Question about Miele S5211 Deep Black Vacuum Cleaner Bagged Canister Vacuum
My Miele S5211 has lost suction power on max setting. I put on min setting to hoover chairs now when i turn upto max says on min setting
Hiya i have several setting on my miele s5211. I use the upholstrey setting to hoover the chairs as this has minimum suction, but now when i turn it upto max setting for carpets it stays on the min setting suction, so won't pick up anything off my carpets. also its shows the red indicator bag full even when i have changed the bag. Help! i got a Miele as i gave up with Dyson and now my Miele seems to have broken
2 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: Instruction required for the removal of a full
Sure thing, the best thing to do is to have a look at the manual I have found here for you. The part you are looking for is on page 25 of the manual, complete with pictures and everything.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Here is the manual:
http://www.miele.co.uk/Resources/OperatingInstructions/S%205211_5781.pdf
Posted on Oct 15, 2010
Testimonial: "Thank you very much,we have missplaced our operating manual so this is just what we require,again our thanks"
Why has my vax power VX2 hoover now lost it's suction ? I have noticed that the roller has limitied brushes on it now and was clogged with hairs . I have removed this now and the brushes are still min
Sounds like something is clogging up the pipes between the head and suction pipe. Have a poke around with some wire to see if it's full of hair or fluff, maybe even a sock?
Sep 16, 2014 | Vacuums
Miele vacuum s5211 stopped working bag overloaded
Not sure what your asking.. Have you emptied the bag or tried replacing it with a new one?
Apr 19, 2014 | Miele Vacuums
Miele Vacuum Cat and Dog Upright S7260 Loss of Suction
could be a couple things first make sure the hose is clear check real good the other is make sure your bag is good and tight and clean and make sure you have no holes or tears in the hose
Mar 07, 2014 | Miele Vacuums
Miele S5211 accidently pulled out the whole device that the bag is attached to.
Hi There I have made a video showing how to replace the bag holder it is not too hard to do.
Sep 17, 2013 | Miele S5211 Deep Black Vacuum Cleaner...
Attach new torsion spring and bracket for miele s5211 vacum bag
Hi There, I put up a new video just recently showing how to fit the bag holder on a miele vacuum. Have a look it should be helpful.
Feb 08, 2013 | Miele S5260 Bagged Canister Vacuum
My S5211 is 5 months old and was running perfectly. Last weekend I took it out to vacuum house but it would not start. I checked the fuse in the plug but it was fine. I replaced the dustbag but still it...
if you put everything back in place properly it should be working,check dust bag properly seated, and cover reseated, still not working do as planed, take it backto the shop, hope this helps
Sep 01, 2011 | Miele S5211 Deep Black Vacuum Cleaner...
Miele, Flamenco II. 2 probs. 1. the head brush is not turning when I put it on the floor. If I pick it up to look inside...the brush is spinning fast..I put it down on the floor...the head does not...
sounds like the belt is not on correctly on the beater brush or the belt is worned out now for the suction check filters or bags that need to be empty or clean
Feb 16, 2011 | Miele Vacuums
Hoover suction
I had a fur ball stuck in the pipe.  I took the end off and used a broom stick to clear it out.
Jan 13, 2010 | Miele Cat & Dog 326i Bagged Canister...
Hoover empower lost suction
The first thing you need to do is remove the debris bin in the front. Turn on the vacuum and feel if there is any suction at the bottom of that compartment. If not then your problem is not a simple blockage and you can stop reading this right now, if you do feel good suction, you're in luck.
The problem is almost assuredly a blockage of some sort. The Hoover Empower's greatest feature is its simplicity of design which is basically a 12 amp motor creating a powerful suction over a very short path as vacuum cleaners go.
While you still have the debris container out of the machine, disconnect the accessory hose from its mount on the right (or "passenger") side of the machine and blow through it. You should plainly feel your own breath coming out of the rectangular slot in the area behind where the debris container mounts.
If you don't feel it, or if it is not strong, well there's your problem. You will need a Torx driver set to remove the 13 screws that hold the back of the vacuum cleaner on and the accessories hose in. Unless you are a total tool geek, you probably won't have anything like this around but you can pick up a set of Torx head screw drivers at any decent hardware store. The look like an Allen wrench set but the ends are different. Look at the screw heads and you'll see what I'm talking about.
Once you remove the screws, the rest of the job is a piece of cake. Brush out or wipe down the air channel and clear the accessory hose, put the rascal back together and buy yourself something nice with the 70 or 80 dollars you would have been charged to do the same work by someone else.
Gregory Glaser
Jun 20, 2009 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Miele S5211 Deep Black Vacuum Cleaner Bagged Canister Vacuum Logo
119 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
