Cannot program westinghouse tv to work on insight remote
Set up INsight remote with 4 suggested input codes, remote would still not control westinghouse TV
  • 225 Answers
SOURCE: How does one change the video inputs without the remote control?
If you have lost the remote, go to any electronics store and buy a universal one. I have programmed many generic remote controls, and they all work fine for adjusting the video inputs. Not all television sets allow their video inputs to be switched without the remote. Most likely you will have to buy a replacement.
Posted on Jan 08, 2009
MNfisherman
  • 11896 Answers
SOURCE: need code for motorola cable box with a insignia remote
Assuming you have the DRC800 remote:
Codes are 0467 or 1376
You can EASILY program the remote without a key code:
1. Press the "cbl" button
2. Press and hold "setup" button Until red light blinks twice
3. Press 9-9-1
4. Press power button
5. Press chanel up repeadedly until your cable box shuts off
6. Press "setup" button again
That should be all there is to it. You can do the same thing for TV,VCR/DVD,Audio, whatever
It's easier than it looks.
Here is a website with more info if you need it:
http://www.eastlink.ca/cable/support/documents/DRC800_User_Guide.pdf
Posted on Jan 17, 2009
  • 1779 Answers
SOURCE: My Insight cable remote won't work with my Insignia NSLCD3209.
http://www.insight-com.com/help-cable-remotecodes.asp
Posted on Feb 19, 2009
SOURCE: tv code for uverse remote
is it a motorola or sysco stb?
Posted on Apr 12, 2009
SOURCE: can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
Posted on May 08, 2009
How do I turn off a westinghouse tv with a direct tv remote?
Hello Deborah Ingram,
Direct TV remotes have special instructions to "program"
various Television manufacturer's equipment into each of their units. Simply by inputting the appropriate codes the "TV"
Once PROGRAMMED they will operate the set and the "DIRECT" equipment together...
Typically some fine set "MENU" items will not be available... so it is wise the keep your REGULAR REMOTE around for those SPECIAL APPLICATIONS.
24 hour DIRECT contact information is available:
http://www.directv.com/DTVAPP/content/remote_codes2 Remote Control Code Lookup
Dec 26, 2016 | Westinghouse Televison & Video
I need an Insight remote (yes, it's an old remote) TV code for an Emerson LD195EMX...any clue?
There are difference types of Insight remotes. Each might have slightly different codes for your TV. I found the following site that might help you. It will help you step through the programming of your remote. I picked one of the remotes at random and searched for the Emerson LD195EMX and it was there.
This should do the trick for you. The link is: http://www.myinsight.com/Help-cable-digital-remotecodes.asp
Nov 19, 2013 | Emerson LD195EM8 19 in. LCD TV
I just bought the Westinghouse VR-4085DF and tried all the listed codes, but none worked. Any suggestions or other optional codes that may work?
Hello mwhinz, there are currently no codes set up for your TV, what you will need to do is call 1-800-701-0680 or send me a quick email to westytech@westinghousedigital.com to get the FW via email that will allow you to program your remote using different codes other than Westinghouse codes. Please make sure you include the model #, serial #, and TW # all located on the back of the TV. Please rate my answer if it was helpful.
Nov 26, 2010 | Westinghouse 16093 Remote Control
Ram Problem
RESOLUTION To clear the RILOE NVRAM and eliminate the error message, reset the RILOE using one of the following methods:
On servers running Microsoft Windows :
  • Reset RILOE through the Management Agents icon in the Control Panel:
    1. Click Start, Settings, Control Panel, Administrative Tools.
    2. Click on Services.
    3. Stop the HP Insight Server Agents.
    4. Click on Start, Settings, Control Panel.
    5. Click on the HP Management Agents icon.
    6. Click on the Remote Insight tab.
    7. Click on "Reset Remote Insight Board" (reset option will be grayed out if the Server Agents are still running).
Or
  • Reset RILOE using the Remote Insight Setup Utility in the Control Panel (pink icon).
On servers running other operating systems and as an alternative method for servers running Microsoft Windows :
  • Reset RILOE by powering off the server and unplugging the external power connection to the RILOE board and the external power connection to the server.
A permanent resolution is not planned as the Remote Insight Lights-Out Edition (RILOE) is end-of-life and out of production.
Jan 22, 2010 | HP Compaq ProLiant DL380 G2 Server
I cannot briing in a picture. Upper left corner of picture says it is on channel 4...upper right corner "no programs availab le"How do I program TV to bring in a picture.; I am on Insight Cable.
Typically the cable box is the source of your channel programming. If you're getting the "no programs available" you need to find if that notice is from your TV or your cable box. Check the connections from your cable source to the cable box and from the cable box to your TV.
Make sure that your TV is set on the proper source selection. Most Projection TV's have several (ant, cable A, B, DVD etc) check your on-screen menu for which one and make sure the cable is connected to the proper input ports on the back of your TV.
If you disconnect the cable between the tv and cable box and still get the "no programs "...then it's your TV.. but if you lose that warning, then it's coming from the cable box... If after checking your connections, disconnect the power to your cable box and let it sit for 5 minutes and then reinsert the power to the box and see if you get a reset with signal...... If nothing after all this, contact your cable provider to check their signal to your house and also the cable box.... Hope you have quick success on this!
Dec 17, 2009 | Televison & Video
Need 5-digit code for universal remote on DAV-X1
There may be no code in the library of your Insight remote. You may have to try a different universal remote.
Apr 04, 2017 | Sony DAV-X1 System
Jan 08, 2009 | RCA Scenium L50000 Television
Remote code
DirecTV offers a remote code lookup tool, which I just used to find possible codes for my Westinghouse TX-42F430S; its first suggestion (the "most popular" code) didn't work. Clicking the "It's not here" button showed seven more codes, and one of them (11577) worked perfectly. Here is the full list of Westinghouse codes for DirecTV from that tool (as of 11/27/08):
Most Popular Code: 10885
Other Possible Codes: 10889 10890 11577 11282 10451 10000 11092
Nov 10, 2007 | Westinghouse 16093 Remote Control
Remote control code for westinghouse sk-19h210s television
I just tried a Sony code for my Westinghouse tv after reading other sites, and it worked. The code that worked for me was 10000
Oct 21, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
