How to fix error 0x800704Sa in Windows
I have this error when I was installing Windows 8 in a computer with Windows 7
Error 0xc000007b
fix 0xc00007b error "the application was unable to start correctly"
there may be multiple reasons as to why you might receive 0xc00007b error when trying to run an application on a windows machine. 0xc000007b error usually comes from mixing up 32bit environment with 64bit one. For example 32bit application loads a 64bit dll causing 0xc000007b error.
Solution 1
In most cases it's .NET framework causing issues. This can easily fixed by re-installing latest .NET framework from [link]
Solution 2
Re-install the application that you are trying to run. It sounds simple but the application data files could be corrupt or missing. This could be caused by a installation that did not complete successfully or by a virus.
Solution 3
Running the application as an administrator could fix this error. Right click on the program shortcut or program .exe file, then click on Properties, and on the Compatibility tab. Check the Run this program as an administrator box, and click on OK
Solution 4
Restart your computer as some applications require restart after installation to function properly.
Solution 5
Run Windows update as it can provide application fixes and updates. Furthermore it installs missing drivers and updates the outdated ones like graphic card drivers. Windows 7 / 8 / 8.1 users need to search for "windows update". select all important and optional updates and click on the "install updates" button. If you use Windows XP navigate navigate to Windows Update by choosing Start > All Programs > Windows Update. When the scan is complete,Click the Review and Install Updates link. Finally press the "install now" button.
Windows 7 / 8 / 8.1
Windows XP
Solution 6
manually update the application if possible.
Solution 7
re-install Microsoft Visual C++ from [x32 link] or [x64 link]
Solution 8
re-install DirectX [link]
Solution 9
Many times hard disk problems can be repaired using the chkdsk command. If you are using windows 7 press the start button in bottom left corner of your screen. If you are using windows 8 / 8.1 press the windows key .Search for "cmd" and Right click it and select "Run as administrator". Windows XP users Click on start > run. In the Run box, type in "cmd" in the box.
Windows 7:
Windows 8 / 8.1
Windows XP
A CMD window should appear. In that window you can just type it as you see "chkdsk c: /f /r". If you have more then one drive or partition, you will need to tell it the disk (chkdsk d: /f /r).
If it is the primary windows disk c: it will ask you to schedule it for next boot. When you restart, it will do a chkdsk for you before even getting to the login screen.
Solution 10
This solution only works for a 64-bit system. It requires replacing files is system32 directory so be careful. Only attempt this solution if you are confident and if other solutions have failed. When Microsoft Visual C++ Redistributable Package is not properly configured it may cause 0xc00007b error. Firstly download the zip file [link] and decompress it. Reboot in safe mode and go to C:\Windows\System32. copy all files included in the zip package (mfc100.dll, mfc100u.dll, msvcr100.dll, msvcp100.dll and msvcr100_clr0400.dll) to C:\Windows\System32 replacing the current ones. After that reboot in normal mode.
If all the solutions above haven't worked i would consider backing up data and performing a clean install of windows.
Jan 11, 2016 | Dell Inspiron Computers & Internet
I have a problem installing a Adapter for my Netgear wn111v2 adapter on my HP Compaq Elite 8000. Every time I install it. I get a error message.
quite possibly the two are not compatible . older routers do not like win 7 or win 8 and win10 is even worse
Aug 21, 2015 | NetGear Computers & Internet
I purchased a desktop computer with Windows 7 and need to install a wireless USB adapter. I've purchased two wireless adapters and both came with a small CD from Realtek Semiconductor supposedly with
Download available to fix realtek usb driver errors. Recommended: To repair realtek usb driver errors, use this software package: RegCure Pro. This repair tool has been proven to identify and fix realtek usb driver errors and other Windows problems with very high efficiency.
Download Now
File Size 5.6MB Requirements Windows XP / Vista / 7 / 8 Downloads Over 500,000 Download Time Broadband: 6 sec / Dial-Up: 3 min End User License Agreement
Uninstall Instructions
Apr 17, 2014 | Realtek Semiconductor Computers & Internet
Can I install windows 7 in my windows 8 computer
Yes you can for as long as there are drivers which compatible for windows 7. What is the build of your computer?
David
May 26, 2013 | Computers & Internet
WANT TO AD RAM
Step 1:
windows 8 upgrade b> Run the Windows 8 Upgrade Assistant :
http://windows.microsoft.com/en-US/windows-8/upgrade-to-windows-8. Note: To make sure the system is compatible visit http://windows.microsoft.com/en-US/windows-8/system-requirements. http://windows.microsoft.com/en-US/windows-8/upgrade-to-windows-8 b> When making significant changes to your computer such as an upgrade, it is always recommended you backup your system prior to installing a new version of Windows. Thankfully, all editions of Windows 7 includes system imaging, which means you can backup your entire Windows 7 installation and restore it if it fails. Learn more about how to backup your Window 7 installation here In addition to System Imaging, you can backup just your personal files using Backup and Restore, to do that, check out the following article: http://notebooks.com/2010/12/27/how-to-backup-to-an-external-hard-drive/
http://notebooks.com/2011/02/25/how-to-restore-a-backup-from-an-external-hard-drive-in-windows-7/ If you want to backup themes, wallpapers and other minor features, Windows Easy Transfer is another option, you can learn more about it here What you can do before attempting the upgrade? You can do some pre-requisite tasks to ensure a smooth migration from Windows 7 to Windows 8. If you are using a name branded computer such as a Dell or HP, go to the manufacturers website for the model computer you are using and download the latest available drivers for that computer. Store them on a disc or USB thumb drive. Important drivers you should try to obtain include Network and Video Drivers. Its possible that they might just have Windows Vista or Windows 7 drivers, those will work with Windows 8. Other things you can do: Uninstall any security software before attempting to upgrade. Disable any encryption software you might have installed. Disable/uninstall disk utility software such as DVD/CD burning utilities or third party defragment programs such as Perfect Disk. Make sure your computer is updated (devices and applications). Disconnect any external devices before installing. Check your hard disk for any errors:
- Click Start
- Type: CMD
- Right click CMD then click Run as administrator
At the Command Prompt, type: chkdsk /r /f
Exit the command prompt.
When you restart your system, your computer will be scanned for errors and attempts will be made to correct them. Another thing you can do is disable Start items: Click Start Type: MSCONFIG. Hit Enter on your keyboard On the General tab, click Selective Startup. Under Selective Startup, click to clear the Load Startup Items check box. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All. Click OK. When you are prompted, click Restart. After the computer starts, check whether the problem is resolved. Run the System File Checker utility. SFC/Scannow checks your Windows installation for errors and corrects them. This will help with ensuring that a smooth upgrade occurs. Click Start
Type: CMD, from the results, right click CMD
Click 'Run as Administrator'
At the Command Prompt, type: sfc/scannow This will check for any integrity violations Restart your system
Feb 06, 2013 | Computers & Internet
Tried to update win 7 to win 8 but when loaded receive message OXOOOOOO5D nowcan,t start computer
windows 8 is far better than windows 7
To install Windows 8 on your PC, the processor (CPU) must support the following features: Physical Address Extension (PAE), NX, and SSE2. Most CPUs have support for these features, so if you receive this error, it is likely because the NX feature is not enabled on your system. To resolve this error, follow manufacturer guidelines to enable NX ("No eXecute bit"), or the equivalent XD ("eXecute Disabled"), feature within the BIOS settings. This feature is typically found in the Advanced or Security tabs within the BIOS settings, and can be referred to by a variety of names, including but not limited to: • No Execute Memory Protect • Execute Disabled Memory Protection • EDB (Execute Disabled Bit) • EVP (Enhanced Virus Protection) If the BIOS setting for the NX (XD, EDB, or EVP) support option is not available on your system, you may need to contact the manufacturer to update the BIOS. Note that some very old processors may not contain these features and will be incompatible with Windows 8 Release Candidate. A whitepaper has been published with further details about the PAE/NX/SSE2 requirement for Windows 8, error cases and scenarios that customers encounter when machines fail to meet the requirement, and what to do to install Windows 8 on their PC's. You can download the whitepaper at http://msdn.microsoft.com/en-us/library/windows/hardware/hh975398.aspx
Jan 18, 2013 | Computers & Internet
Windows 7 Update
Follow this article
System Update Readiness Tool fixes Windows Update errors in Windows 8, Windows 7, Windows Vista, Windows Server 2008 R2, and Windows Server 2008 http://support.microsoft.com/kb/947821
Jan 13, 2013 | Lenovo Computers & Internet
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
