Question about Freecom (24358) 160 GB Network Hard Drive
Freecom external hard drive classic 2.5
My computer crashed about month ago had re boot now have tried put external drive back on wont load can help cheers I have a Freecom 40GB Hard Drive and cannot load the software onto my new iMac with the original Freecom CD. The Hard Drive had been loaded via the issued Freecom CD on my old Microsoft Windows PC. Many thanks
  • 413 Answers
Have a look here>
http://www.freecom.com/ecDrivers.asp
I can't see any Mac drivers for the drive...
I found this page>
http://freecom-usb-osx.sourceforge.net/
You might be able to get some help here...
Posted on Jul 01, 2009
Missing or corrupted system 32 wont install off windows xp disk
try going to the bios and change the boot sequence for hard drive to cd
put the copy of xp in the external hard drive and reboot the computer
when it powers up it should boot up off the external hard drive
if that works go to computer --device manager and find recovery section
you may also go restore to a previous date and try for a fix from there
go google and get to microsoft and find that file download for xp and install it
if all that works shut the computer down and reboot back to bios and change back to reboot from hard drive
remove the disc from the external hard drive
Mar 13, 2017 | Compaq Mini 110c-1001NR Notebook
Advent 4211-c netbook wont load up???????
Have you tried booting in to a Safe Mode and trying to work from there. You can also try using external DVD/CD drive and hopefully it recognize it. Hope this helps.
Jan 03, 2010 | Advent 4211c Notebook
Freecom Classic 500GB External HDD Power Problemo
hello Dude ! You have to open the case of that harddisk ,sorry and if the wires are cut from there positions u must solder them back , and put the to its rite position .
in short get ur tool box and have fun
bye
Sep 03, 2009 | Freecom (24358) 160 GB Network Hard Drive
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Dec 25, 2008 | Freecom (24358) 160 GB Network Hard Drive
Toshiba Hard Drive Crash
if the datas aleady deleted, then you have nothing to lose. Right ?
What you need is a 2.5 to 3.5 inch IDE ribbon cable connector.
this will enable you to put the drive into an IDE slot on the PC internal motherboard ( primary/secondary )
Unless it,s already 3.5"
boot the computer, see if it recognises the drive. And format it.
then you may be able, to re-fit back into the external casing, and use as an external again.
Mike @ compurepair.
Feb 25, 2008 | Toshiba 120GB USB 2.0 Portable External...
Freecom Classic DVD problem
I had a similar problem with a Sony External DVD Writer. I updated the firmware and all was right again. If you can identify the model of your drive here ----> http://www.freecom.com/firmware.asp?form1=true&form2=true&serie=12600&Manufactures=12600 ----- Then you can download the firmware, update and you should be set. Hope that helps!
Jul 25, 2007 | Freecom Classic (22095) (22095)...
Freecom (24358) 160 GB Network Hard Drive Logo
999 people viewed this question
Top Freecom Computers & Internet Experts
callhow
Level 1 Expert
John Anderson
John Anderson
Are you a Freecom Computer and Internet Expert? Answer questions, earn points and help others
