Question about Raypak Pool & Spa
Raypak pool heater indicates vnt. How do I fix?
Vnt code
    Top Expert:
  • Raypak Master
  • 6,889 Answers
If vent fan check
Posted on Nov 23, 2017
  • 22 Answers
SOURCE: Raypak FFL Fault Code
the ffl is a false flame sensing when the heater is not in call for heat mode.
Posted on Feb 21, 2009
SOURCE: I have a Raypak pool heater the pilot will lite but the unit will
My Rapak gas pool heater burner will not ignite. I changed the flame sensor and then the main gas valve (on a recommendation of a heating contracter) and after spending almost $300 on parts, I may have not needed, it still will not ignite. The water temp has been around 80 using the solar cover but now with the air temp in the 50's at night and only in the 70's in the day the water is a brisk 70 degrees. We would like run the heater now, so we can use the pool for a bit longer this fall.
Any ideas? Some people told me there is a valve that senses the proper amount of water is flowing around the boiler so it doesn't burn up, is this possiblely the problem that the valve is not opening?
Joe Snyder, Toledo, Ohio
Posted on Sep 09, 2009
SOURCE: Pool heater will not ignite
My heater worked ok , btu made a clicking sound, now it shows a AO error? What can I do I dont have enough money to call a pool man again.
Posted on Sep 16, 2009
john224
  • 1378 Answers
SOURCE: raypak heater. fault cde says (ROL)
Thank you for posting your question here on Fixya.com.
Replacing the roll out switch is an easy do-it-yourself repair. Fixing the problem causing the roll out of the burner flames in the first place is a bit more of a pro job. Something is causing to much heat to roll out the the combustion chamber into the control area causing the switch to fail. You will continue to burn the link until the underlying problem is fixed.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jun 01, 2010
StepehnD
  • 78 Answers
SOURCE: service code ROL
This indicates the flame roll out safety switch is bad. This part is usually mounted right above the burner tray. It is a white ceramic piece with two wiring terminals and an external part that looks like a resistor. This part detects flame/heat coming out from the burner tray. When replacing it, be sure to check for blockage at the burner tray, heat exchanger and the flue if vented with duct work. This is a critical safety device so do not bypass it.
Posted on Jun 19, 2010
How can i fix a model raypak 406A natural gas pool heater with a rollout switch open indicated?
replace but find out why either inproper gas supply which will soot up and overheat and burn that part or if gas is ok then see if wind caused it to roll out then add a wind stack
Aug 17, 2014 | Raypak 406A Digital ASME Natural Gas IID...
Raypak pool heater - error code is "FAN"
In models older than 07-07 it typically indicates a loss of the pilot light.
In models newer than 07-07 it is probably the air switch not being activated, or it has just failed. Check air switch tubing for secure connections.
Oct 03, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Have an error code GVP
You didn't indicate what model heater you have, but here are some of the fault codes you might see. Could it have been GVO? You can download a manual for your exact model at www.raypak.com
BD1 Board failure
EEP Microprocessor error
FAN Blower pressure failure
FFL Flame sensing when pilot and gas
valves are closed
GVC Gas valve closed
GVO Gas valve open
HL1 High limit switch #1 open
HL2 High limit switch #2 open
IGN Ignition failure
ILO Ignition lockout - Propane units only
PRS Water pressure switch open
ROL Heat roll-out safety switch open
SNS Sensor failure, Water temp. below 36°F
or above 110°F
VNT Vent switch open
Aug 03, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
I have raypak pool heater with services code ROL how I troublesho
roll out fuse is open. for starters you have to replace that safety. then find out what caused the over temp situation. clogged venting or heat exchanger, negative down drafts, inadequate combustion/ventilation air, improper air/gas mixtures
Jul 25, 2010 | Raypak 130,000 BTU Propane Gas Pool...
Service code ROL raypak pool heaters p-r-266a-en-c
May 29, 2010 | Raypak 130,000 BTU Propane Gas Pool...
Service light comes on our Raypak RP 2100 pool heater.
this usually indicates a high limit condition.you must first ascertain if you have a component failure or a true high tempature condition.your model has 2 limit controls and they are both located in side panel on water in/out header
Sep 16, 2009 | Raypak Pool & Spa
Heat not firing, read-out indicates "FLO"
you may have a bad pressure switch.if you are getting flow thru the heater and this code is comeing on there are only two reasons.No flow or bad switch.
Jul 06, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pool & Spa Logo
185 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
