Question about Samsung YP-U3 MP3 Player
I have a samsung YP U3 MP3 player that i have installed the software on my computer for. The player charges when I slot it into the USB hole but it appears that the computer does not recognise the player. How do I fix this.
I had same problem try opening gently w/ the use of a small knife
i saw the film inside where the connection to the usb port and to the microchip is cut off i suspect that the continuous closing in and opening out of the port was its cause
Posted on Feb 07, 2012
  • asero_gmatv7
    asero_gmatv7 Feb 07, 2012
    i had same problem try opening gently w/ the use of a small knife
Redownload drivers frm the internet and then download and reinstall samsung media player 5 that should fix your problem
Posted on Jan 07, 2009
Have a samsung YP U3 MP3 player that i have installed the software on my computer for. The player charges when I slot it into the USB hole but it appears that the computer does not recognise the player. How do I fix this.
Posted on Jan 05, 2009
How to put on the songs on it
How to Add Songs on Samsung YP-U3 MP3 Players
The Samsung YP-U3 is an MP3 player that comes in various colors. This device has a built-in USB plug, so it's not necessary to have a cable to transfer songs from your computer. To transfer songs to your device, you will need to use a PC. If you don't have the Samsung Media Center installation disc, you can download the software from the Samsung website.
Instructions
Install the Samsung Media Center if you have not done so. This is the software used to transfer songs to the YU-P3. The installation disc comes with the device. Simply insert it and follow the on-screen prompts.
Insect the bottom end of your device. You'll see a hidden USB plug on the end. Push it outward to extend it. Plug the device into your computer's USB port. This is usually on the front of the tower. The Samsung Media Center will automatically start after a few seconds.
Locate the file you want to transfer to the device. The Media Center's screen will display the MP3 (and other audio) files currently on your computer. When you find a file you want to add, click on it.
Click on the "Right Arrow" button. This transfers the song to the device. Repeat to transfer more songs, if desired.
Right click on the green USB icon on the right-side of your taskbar. Select "Safely Remove." Unplug your Samsung YP-U3 when prompted.
Hope it helped..
Have a nice day...
Feb 22, 2011 | Samsung YP-U3 MP3 Player
Computer wont recognise my software for yp-u3 mp3 player
go to my computer icon on desktop !
click right mouse go to proberties --- system or device ---device management --- there you can solve the problem .
rate please !
best regards .
Jan 12, 2010 | Samsung YP-U3 MP3 Player
My samsung yp-u3 is not charging. when i plug into
No its not broken try to hold it tightly then it will work. Thanks :)
Jan 02, 2010 | Samsung YP-U3 MP3 Player
How do I charge Samsung MP3 player Yp-U3 Samsung YP-U3 MP3 USB port not connected to the computer
The player needs to be charged via the USB connnection on your PC. If it doesnt fit, try the USB ports on the back. If its not working/not charging, please test the MP3 player on another PC.
Jan 21, 2009 | Samsung YP-U3 MP3 Player
I have a new yp-u3 mp3 player but i don't know to turn in on .all the instructions are in the Korean language but i speak english
My new YP-U3 player does not connect when entered into the USB port of the computer, states disconnected, it does charge though. The Samsung Media Studio has been installed and is operating
Jan 02, 2009 | Samsung YP-U3 MP3 Player
My yp-u3 wont connect
no reconoce el dispositivo
Nov 06, 2008 | Samsung YP-U3 MP3 Player
MP3 can't work normally
With the YP-u3 connected to the USB port and internet connected, start Samsung Media Studio software, you should get notification of a firmware update to download which fixed the recognition problem for me
Sep 13, 2008 | Samsung YP-U3 MP3 Player
Samsung YP-U3 MP3 Player Problem connection
Found the solution on another site (http://www.everythingusb.com/forums/showthread.php?threadid=11238). To quote user AFHavemann :
"* Plug in the player so the USB bus can see it.
* Once it’s recognized (i.e., the device screen reads "Charging" and "USB Disconnected"), go to the Control Panel and click "System"
* Choose "Hardware" then "Device Manager" tab.
* Look for the name of your device under “Portable Devices” in the list
* If the name of your player is under “MTP Device” then the correct drivers are probably loaded
* Right-click on the name of your device and click "Properties"
* Click “Update Driver”"
Then follow the prompts from there. The computer searches for the driver software, etc., and reinstalls/resets information related to the device, which fixed things such that the computer will now recognize the device. I'm not sure what causes the problem, but this solution seems to reset whatever's gone wrong.
Sep 03, 2008 | Samsung YP-U3 MP3 Player
Computer Freezes when Samsung YP-U3 in USB Port
Get the firmware upgrade from the Samsung website:
http://www.samsung.com/us/support/download/supportDown.do?group=audiovideo&type=mp3players&subtype=flashmemory&model_nm=YP-U3JQPY&language=&cate_type=all&dType=D&mType=FM&vType=L&prd_ia_cd=03040200&disp_nm=YP-U3JQPY
But, it sounds like the USB interface on your computer is diverting all of the power to the USB port, and away from the mouse/keyboard slots - you may need to contact your pc manufacturer on that one.
Jun 18, 2008 | Samsung YP-U3 MP3 Player
U3 mp3 player
I bought a Samsung YP-U3 . It had the installation cd .When plug to usb port It's charging but it shows disconnected...the samsung media studio and my pc don't recognise it, allways ask new samsung YP-U3 found. when i give the path to cd it dint get. Please help me....
May 13, 2008 | Samsung YP-U3 MP3 Player
Samsung YP-U3 MP3 Player Logo
212 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
