Ok - what is your board number? usually it is printed on your motherboard. Eg. ga-7vm400am. it could be just numbers as well. When you get that, google it + sound drivers. you ought to find the link to download it. Alternatively you can try downloading everest, run it, and will it give you your soundcards model, google that and you will get your drivers. good luck
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
If your computer came with a motherboard disc the drivers could be on it
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don't see it everything is OK and your card is working properly. Hope this helps don't forget to vote
plz install audio driver suitable my pc
Hi and welcome to FixYa,
Initially, pls postback what motherboard.
Good luck and Thank you for using FixYa.
