Question about Bosch Exxcel KGV35421 Bottom Freezer Refrigerator
My bosch fridge freezer temp gauge keeps flashing -22
namzyanzy
  • 435 Answers
SOURCE: Bosch Classixx Fridge freezer KGU30604 I
Hi Kloynes,
It could be a problem of LEAKAGE.....Followings steps may help you tackle the problem:
Steps
  1. Check the hose under your fridge that drains condensation and such into a catch tray. Make sure the hose is draining properly.
  2. Blow air through the tube to make sure it is not clogged. A coat hanger wire can be inserted to break up clogs. An alternative method is to use a bicycle pump to force air through the drain hole to remove any obstruction. Vacuum dust bunnies from under the fridge to allow free flow of the air. Most refrigerators periodically blow warm air across the condensation tray. The warm air dries the condensation in the tray.
Tips
  • Clogs are usually caused when dust, moisture and micro-organisms get together in the drain tube. Keep the dust vacuumed from the back and bottom of the fridge. Make sure the drain tube is firmly connected at all points. The drain tube can be flushed with chlorine bleach, rubbing alcohol or other anti-bacterial product. Product selection should be consistent with the tubing material.
Warnings
  • Use caution with anti-bacterial products. Make sure that any such products cannot flow back into the food compartment.
Things You'll Need
  • Wire hanger
  • Anti-microbial agent such as chlorine bleach, rubbing alcohol or anti-bacterial soap.
Thanks
Posted on Sep 03, 2008
docjohn174
  • 943 Answers
SOURCE: My Bosch Fridge Freezer Model
Hi thanks for the question. I would pull fridge away from the wall . remove back panel . clean all coils . thanks the appliance doc
Posted on Oct 06, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Bosch frost free fridge freezer
The circuit board is fitted behind the display right at the top.
Unplug.
Open fridge, undo the two screws under the display moulding.
Using a thin bladed scraper and a flat screwdiver, prise the panel off at the top join. The top is the only bit with plastc clips, but it will help to apply pressure with the screwdriver at one end as well.
Pull it forward by about 2", and remove the connectors to the on switch.
There may be a drip strip to remove before taking the board out.
Use a thin screwdriver to remove the retaining clip over the board.
Use a small flat screwdriver to lever the board out using he holes at each end.
Observe anti-static precautions as it contains Cmos chips.
Reverse procedure to replace.
Posted on Dec 31, 2008
  • 9 Answers
SOURCE: Bosch fridge not cooling freezer fine
if back wall of freezer has ice or thick build up you may have a defrost problem or if not the evaporator fan motor could be bad, not moving cold air from freezer to refrigerator.
Posted on Mar 14, 2009
Illeagle
  • 525 Answers
SOURCE: How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Posted on Jul 05, 2009
2 year old Bosch B22CS is not keeping temp low enough.
Check the condenser on the bottom back side of the fridge if it is plugged off the freezer will not cool enough. If the condenser fan motor is dead then the freezer will never cool down enough. If that doesn't do it then you are looking at a waxed up cap tobe in which care you will need a professional to take care of the problem. Good luck
Sep 08, 2012 | Bosch B22CS30SNS (22 cu ft) Side by Side...
Bosch Fridge Freezer KGU3200GB/01 alarm beeping temp rising
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 26, 2010 | Freezers
I AM HAVING A PROBLEM WITH MY SAMSUNG FRIDGE FREEZER THE TEMP INDICATOR KEEPS FLASHING AND ITS NOT FREEZING?
Oct 22, 2009 | Samsung Refrigerators
BOSCH FRIDGE
If you have a two door (fridge freezer) some of the newer fridges these days have the cooling come from the freezer to cool the fridge part. Maybe try altering the freezer temp and see if that makes any difference.
Jul 02, 2008 | Refrigerators
Freezer not working
same problem but electronic temperture on in fridge but keeps flashing
Jun 17, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge freezer temprature/hot doors
if your talking about the post between the doors its supposed to be hot its to keep the gaskets dry but you can clean the coils on the fridge if you haven't for awhile that will help keep them the right temp as far as setting the temps i always using your milk and ice cream every one knows how they like their milk and you don't want to have to dig your ice cream out with a chisel
Feb 16, 2008 | Refrigerators
Bosch KGU32160 fridge freezer
The compressor behind the fridge should cycle on and off as the machine maintains temperature, but the evaporator fan inside the freezer will keep running, except when the fridge goes into defrost. If the noise is coming from the fan inside the freezer, there could be some ice on the frame of the fan and the blades are touching the ice. If the noise is coming from behind the fridge it could be the condensor fan motor. This fan is situated behind the fridge in front of or next to the compressor. It keeps the condensor cool by blowing air onto it. Check this fan. The blades could be touching the pipework or something.
Oct 31, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
Bosch Exxcel KGV35421 Bottom Freezer Refrigerator Logo
443 people viewed this question
Top Bosch Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
