Question about Steinberg Computers & Internet
Cubase audio problem
Im using cubase.le software for my recordings it now says there is ASIO driver error. and goes like the audio engine could not be started.help me
  • 13,433 Answers
The settings in the cubase le - devices - device setup are not set properly or the driver has been removed from the computer.
Id suggest you remove both the cubase le and the hardware device you use with it, then reinstall the cubase and your device. you may need to set the setting again in the device setup and it should work fine.
Posted on Jan 03, 2009
I've just bought a us-800 and installed everything correctly, including the updated driver and it works with media player etc, and on it's own but when i try to use it with cubase 5 nothing happens! i've...
Steinberg software requires an ASIO driver in order to utilize audio interfaces, whereas Windows Media Player uses a WDM driver I believe. I would start by looking for the ASIO driver for your specific hardware interface (or even use a universal ASIO driver) and see if it is detected then...google should help you find what you're looking for :)
Mar 24, 2011 | Tascam US-800 USB AUDIO/MIDI INTERFACE
Recording on cubase le4 using my tascam us122 mk2
You're probably not recording through your tascam interface. Go to control panel -> sound, and then select the us122 as your default sound device. Close cubase and open it again. Then go to devices -> device setup, and then under your asio drivers, select asio us122. That should solve it
Oct 25, 2009 | Tascam US-144 Sound Card
Edirol not able to record on Cubase essentials
This interface works fine with other hosts but with cubase is more tricky. But you can fix it.
You need to disable the onboard sound card, also use the UA25 Asio drivers, go to programs/Steinberg cubase/ ASIO multimedia setup and you should see the UA25 outports are active and that the sync ref "YES" also that the UA25 Input ports are active. the next bit is a bit of fun select the Advanced options and select Detect buffer size, when thats finished select Check Buffers and Sync, press the start button and the test will run,if everything is ok you should have zero "Sync lost" and zero "Buffer lost"
Depending on how lower you want to get your latency , you may have to tweek the UA25 driver settings and re-run the setup above.
Jan 25, 2009 | Edirol UA-25 External Sound System
It says I can not record pick the asio duplex but i don't know how
What recording software are you using? What version of Windows are you on? The ASIO driver for the Lambda should have been installed when you loaded the software that it came with, and if so there should be a control panel that will allow you to select that. The other option is to use ASIO4ALL. It is a free ASIO driver that works really well for most sound cards and software instruments and recording software like Cubase, Nuendo or the many other programmes out there.
If you need more help let me know.
Cheers.
Dec 22, 2008 | Lexicon Lambda Usb Desktop Recording...
H4 randomly stops recording on cubase le
I may possibly have solved this. I didn't realise that when I log off from Cubase, the ASIO driver returns to the Multimedia ASIO driver, which seems to be the default setting.
Every time I want to record with the Zoom H4 in future I'll need to reconfigure the ASIO driver to the H4 one.
I thought once I'd set the driver, it would remain there every time Cubase booted up. Apparently not.
Aug 28, 2008 | Zoom H4 Handy Recorder
Cubase REcording/Playback Problems
check first the sample rate maybe its to high like instead of 44k. its in 48 96 or something like that so the buffering isnt catching with the recoding . alogn with your lattency configuration must devices are ok in 512 latency.
and also be shure not to be recording directly to tyour external hard drive
in case of plugin overload issue it would not stop recording suddenly it would slow down first with some crackles and then stop or must shure freeze.
so impretty shure its somethin else.
hope it works
good luck
May 10, 2008 | Steinberg Cubase SX3
Lexicon Omega/Cubasele4
I've had this problem and similar ones. Following these steps seems to help:
Starting Cubase before switching on the Omega.
Go to 'Devices' and then 'Device Set-up'. Make sure you're in the 'VST Audio System' part of the menu. Make sure the Omega is selected as the ASIO driver - if not, switch it. Then click on 'Set to Defaults', then 'Apply' and 'OK'.
Or re-setting the Omega sometimes helps too.
It's a pain, though.
Mar 31, 2008 | Lexicon Omega Desktop Recording Studio...
Tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Mar 04, 2008 | Tascam US-144 Sound Card
Computers & Internet Logo
1,798 people viewed this question
Top Steinberg Computers & Internet Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
 Grubhead
Grubhead
Are you a Steinberg Computer and Internet Expert? Answer questions, earn points and help others
