Question about Optoma MovieTime Digital DVD Multimedia Projector
How to take apart optoma movie time projector to check fan and thermal sensor?
SOURCE: dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
Posted on Nov 03, 2008
SOURCE: Short picture time when starting Optoma HD72 projector
Mine did the same thing. The bulb is used up...replace the bulb. That fixed mine, working great again.
Posted on Jan 01, 2009
vortash
  • 431 Answers
SOURCE: optoma projector switches off after 5 mins
AS regretable as this sounds component failiure was my first thought .. It's not the bulb temp sensor as the fan is opperating and that usually cuts all power .
You may find that as you have a bulb ( usually worth more than the units they reside in ) rather than a repair another unit of Ebay would be a safer and more economic conclusion ... Regards Vortash
Posted on May 10, 2009
  • 50 Answers
SOURCE: Optoma projector overheat issue - fan comes on but switches off
Most projectors have air filters. Yours may need to be removed and cleaned. No air flow = overheat.
Posted on May 28, 2009
  • 12650 Answers
SOURCE: I get the message of fan failure in my optoma hd
first vac and clean vents for proper air flow if still coding with unit unplugged remove cover and check fan for blockage if good and still fan code test fan, if bad fan is replaceable most electronics or some computer stores should have it if u want to diy can use serial&model number of projector or numbers on the fan
Posted on May 18, 2010
Optoma hd73 the temp light is red and wont start fans or light just the standby light on flashing could this be a ballast issue or thermal sensor?
if you projector auto shut down, and Lamp LED Light - Check Lamp - Check Lamp Driver - Check Main Board b. Temp LED Light - Check Thermal Sensor - Check Thermal Switch - Check Fan
May 12, 2016 | Office Equipment & Supplies
MY PROJECTOR TURNS OFF AFTER A COUPLE MINUTES
- Check LED Status
a. Lamp LED Light
- Check Lamp
- Check Lamp Driver
- Check Main Board
b. Temp LED Light
- Check Fan
c. Color Wheel
- Check Color Wheel
- Check Photo Sensor
Sep 03, 2014 | Optoma Hd70 Dlp Hd High Definition 720p...
Why won't my Optoma DV10 projector won't turn on?
On an Optoma DV10 if its not the lamp timer, then it might be a cooling fan that needs replacing. Take out the old one, and look-up its part number online. If you don't feel confident taking it apart, have a qualified person do this.
May 23, 2014 | Optoma MovieTime DV10 DLP Projector
Optoma movie time projector has a vibrating sound
Normally this sound noise is the small FAN inside. Dirty or faulty. You must open the proyector, or go to some shop repair.
God bless you
Jan 25, 2013 | Optoma EP706 Projector Remote Control
Plugged in and turned on automatically said it overheated won't turn on or off
you fan could be bad and needs replaced try putting a a small fan next to the excaust vents than see if dies the same thing, if it does it could be than the fan needs to be replaced or the thermal sensor needs to be replaced. hope this helps
Jun 04, 2011 | Optoma DV11 Projector
Optoma DV10 randomly shuts off completly during a
check the power timer settings and put it to disable setting, Or avoid anything that cover the exhaust, fan if the problem occur get assist to the technician.
Oct 22, 2009 | Optoma MovieTime DV10 Multimedia Projector
Optoma H30 Projector: color banding
Most DLP projectors have a colour wheel. It's usually hard to get at, and you may have to actually remove everything including the optical block from the projector to access it. This wheel turns on a motor just like a fan, and if it gets dirty it can act up just like a fan.
They are expensive to replace, so you might want to try taking it apart and cleaning it out. Add a small amount of 3 in 1 oil to the motor if you can.
Aug 22, 2008 | Optoma H30 Multimedia Projector
Lamp goes out
Check your fans, sounds like a thermal shutdown. The fans are 12vdc with a sense line. Red and black power, blue is the sense line. disconnect the fan connector and check the fan with a 12vdc supply. then check the sense line for signal feedback.
Jan 23, 2007 | Optoma EzPro 756 Multimedia Projector
Optoma MovieTime Digital DVD Multimedia Projector Logo
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
