Question about DEI Python 1400XP Remote Start/Keyless Entry System
Remote went through washer and dryer...Does not work. Does the system have to be rewired or can I just purchase a new remote
    Problem Solver:
  • 4 Answers
You need to purchase a new remote and the program the transmitter to the brain. it is real easy. but make sure that you purchase the same model of transmiter.
Posted on Jan 04, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Bose music system remote is inconsistent.
The notoriously unreliable SMD capacitors which Bose installed are long defective. That's just the start of your problems.
You'll need to replace those defective capacitors with much higher-quality units than the original.
Only a tech experienced with SMD work should attempt this repair.
Replacing the PCB will solve your problem for only a short time, as you are just getting the original standard junk again, but new.
Dec 29, 2014 | Bose & Wave& Music System
I have a hamton bay remote ceiling fan it the fan quit working and can't find the remote control can I hook it up straight and do away with the remote control system
You're playing with fire there, mate. Find the remote or buy another. To connect it directly to the mains requires a skilled electrician. I've done it myself and found it really hard. So, I went to the store and purchased a new remote module for the type of fan and then did it myself. Now it works as new. I suggest you do the same if you do not wish to electrocute yourself by wiring it directly to the mains.
Jul 02, 2014 | Dryers
Remote is not working for my Lionel Holiday Tradition Express Train with new batteries. Any suggestions?
I rewired my train this weekend..it now works on my outdoor setup....I found that the circuit board inside the engine had a blown capacitor and the power transitor was fried. I by passed the engine board found that it only would run backwards....went into the tender and taped into the power from tack bypassing the rectifer... By the way the engine does not start up when one uses the remote...there is a 20 second delay before starting
Nov 27, 2011 | Lionel 11000 Holiday Tradition Express...
Light works, fan doesn't. It rotates freely, but
Make sure the switch on the fan is set to high first. If it is, either check the voltage coming out of the remote box, or bypass the remote box to see if the controller went bad. Be careful and only check voltages on live circuits if you have the knowledge to do so safely. Disconnect the power before attempting to rewire anything.
Mar 20, 2010 | Dryers
Vizio remote stop working
My remote stopped working too. A universal remote from my cable provider also didn't work, so I assumed the problem was in the television itself.
The power going to the outlet was old and lacked a ground. I just rewired the outlet going to the TV with new Romex that is properly grounded and voila!
Remote is working again. Nuts
Dec 19, 2009 | Vizio VO320E LCD TV
Battery went dead
If you live in the US, you can buy a new battery by calling 1-800-231-7717.
If you live elsewhere let me know and I will tell you how to get replacement parts for your Harmony remote.
Jul 28, 2009 | Logitech Harmony 890 LCD Remote Control
Bulldog m200 just stoped working
If it is the same brand and model you will not have to rewire anything
Jun 09, 2009 | Remote Starter with Keyless Entry
Fan with light (no remote) with wall switch not a 3-way
Unless you want to use pull chains, you will either have to get a different fan with a remote, or you can buy a remote to ADD to an existing fan/light. It hooks up under the base of the lamp. They seem to work better than the factory fans with the built in remotes.
Dec 04, 2008 | Hunter 52" Ceiling Fan With Light And...
Help
Follow the directions in the remote monitor system owners manual on clearing and resetting the home code. That should take care of the problem.
Oct 10, 2007 | LG Remote Monitoring Laundry System -...
Open Questions:
See all DEI Python 1400XP Remote Start/Keyless Entry Questions
DEI Python 1400XP Remote Start/Keyless Entry System Logo
266 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
