Question about Compaq Evo N610C Notebook
Not able to connect wirelessly to internet
I have a compaq laptop -734DU Model. The problem is that its wifi button always remain on and switching it off too does not work.
Also in 'connect to' option 'wireless connection' icon is not listing down.
Now I have a wireless broadband connection and i am able to connect to internet.
Please suggest some solution.
Sid - India
    Genius:
  • 1,913 Answers
Reset your roter then configure again.
reset switch in back side of router press it for 10 seconds.
then if u dont know how to confiure let me know.
Posted on Jan 03, 2009
I want to activate wifi on my laptop Model: HP COMPAQ HSTNN-A25C. Please advise the process.
The wifi switch will be in one of the following places. It may have a wifi symbol which will look like radio waves. I hope this helps.
  1. Check the front edge of the laptop for a switch that goes from left to right. The light will normally go from Orange to Blue
  2. check the side edges for the wifi switch
  3. Look at the top of the Keyboard above the number keys to the right. you may find a button there.
  4. Or you can manually turn on your wifi.Click the "Start" button, and click "Control Panel." Click "Network and Internet." Click "Change adapter settings." Right-click on "Wireless Network Connection," and select "Enable" from the menu.
  5. Once you see the wifi symbol at the bottom right of the Laptop screen (near the date/time) click on it and choose your wireless network.
Jul 29, 2016 | HP Computers & Internet
Improper shut down
try to refix ram,remove ram clean ram and refix it.If its not ok then remove wifi card and switch on laptop with out wifi card.if the laptop is shutting down with out wifi card then clean the lead of wifi card and refix wifi card and if the same problem persist try to update bios with out wifi card and check with wifi card connected back again.If the problem persist replace wifi card.Follow this link to refix ram in that vedio http://www.youtube.com/watch?v=Q1m0SBQu7iU .Follow this link to refix wifi card http://www.youtube.com/watch?v=54VS4bFM-qI
Jan 12, 2014 | Dell Inspiron 15 (N5050)
Where is wifi switch on the compaq laptop?
Well, you haven't given the model number to your compaq. I will try to assist you the best I can, if this doesn't help then I ask that you provide the model number. Some of the Compaqs have a button right between the keyboard and the monitor(it looks like this: http://www.hp-pavilion.ru/Catalogimages/Compaq-Presario-C700/29945.jpg). Others will have a switch somewhere with a orange dot/light near it. If you don't see either of these then there is probably a function key for it. Incase you don't know how function keys work, functions are usually located under the F1-12 keys, you hold down the FN key and press the corosponsding Function. The Wi-Fi function key usually has the same symbol as the one in the picture above. If all else fails and your WiFi still isn't working you could have a more indepth issue.
Nov 20, 2009 | Compaq Computers & Internet
Wireless device button not working
check if drivers are installed..
if drivers are installed then go to control panel and network connection if xp then right click on wireless network connection and disable and then enabe it..if this solve problem... otherwise check for drivers..
Sep 09, 2009 | Compaq Presario 700 470024-192 Notebook
Wifi switch is not working
check your wifi driver be sure that you installed is rigth driver otherwise, downloa from the hp website the correct driver... as long as your wifi is working driver installation only the problem thats why you can't use it....
try to remove then install again the driver
http://welcome.hp.com/country/us/en/support.html
click the autodetection to detect your system model then select the operating system , download it
Sep 07, 2009 | Computers & Internet
Compaq parcerio 2000 laptop web connection light will not come on
did you refer to the wifi light? actually wifi radio receiver is a manual thing and you should turn it ON and OFF manually. Im not sure with the model you described but try to look for a slide or push button with the wifi icon (an antenna with 3 waves). then try to see if the wifi led is lit. Another way, if your device is soft touch, then there is no hard press button for it. it will be a combination of FN + a function key (look at the function key with the wifi icon)
Sep 01, 2009 | Compaq Presario M2000 Notebook
I have a compaq presario c700 that has the WLAN disabled and it wont turn on i need help getting it on to find my routor it was working 2days ago now its not any help i have compaq c795tu laptop and my...
in very laptop there is a switch button that determines if your wlan is on or off. Try finding it and switch it to On. I hope this will help you,, if it doesnt work let me know.
May 30, 2009 | Compaq Presario 700 470024-192 Notebook
Wifi detecting Issue
I have a similar Compaq model - this may be because you do not have the WiFi switch enabled on the front of the laptop - if you look below and to the left of the touchpad there is a "slide" switch that needs to be lit up "blue" (at least that's the color on my model) - when this switch is slid to the right, WiFi is then enabled. Hope this helps.
Apr 09, 2009 | Compaq Presario C700T Notebook
Hello, sir LT is Compaq prasario V6307 TU,have sound & WiFi prob.
Hi! For Wi-Fi you have to check weather the Wi-Fi switch is off or not ,there is small switch at side off laptop.
For sound you have to check the drivers
Mar 21, 2009 | HP Compaq Presario V6000T Notebook
HOW TO START WIFI SERVICES IN COMPAQ PRESARIO C700
hi , r u using win xp or vista, if u r using win xp , then its one of the compatiblity issue of this notebook with win xp. wifi will work but the led will always be red.
sunder singh
May 18, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Evo N610C Notebook Logo
130 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
