Question about Samsung SyncMaster 175V 17" LCD Monitor
Monitor dark I have a Samsung 175V monitor. The LCD is dark but will work intermittently. When it stops woking, the green power light flashes. When I unplug the video cable from the monitor, a "signal loss" message appears and moves around the screen. I have tried two other monitors using the same cable and they both work. Is the problem with this monitor worth fixing? Are repair parts available and cost effective? Any help will be greatly appreciated !! Thank You !
  • paintba11er Nov 06, 2007
    I have the same problem, and the screen resolution thing doesn't work.. I think that the bulb is out or something like that, but I hope that it isn't that because that costs money to fix... :-\
I had a similar problem with this monitor, mine was dim all the time to the point you cant use it, but the MENU icon was bright as new... also if cable was unplugged the box would float around as normal.... anyway I fixed it by taking it all apart and pushing in the socketed chip.. it clicked like it moved, I also pushed on the variable resistors on the power supply... now it works!!! First time since it quite working long time ago
Posted on Mar 01, 2008
  • Dookie454 Mar 01, 2008
    More info on the Dim/fuzzy problem.. When I took it all apart it did work perfectly, until I put it all back together then it quit working again. After about 2hrs of "playing around" I realized the big metal backbone (visible by removeing the entire rear plastic cover) was causing some type of problem since the monitor would work fine until that part was re-installed. After a couple hours of getting mad and checking for shorts and thinking it was creating electrical interference I noticed the main circuit board was extremely bent.. it was bent down in a corner near a ground post. This ground post was being pushed down by the metal cover. By reinstalling the cover this was causing the ground post to move down a little more, pushing on the board even more... I decided to shorten this post and after I cut it I noticed it was a little bit loose... then I realized it was a multi layer circuit board and the ground attaches to several layers.. not just the bottom... so I re-soldered it with about 1/8" of height taken out of it and NO MORE PROBLEMS AT ALL - EVEN RE-ASSEMBLED. Im pretty sure anybody experiencing a dim screen and/or "locked" auto buttons have this exact problem. I did notice depending on how I wiggled the ground post I would either get a dim screen, locked auto button, or both.
  • 883 Answers
Try running a low screen res at first, like 640 x 480, then gradually build up from there to the advertised max res for the monitor.
Posted on May 29, 2007
Green light blinking
First place to look will be the power supply section, common problems with all LCD monitors.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 14, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
On bootup monitor goes blank and only the green light blinks. Bad monitor?
Possibly. Try it on a different computer and then if it works you know it's a bad monitor.
Dec 27, 2009 | Samsung SyncMaster 175V 17" LCD Monitor
Screen is black
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jun 30, 2009 | Samsung SyncMaster 175V 17" LCD Monitor
Green light just flashes on and off and there is no displ
try to check your screen resolution maybe not compatible to your System. if green flashing there no signal from cpu to VGA cable monitor.
Jun 07, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Dec 19, 2008 | Acer AL1715 17" LCD Monitor
Repair samsung SyncMaster 175v lcd flat screen went black right after it start
usually that is an indication that the back lights on your monitor is not illuminating your screen.... here's a test start up your machine and look at the monitor real close.... or shine a flash light at it... you may see your desktop afintly... which means your monitor may need a new inverter board or possible to change some capacitors on it.
you can also try another monitor just to make sure it is ur monitor which is problematic
Dec 01, 2008 | Computers & Internet
All I get is a white screen
copied from http://www.fixya.com/support/t190380-turn_screen_displays_white
I have a Samsung Syncmaster 175v Mfg Oct '03 displaying the __ White Screen . I removed the screws on the back , removed base stand, separated case with flat screwdriver starting at bottom, unplugged the small wire to the panel menu buttons , removed metal cover from back of LCD. Now you can see the powerboard \ inverterboard combo and the attached video signalboard. Follow the 30 wire plug to the LCD screen, the 30 wire plug goes under a metal panel , remove the 3 small screws securing the panel and you will see the hidden LCD screenboard. Very close to where the 30 wire plug attaches to this screenboard on the Rightside you will see with a magnifying glass a SurfaceMounted Fuse named F1 with a value? of "K". On my LCD the fuse tested with a volt-ohmmeter to be Open or Blown. The right thing to do would be to replace the fuse however I acquired my LCD from a trashcan / dumpster so I stretched a drop of solder connecting both sides of the fuse. Now I do not have the protection from power failures and surges that the fuse could offer but upon reassembly my screen works like new again .
PS : i'm not an expert at anything...x'cept maybe dumpster diving. God Bless
Jan 18, 2008 | Samsung SyncMaster 175V 17" LCD Monitor
Dim Monitor
I had the same problem, took it all apart and pushed on the socketed chip, it made a click noise and it works now. I also pushed on everything including the variable resistors. First time it's worked since it quit working!!
Nov 06, 2007 | Samsung SyncMaster 175V 17" LCD Monitor
Samsung SyncMaster 175V 17" LCD Monitor Logo
189 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
