Question about AEG B1180-4 Electric Single Oven
Diplomat ADP3702 cooling fan problem
The cooling fan on my Diplomat ADP3702 oven is not working. The ouput from the control pcb is ok - but no power is present on the terminals of the fan. One of the connections to the fan is a blue wire connectiong through a white rectangular ceramic component - any ideas what this is? Could this be the fault?
  • AEG Master
  • 3,463 Answers
It could be a fuse or thermal cut out, you can test it with a meter. you should have continuity through it, if not then it is faulty.
If you do not have access to meter, then if take a piece of wire and connect it to the fan terminal and connect the other end to the origin of the ceramic fuse or what ever it is, and it should work, you are in effect bypassing the part in question.
If it still does not work then you are going to have to investigate further, or call some one in.
Plz rate my solution.
Thanks.
Posted on Jan 05, 2009
C302U Double Oven cooling fans shut off immediately after finishing bake cycle. Replaced control board, still does the same. What controls the cooling fans to protect the circuitry?
Newer versions of the control board software will run the cooling fans for a bit after the cycle ends, but many older models work like yours does
Aug 30, 2016 | Thermador C302U Electric Double Oven
New World G90m grill turns off - overheating?
Its a good chance its the thermal control board to the fan (PCB),if faulty it doesnt allow fan to reach correct speed thus overheating.
Hope this helps
Feb 05, 2012 | New World G90m Gas Double Oven
Maytag gas range, model MGS5770ADW,serial 34735247GG. Cooling fan comes on when temperature is set. Continues to run after cancel. Replaced control panel and igniator. Fan is still running.
I have run into this and I would bet you have a bad oven sensor.Im sure this model only has one pcb. so there is no fan board.try the oven sensor.
Mar 10, 2010 | Maytag Ovens
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
The fan has stopped working but if I connect it direct to the mains it runs OK 900gdo
After seeing that the fan was OK I replaced the PCB that controls the fan and this fixed the problem.
Before the fan stopped completely I had noticed that it sounded slow.
I got the part from espares but they took forever to deliver it (10 days).
Oct 17, 2009 | Stoves Ovens
Stoves 720ef fan oven cuts out after a while, then cools down and restarts......help
There are thermal cutouts for both ovens. When the fan oven cuts out, does the thermostat display and the oven lamps go out as well or do they stay on? Is the oven cooling fan working ok, i.e. does it run for about 10 mins after you turn all the controls off? Do you think the oven thermostat is working ok and not running too hot? If it is, Lakeland do an oven thermometer for about 5 pounds that you can check the thermostats with.
Apr 22, 2009 | Stoves 720EF Electric Double Oven
The inner glass panel on my diplomat oven has shattered. What can I do?
My Diplomat Oven Heating element (ELEHY6075) stopped working with the FAN ON combination. I replaced it with a new one and it still does not work with the FAN option. All other combinations do work. What can I do?
Mar 07, 2009 | Ovens
Main cooling fan switches on and off rapidly
hi there,
could i get the exact model # for your stove please?
Sep 14, 2008 | Tecnik Ovens
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
AEG B1180-4 Electric Single Oven Logo
307 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
