Question about Kenmore 500 6952 Dryer
Kemnore dryer model 110.78532700 wont heat - Kenmore 500 6952 Dryer
2 Suggested Answers
oldTech2332
  • 2341 Answers
SOURCE: kemnore 80 electric dryer:
In addation to testing the element and thermalfuse what ya need to check is both of the thermostats that are on left side of teh housing where the heat element fits into,both of those should have zero ohms resistiance,also should check the cycling t-stat there where the thermal fuse (in the blower housing) be sure to not confuse the thermal fuse which is the blower housing with the thermal cutoff which is on the heater housing that and the high limit t-stat are the ones in the heater housing and are the most likely things making the dryer not heat.
If all above checks to be good, the timer, or the motor is whats wrong causing it to not heat.
GENE
Posted on Sep 20, 2011
Why wont whirlpool duet dryer model WED8300SW1 heat?
Is the dryer gas or electric? But you can also try cleaning the vent tube the pipe that goes outside also the pipe that goes into the dryer it's a good chance it's full of lint.
May 07, 2014 | Whirlpool Dryers
Kemnore
searspartdirec.com
Jul 14, 2013 | Kenmore 64602 Electric Dryer
Kemnore washer wont spin or drain
What is the model number of the unit?
Nov 11, 2012 | Washing Machines
Kemnore 80 electric dryer: dryer spins, light works, heat does not work...used multitester on ohm setting to test for continuity on coil and thermal fuse...both seemed to be fine...back to square zero
GENE
Sep 20, 2011 | Kenmore 63942 Dryer
My ge dryer wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 08, 2010 | GE DWSR483GB Gas Dryer
Wont heat up
change the heating elament this is not hard to do it goes back the same way you take it out thank you for useing fixya
please rate me
Apr 17, 2009 | Frigidaire GLER642A Electric Dryer
Kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Feb 25, 2009 | Kenmore Dryers
Ge dryer not heating
Most likely problem is burnt out heater coils
Feb 02, 2009 | GE DVLR223 Dryers
Where is the fuse?
The fuse is located in the dryer fan/blower wheel cover and is a one time fuse, which means it is not resettable. I did a look up for the kenmore model # that you gave and I cannot find your model listed. If you go to parts.com and do a search for your dryer you will be able to see all the drawings on your dryer. You will be able to find the replacement part # and how to get to it. Test your fuse to check if it is open if it is, then replace the fuse. There is also a temperature sensor on the back wall of the dyer drum (it is a small metal circle close to the exhaust outlet). Sometimes there is simply a build up of fabric softener residue on them that stops the dryer from heating up. Clean the sensor with an alcohol wipe.
Hope this helps and don't forget to get all the lint out of the dryer before putting it back in service.
Jan 27, 2008 | Kenmore 64942 Electric Dryer
Kenmore 500 6952 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
