Sir, i have a AMD Samptron 2600 supported VIA chipset MOTHERBOARD, when I current my SATA harddisk with m y motherboard , hard disk is not deducted, but my hardisk is ok, becouse I also test my harddisk with another motherboard. then sir who I can solve my this problem?
  • Roberta Smith
    Roberta Smith May 11, 2010
    the setting is in your bios.... you need to change it so it detects a sata drive
    Genius:
  • 1,913 Answers
Change your power cable.
go to bios and load factory defaults.
also check ther esata enabled in bios
Posted on Jan 03, 2009
I have a k8upgrade vm800 motherboard. I want to install a sata hdd for storage only but the bios is not seeing the sata connection. Is there any soloution to make this possible or are the sata connections...
Is the drive initialised ... if not it will not exist on your system.
1.1 Serial ATA (SATA) Hard Disks Installation
This motherboard adopts VIA VT8237 southbridge chipset that
supports Serial ATA (SATA) hard disks. You may install SATA hard
disks on this motherboard for internal storage devices. This
section will guide you to install the SATA hard disks.
STEP 1: Install the SATA hard disks into the drive bays of your
STEP 2: Connect the SATA power cable to the SATA hard disk.
STEP 3: Connect one end of the SATA data cable to the
STEP 4: Connect the other end of the SATA data cable to the
chassis.
motherboard's SATA connector.
SATA hard disk.
Nov 25, 2017 | Asrock K8Upgrade-VM800 Motherboard
I have MSI via k8m800 vt8237r chipset based board and amd athlon x2 dual core 4600 cpu ccan i suppor 1tb sata hard disk
some of the motherboard select the kind of devices that will work for them, try to test your sata hard disk with another system if it work then try to change the board. or get another system that will support your sata. thanks
Jun 12, 2010 | MSI K8MM-V Motherboard
It wont rocognise the hard disk but will pick up everything eslse
Change ide or sata cable.
Also change power cable of smps to harddisk.
Make sure your harddisk set as master with jumper settings.
Read jumper settings on harddisk then set harddisk as master.
Then check in bios.
Change ide or sata ports on motherbord then check.
Nov 17, 2009 | EliteGroup K7S5A Pro Motherboard
How much Hard disk my motherboard D845GVSR will support.
There's not really a limit to how big a harddisk you can support. The only thing that can restrict you is the connection, because, for obvious reasons, you can't connect a SATA disk to an old IDE board, but it seems like you're aware of that.
You can just buy any SATA HDD you want!
May 13, 2009 | Intel D845GVSR Motherboard
Epox motherboard and SATA disk
According to the hard drive manufacturer Maxtor, motherboard host controllers using the VIA and SIS chipsets VT8237, VT8237R, VT6420, VT6421L, SIS760, SIS964 found on the ECS 755-A2 manufactured in 2003, do not support SATA 3 Gbit/s drives. To address interoperability problems, the largest hard drive manufacturer, Seagate/Maxtor, has added a user-accessible jumper-switch known as the Force 150, to switch between 150 MB/s and 300 MB/s operation.[9] Users with a SATA 1.5 Gbit/s motherboard with one of the listed chipsets should either buy an ordinary SATA 1.5 Gbit/s hard disk, buy a SATA 3 Gbit/s hard disk with the user-accessible jumper, or buy a PCI or PCI-E card to add full SATA 3 Gbit/s capability and compatibility. Western Digital uses a jumper setting called "OPT1 Enabled" to force 150 MB/s data transfer speed. OPT1 is used by putting the jumper on pins 5 & 6. http://en.wikipedia.org/wiki/Serial_ATA
Dalius
Mar 30, 2009 | EPoX EP-8K9A7I Motherboard
Change of hard disk from 160 gb ide to 250 gb sata
Hello there.
I checked the specifications on your motherboard from here .
As you can see it does indeed support SATA Hard Drives, as per the page:
SATA Four-Channel Serial ATA supports 4 SATA II devices
Each SATA hard drive uses up 1 of the channels, so you can use a total of 4 SATA drives at once.
Hope this helps.
Jun 16, 2008 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Lost Motherboard Driver CD
Try the unified drivers from VIA arena -
http://www.viaarena.com/default.aspx?PageID=2
They will work.
Jun 08, 2008 | Mercury KVM800M Motherboard
250gb sata hard disk to 845 glad mother board
Hello all. I have the same issue. My MB is 845G [P4 2.4 Ghz] and SATA harddisk I need to install is Seagate 250 GB Baracuda with 3.0Gb/s interface, I belive which makes this HD as SATA II. So for this motherboard should I prefer PCI cards which support SATA II over the supports SATA I [these are cheaper].
Thanks so mcuh!!!
May 12, 2008 | Computers & Internet
Maximum HARDDISK CAPACITY FOR Intel 865GV motherboard
Yes, your board will support 320gb. I am not aware of a limit to how many gigabytes you can have per computer. I currently have 1.5 terabytes. 1500gb.
Apr 22, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Computers & Internet Logo
378 people viewed this question
David Payne
David Payne
