Question about Yamaha DVX-S120 System
Want to tune sony tv using dvx-s120
Guys, would like to tune tv through my cinemastation so i can enjoy all tv programs on my 5.1 spekars..also would like to know wiring diagram to tv cheers, virendra
SOURCE: Yamaha DVX-S120 On Screen Menu - Phillips brand
The same happened to me! DVD's play fine but on screen menu just changed and Video Output option is gone! Also de Philips logo on screen which I suspect is placed there by my TV (which is a Philips one) and as it does no longer receive the background screen from the DVX it just puts its own. Is your TV Philips like mine?
Posted on Jun 20, 2007
0 characters
1 Points
Yes I have a sony home theaterand I'm trying to hook The insignia remote to it
Remote Control Codes for Home Audio - Page 35 ...
Jun 29, 2012 - Re: NSR2000 remote codes for Comcast Universal Remote .... I havetried to program my Direct TV remote (RC64R) using the codes on ... I'm hoping you guys have the code for the sony remote so that I can just use a ... Insignia Device: NS-H2002B Insignia 200W 5.1-Ch. Home Theater ... Connect With Us:.
BDP-S3200 issue not able to control TV with remote - Sony's ...
May 25, 2014 - Televisions & Home Theater .... how to connect blu-ray BDP-S790 and Xbox into 1 HD. .... Have you already tried the programming instructions on page 43 of the manual? .... My problem is the same as the BDP-S3200 but my tv is an INSIGNIAmade fot LG. i .... So is this a 'Guess I'm out of luck' situation?
Sony Home Theater System DAV-TZ140- Gaming console ...
Dec 19, 2015 | Sony Home Theater Systems
DVR-S150 shows No Disk even though a disk is inserted
Most likely, your Optical Pickup(laser) has worn out. It needs about.15 milliwatts to operate correctly. When you insert the disc, the laser must focus on it to read the table of contents. If it no longer has enough output left, it will assume there is no disc inserted in the drawer, which is your issue. If you're interested in having it fixed, please visit my website at, Thank you.
Feb 01, 2012 | Yamaha DVX-S120 System
Can i connect extra spekars
Your unit is design for the packaged speakers, once you add other speakers aside from them your amplifier will expose to excessive load which will caused an overload. It will produce more heat and will damage the output IC.
Give a thumbs up if you find it useful.
Thanks for using fixya.
Have a nice day.
Feb 09, 2011 | Sony DAV-DX255 System
The disc has appeared to stop rotating. The info window continously says "reading".
DVD/CD Read/Write process: 1. The tray or carriage places the disc into the spindle or motor. 2. The spindle motor locks into place to prepare motor to spin - the disc is in free space and does not touch anything except the spindle motor. 3. The laser assembly moves into home position and attempts to focus on the disc by emitting infrared light to disc. 4. If a disc is present, the light should reflect back to the laser lens as the lens attempts to focus on the light - you will notice the lens moving up and down to focus. The lens should NOT touch anything. 5. Upon a successful focus, the spindle motor spins. 6. Data is read and sent to a buffer for decoding. 7. Success.
Dec 27, 2010 | Yamaha DVX-S120 System
IM tring to output the tv sound to my dvx-s60 *yamaha* im using a samsung led tv 42 how can i fix it?
You hook the DVD etc to the inputs on the receiver and then output from the receiver to the input on the TV.
Aug 14, 2010 | Yamaha DVXS60 System
My VCR not recording after the switch to digital tv signal
The answer to this question can get a little complicated. Lets tackle it in two parts. First the last part; the part about picking up channels as decimals. With analog TV transmission, it took the full television broadcast channel to transmit one standard definition TV program. The newer digital transmission system uses some advanced video compression and audio compression technology to reduce the data needed to transmit the pictures and sound which allows the same bandwidth to deliver either High Definition Television programming or MULTIPLE channels of Standard Definition programs. So in your example above, you use to watch one channel of programming on TV channel 4, but now the TV station can broadcast multiple channels of programming on channel 4, sot they delineate the programs with a decimal point. So 4.1 it the first program on TV channel 4, 4.2 it the second program on TV channel 4..... Well, I hope you get the idea.
Now for the hard part of your question. I believe that before the transition, even with your new digital TV, you were still enjoying the analog broadcasts from your stations. Your VCR picked them up and recorded them and your digital TV could tune them in and you watched as you had always done in the past. After the transition you noticed that your VCR could not record anymore and your digital TV had discovered the digital channels that replace the analog channels. To remedy this situation, your VCR will need the aid of a DTV converter box to tune channels, and you may have to reconfigure the way your TV and VCR are connected. The best resource that I can give your for the reconnecting is the website Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Scroll down to the Normal 0 false false false MicrosoftInternetExplorer4 section about “Set-up #2: Watch One Channel while Recording a Different Channel”.
Hope this helps
Jun 20, 2009 | Insignia Digital-to-Analog Converter for...
Video/dvd/cd play but no sound from speakers
Try changing "audio" setup in your TV to "variable" instead of "fixed", if you have that option on your TV set up... I have a Sony HD widescreen, and that worked for me...
Feb 16, 2008 | Home Theater Systems
Mar 26, 2007 | Yamaha DVX-S120 System
Sound Interference coming throught the Amplifier
On many occasions high pitch interference is a result of bad wiring and grounding problems. Check to make sure that you followed the manufacturer's instructions concerning grounding and installation of the amp, and if possible try and install it at another location in your house, using other electricity sockets. If the problem is solved by relocating the system, you might be looking at wiring problems (audio equipment can be very sensitive to that), if changing anything in the installation process solved the problem then the problem was probably due to bad grounding and "loose" electricity. Try making the installation as "clean" as possible, avoid tangled wires and stressing a single socket with too many electric appliances. If the problem persists, and you are still under warranty, I suggest contacting your local Yamaha dealer. If you're out of warranty I suggest locating a professional repair person.
Jan 17, 2006 | Yamaha DVX-S120 System
Yamaha DVX-S120 System Logo
22 people viewed this question
Top Yamaha Home Theater Systems Experts
Matthew Spark
Matthew Spark
Are you a Yamaha Home Theater System Expert? Answer questions, earn points and help others
