Question about Ascaso Dream Espresso Machine
Heat the temp gauge is only going up to under 250 them dropping back down.... I just got this. I read the reviews, and there is supposed to be a lot of crema but there is no crema and I am using a new can of ground lavazza. I was so excited to finally have a great machine and now so disappointed.  I think the crema problem is the lack of heat, although the steaming element is working....
Hey Nashville,
I have a few suggestions/questions for you. I've had the Innova(Ascaso) Dream for several years now and use it at least twice daily. I would trust your own senses before sweating the gauges too much. If you're really worried about it being a temperature problem, my first question is whether or not the espresso is actually hot when it comes out.
But my best guess is honestly your beans and grinder (or lack thereof). The problem with using pre-ground beans is that even on the day you open the can, they won't be nearly as fresh as truly fresh ground beans you grind yourself. And the problem gets dramatically worse every day after they are opened.
The key to a thick, crema-laden espresso is very fresh beans that you grind right before making your espresso. You can certainly confirm that the machine is working with any old coffee grinder and a bag of *really* fresh beans from a local roaster.
You really need all the oils that come with really fresh-roasted and fresh-ground beans. And the beans really need to be ground very fine for espresso.
I keep a can of pre-ground Illy decaf beans around for the rare occasions I need to make a decaf, and it's like night a day between that and what I drink daily.
If you try the fresh beans and grind them yourself and can see the obvious difference, then you may want to invest in a good-quality burr grinder (as opposed to the spinning blade kind that most folks use for drip coffee). The reason is that with a burr grinder you can get consistently-sized particles every time. So once you get the setting right on your grinder you can keep pumping out the shots time after time. With a rotary blade grinder you get some big pieces, some little pieces and the water flows through too easily -- or you grind it longer and (1) burn the beans from the heat, and (2) end up with some particles that are just too small -- essentially dust, that will actually clog the process.
So, my best suggestion would be to find a local cafe/roaster and buy a half a pound of beans from them and grind yourself. If you don't have a grinder or want to eliminate a variable, ask them to grind it for you for an espresso machine.
Again, if you can see the difference (and I think you will), then you can consider getting yourself a good grinder.
Tony
Posted on Jan 28, 2009
I have a 02 Grand caravan that has new radiator, termostat, one new fan. the temp gauge goes up to max hot the drops right back down in seconds. what could be the problem?
it could be you have an air lock in the cooling system
remove the rad cap from the rad, start the engine and let it run until the coolant drops (add to fill it back up) or until the coolant boils out of the rad spout.
maybe pull the heat sensor. -replace it OR clean it off, reinstall it.
Mar 12, 2015 | 2002 Dodge Grand Caravan
Temperature gauge reading too low
most likely the sender for the temp gauge or not enough water in the cooling system radiator
Jun 17, 2017 | Jaguar Cars & Trucks
2004 Impala ls temperature dash gauge
fans came late on those car,like 212 and second fan comes on at 224,you reprogram it to come a lot sooner,,other thing is there might be gunk inside the block,and coolant has hard time to pass through,and staying longer than enough in block temp goes high,even tough the radiator is doing it's job,it is just coming out block lot hotter than it suppose to be,and gauge read the block not the radiator
Apr 18, 2017 | 2004 Chevrolet Impala
Temp gauge goes from 199 to 255 then back to around 235 and back up
Could be thermostat, water pump, or you may have a leak from the radiator
Apr 09, 2012 | 1997 Cadillac DeVille
I have a 2001 1.8 lx mondeo.The temp gauge moves to the middle position when I drive around town, but when I go onto a duel carriageway or motorway the gauge drops back to the cold end, whats going on
First thing comes to mind is coolant level.
Temp gauge only measures temp of water...it can't read air temp.
If there's an air bubble that gets to the temp gage...you will indicate a lower temp.
I'd check for leaks...a water pump just starting to weep can cause up / down readings.
After that I'd look at the thermostat.
An experiment to try:
Prior to getting on the motorway, slide a piece of cardboard in front of the radiator and see if temp stays up.
I had a thermostat break in half once in winter...I had to do this trick to get enough heat to run my defrost....but running around in local traffic, it seemed to work fine.
If your problem was just the opposite...I'd be sending you to the lower radiator hose.
Hope this helps a little.
Jul 17, 2011 | Ford Taurus Cars & Trucks
Assuming everything is working properly,where should the needle on my temp gauge be under normal driving conditions?1996 bmw 328i
I would say no more than 210 F, Say you have a thermostat listed at 185, or 195, they open up at that temp, the engine under normal driving will run between 195 and 210, you really don't want to see 250. even though coolant boils at 265+, in a pressurized unit, and some cars are supposed to run that hot, I don't like the idea. Hope this helps.
Apr 10, 2010 | 1997 BMW 328
Overheating/No Heat 2001 Impala
change the thermostat and the temp gauge in the radiator
Mar 03, 2009 | 2001 Chevrolet Impala
Alternator or BCM problem ? Gauges drop
it is not the BCM, go to any Kragen or Autozone parts store, have them test the alt, the test is free
Feb 18, 2009 | 2000 Pontiac Sunfire
I have a 2000 Daewoo Leganza. When I first bought it, there was no heat in car, temperature guage was blowing sky high and shutting down engine. It was discovered that there was engine problems, so that...
You have air in the cooling system, it needs bleeding, this is best done from the heater hoses. you cannot have a heating or cooling sysem that is not pressurised. no water no heater no demister no temp guage
Jan 17, 2009 | 2000 Daewoo Leganza
Ascaso Dream Espresso Machine Logo
317 people viewed this question
Top Ascaso Coffee Makers & Espresso Machines Experts
richie46
ray gallant
Are you an Ascaso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
