the curcuite. On some models there is a thermal fuse (white plastic with 2 wires going to it) attached to the heating box, make sure the circuite through the thermal fuse is closed. If everything checks out ok you may have to take the panel off behind the timer and selector switch and inspect the wireing there. If you check the wireing diagram you can see what switched are sopose to close when you select different temperatures and check the switches in the timer and selector switch.
If you check everything on the wireing diagram you will be sure to locate where the problem exists.
Jan 09, 2010 | Dryers
INGLIS DRYER MODEL IP82000 RUNNING BUT NO HEAT.
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.(((((Most common issue)))))
Aug 04, 2009 | Whirlpool Inglis IP8200 Dryer
My dryer is not producing heat. Just cool air!
2. Heating element
3. Thermal fuse
Jul 17, 2009 | Dryers
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Inglis Dryer
Oct 13, 2007 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
915 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
