Question about Imperial ICVD-1-H Turbo-Flow Gas Single Oven
Imperial convection fan motor failed after a brownout. Is it the capacitor, motor itself, or is it something else?
Model ICV 1 70,000BTU 120 Volt Purchased 1999. Original motor, dusted occasionally but never replaced. Used daily. If cost of repair is excessive, the unit should probably be replaced due to the fact that the oven door mechanism slips occasionally and can hardly be adjusted due to wear, rust, and a slight warp in a hinge cog. I would like to hear if this this otherwise fine unit is worth repairing?
  • 24 Answers
OK door mech's first. The chain gear will not warp, it is probably a seized-up chain link and the turnbuckles usually wire-brush up fine. Add some release fluid and they should adjust easily. Check the grub screws in the chain gears as these DO work loose. The chains are fitted to the adjustment rods/turnbuckles with split links. The chains and links could be replaced if the old ones are just to seized to free off. Once the door is adjusted correctly, apply copper grease (Like the stuff used on brake parts) to the chains, gears, door switch cam and hinge points. Makes a massive difference to their reliability.
Now the motor. Several variants were fitted but if I am correct, all the ICV ovens had two 11-pin relays in the control panel one for high and one for low speed. If one fails in the on position, both high and low speeds are energised together (huge buzz no motor). The relays are far more likely to be failed than a motor (assuming a brown out was just a loss of power/low power and not a massive power surge/spike). Easy check for stuck relay is to take one out and check the motor on high then low speed. One would work the other would not. Now switch the relay that is unplugged and see if the opposite speed works. If neither speed works then check cook/cool/ off switch. The cool function and the door switch form part of a two-way circuit. If either the door switch or the cook cool switch are faulty you may loose the motor function. The switches have to be tested out of circuit so note the wire positions to aid correct placement when putting wires back. Only after you have done those tests should you go to the motor terminal box and test for voltage present. If it does prove to be a faulty motor, take it off and have it rewound or replace with new motor from Imperial. Certainly cheaper than a new oven!
Posted on Nov 25, 2014
3 Suggested Answers
SOURCE: our imperial convection oven will not light. NO ignition
Your door switch is not reading that the unit is closed
Posted on May 28, 2010
SOURCE: No ignition
EL HORNO NO SE APAGA EN LA TEMPERATURA SELECCIONADA Y CALIENTA DEMASIADO
Posted on Feb 04, 2011
Imperial single older convection ICV pilot lights, have flame, but wont light / heat oven. replaced thermostat, didnt help problem, now what?
I suspect the thermo coupler if there is one. I had to replace ours. I took it out and took it to a repair man and he sold me one just like it. Works good now. Make sure the parts are clean where the gas comes out as well The burner as well.
Oct 20, 2016 | Imperial Ovens
Imperial icve-1 standard depth 208/240 volt connextion help
Are you in the EU or US and can you be more specific, it is fairly straight forward. If in doubt get a professional to connect it for you.
Apr 10, 2014 | Imperial ICV-1 Turbo-Flow Single Oven
Imperial icv-1 electric oven
Not sure what type of oven you are having, Gas or Electric ?
Apr 10, 2014 | Imperial ICVD-1-H Turbo-Flow Gas Single...
How do you adjust doors on imperial ICV-1 convection oven
The turnbucke system behind the lower panel is relatively straightforward but one buckle is LH thread the other is RH thread. Slacken both locknuts and adjust the buckles until the LH door lags by the thickness of the RH door when they are just coming together (a rough approximation). Don't have too much tension on the chains and lube the chains, gears etc with a copper based grease. It has been known for the little grub screws in the bottom cogs to come loose. You'll need an allen key to tighten them up.
After all adjustments check the chain 'slack' by quickly opening/closing the doors when at about 1/2 open. There shouldn't be so much that the LH door doesn't react reasonably quickly to the change of direction, but not so tight as they are like bow strings.
Mar 08, 2013 | Imperial ICV-1 Turbo-Flow Single Oven
I have a imperial convection oven that I just purschase and operated fore 4 days, and the fan stoped working any idei what would cause this?
You don't say what model. Some Imperial ovens have a cool-down switch that lets the fan run with the doors open but not in cook mode. That is a starting point.
Mar 27, 2012 | Imperial Ovens
Oven fan motor is burned. Can we rewire the oven to bypass the fan motor
No. The whole combustion process relies on the fan motor drawing combustion products into the cavity and out the flue. Get the motor replaced or rewound.
Feb 04, 2011 | Imperial ICV-2-H Turbo-Flow Electric...
I put in a new switch for the top oven but the convection fan is going on only in cool down mode not on oven mode. it should go on when oven turns on (button up) but goes on when button clicks down (cool...
Door needs to be closed in cook mode to work. You sure you put the switch in the right way up? Also you could have a dodgy door switch as the cook/cool switch and the door switch operate as a two-way circuit.
Nov 20, 2010 | Imperial ICV-2-H Turbo-Flow Electric...
Imperial ICVD-1-H Turbo-Flow Gas Single Oven Logo
80 people viewed this question
Top Imperial Ovens Experts
Dan Webster
Dan Webster
Dennis Boxerman
D. E. Hev
Are you an Imperial Oven Expert? Answer questions, earn points and help others
