Question about Canon PIXMA iP4600 Color InkJet Photo Printer
Alignment of printhead on Canon Pixma iP4600
I am trying to set up my new printer and have reached the print head alignment stage. Unfortunately I have flashing orange and green lights even before I start the alignment procedure a nd on clicking to align the print head I get the C000 Service error message. Please advise me.
  • 1 more comment
  • philenglish Jan 24, 2009
    Same problem. This is the second IP4600 I've bought with this problem. The first went back and I got a refund, but this is now beyond a joke
  • chromeman85 Jan 26, 2009
    Same problem. Just trying to install it. Anyone able to help?
  • Anonymous Mar 16, 2009
    Same as others describing, green and orange lights flash intermittently, tried reinstalling the cartridges but to no avail.
This is simply a case of the ink tanks not being pressed in hard enough. They do click in, as the manual instructs but, unless they are fully pressed in top and bottom, this problem occurs. It's a shame that the Canon manuals and even the support centre do not mention this simple solution.
Posted on Jan 26, 2009
Hey guys. Try this link - http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=17406&kbpage=yes.
Worked for me!
Good luck.
Cannon PIXMA MG500
Hi! try printhead nozzle alignment and head cleaning from maintenance tab in printing preferences. it will print a test page after cleaning printhead. Good luck!
Nov 30, 2012 | Canon PIXMA iP5300 InkJet Photo Printer
Cannon multipass 730
Try reseating the printhead. Remove the ink cartridges, lift up the lock lever and then pull the printhead out at an angle (IIRC). Then reinsert the printhead and lower the lever. Then reinsert the ink tanks one by one; Press down until you hear the click. Close the scanning unit and hit Set to print the alignment page. Tell the printer which line in each column has the best print quality (most solid); this is the horizontal alignment. Then repeat for the vertical alignment.
Try resetting the printer (on/off cycling). If this doesn't work, you may need a new printhead. Unfortunately, this may not solve the problem and you may need to have the unit serviced. Printheads are not returnable once you install them (so if replacing it doesn't help, you are stuck with the spare.)
Good luck. I hope this helps.
Jul 22, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
How to configure printhead alignment
Hi there, Aligning the Print Head
If ruled lines are misaligned or a printout is unsatisfactory,Print Head Alignment is required.
Steps for Aligning the Print Head.
1) Press [Menu] repeatedly until [Maintenance] appears.
2) Press [Maintenance] repeatedly until <P> appears.
3) Press [Black] or [Color].
The machine print the head alignment sheet.
4) Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
5) Load the checked sheet on the Platen Glass.
When loading the checked sheet, place the front side down, and align the upper left corner of the sheet with the alignment mark on the lower right corner of the Platen Glass.
6) Press [Maintenance] repeatedly until <U> appears,
7) Press [Black] or [Color].
The machine scans the pattern and aligns the Print Head automatically.
Note : If you select <L>in step 2, the machine prints the current Print Head Alignment setting.
Hope this help.
Have a good day.
Dec 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA iP4600 - error 6A80
Hello someone else here had this problem, this is what he posted: "Same problem with a Canon MP540 fresh from the box. Turned out to be the print head unit was not returning fully to the home position ie extreme right. My Fix : When the scanning unit cover is raised the print head unit moves left for access, look in the vacated area to the right, in particular the small black sponge where the head normally parks. I found a small spring jammed in beside the sponge, removed it and all is well. Don't know what the spring was meant to do but everything is working fine without it.On the MP540 the head unit now glows red, presumably meaning all is well... "
Jun 14, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Mar 18, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
Banding
Unfortunately, one choice Canon made to keep the price low was to eliminate automatic alignment. That means you have to align the print heads manually—an unusual step for all but the least-expensive printers today. Manual alignment involves printing an alignment page, picking the best-looking choices for each of several alignment samples, and then entering the settings in the printer driver.
Feb 15, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
I have just re-started my Canon PIXMA MP610 after it has been in storage for 2 months. It is around 1yr old. It seemed to work OK. When i went to print the 1st page, the paper jammed because of some...
I would suggest removing the printhead, make sure there are no more dead roach's under the printhead, also make sure all lights on the ink tanks are lite up, the first error code you mentioned has to do with the ink tanks, the second one has to do with the printhead. I would suggest un-installing the printhead, then reinstalling it doing the alignment, and that should clear the error code.
Sep 28, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Canon PIXMA iP4600 Color InkJet Photo Printer Logo
2,210 people viewed this question
old marine
old marine
