HP Pavilion ze4300 Notebook Logo
Posted on Jan 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I Have an hp ze4300 laptop. it will not boot up?
Press esc , F2 or F12 it states "starting" each choice but never gets there. Help please!
Ekse
Level 3:
  • HP Master 13,435 Answers
  • Posted on Jan 03, 2009
Ekse
HP Master
Level 3:
Answers
13435
Questions
82
Helped
3983058
Points
38023
Seems the laptop doesn't start up properly, the bios maybe corrupt or you have a hardware fault.
the bios may need to be reprogrammed and parts need to be tested to see what the problem is.
Theres not much we can do about this, you will have to take the laptop to a professional or contact hp for assistance / repairs.
1helpful
How do I get it to go into bios when pressing f2 doesn't work?
Per the internet site, it depends upon the model of laptop. Here are some examples:
Laptops - Access Bios Settings Key
Issue
The most common Access Bios key is the "DEL" button or "F2". This depends on the laptop model, however, and can be confusing if you do not know which key to press.
Solution
Here is a list of laptop models and brands with the keyboard commands / key for accessing the BIOS Setup:
Acer: F1, F2, CTRL+ALT+ESC
ARI: CTRL+ALT+ESC, CTRL+ALT+DEL
AST: CTRL+ALT+ESC, CTRL+ALT+DEL
Compaq 8700: F10
CompUSA: DEL
Cybermax: ESC
Dell Laptops:
Dell 400: F3, F1
Dell 4400: F12
Dell Dimension: F2 or DEL
Dell Inspiron: F2
Dell Latitude: Fn+F1 (while booted)
Dell Latitude: F2 (on boot)
Dell Optiplex: DEL
Dell Optiplex: F2
Dell Precision: F2
eMachine: F2
Gateway 2000 1440: F1
Gateway 2000 Solo: F2
HP (Hewlett-Packard): F1, F2 (Laptop, ESC)
IBM: F1
E-pro Laptop: F2
IBM PS/2: CTRL+ALT+INS after CTRL+ALT+DEL
IBM Thinkpad (newer) Windows: Programs-Thinkpad CFG.
Micron: F1, F2, or DEL
Packard Bell: F1, F2, Del
Seanix: DEL
Sony VAIO: F2
Sony VAIO: F3
Tiger: DEL
Toshiba 335 CDS: ESC
Toshiba Protege: ESC
Toshiba Satellite 205 CDS: F1
Toshiba Tecra: ESC then F1 or F2
Toshiba Notebook [Newer models]:
  • Turn on the computer by holding down the power button while pressing the ESC key
    • The machine will beep, then display:
    • Check System, then press [F1] key.
  • Release the ESC key
  • Press the F1 key
Laptops Access Bios Settings Key
DELL latitude 100l, someone disabled all boot devices then set config / administrator password. Please help
Boot Priority on Dell Latitude 100L
  1. Turn On Your PC
    Have you ever noticed the messages that pop up on the screen as soon as you turn on your PC? These messages tell you a key combination you can press to enter "Setup" or the "BIOS." Watch your screen and see if you can read what keys to press.
  2. Press the Keys to Enter Setup Mode
    If you did not see a message telling you what keys to press, try tapping the following possibilities as you turn on the machine:
    • Esc
    • F2
    • F12
    • F10
    • F1
    After pressing Esc or other key, you will most likely see instructions telling you how to enter "Setup Mode". Follow those instructions.
    tip.gif On some computers, you must hold down the key before you press the power button to turn on the computer. For example, if you are converting a Toshiba laptop to a Linux Workstation, you must hold down the Esc key and then press the power button. The computer then asks you to press F1, and you can then set the "Boot Priority."
  3. Using the Arrow Keys, Choose the "Boot," "Boot Order," or "Boot Priority" Option
    The menu of choices you see will be different for different kinds of computers. Remember that the choice you want is the "Boot" order or "Boot Priority." On some computers, this is called the "Start Up Options" or "Start Up Sequences." You are going to change where the PC will look for boot information when it starts up. (CD-ROM, HARD DRIVE/HDD, LAN, FLOPPY, USB). If you wish to boot from your Hard drive, then select it as your First Priority.
  4. Using the instructions on the screen, save your settings and start up your PC. The PC must boot from the HDD. Regrds
2answers
I have already this message : press ESC to access Startup menu.
You should have the option to press either f2 or f12 to go in to bios
Can't boot up my HP XE4100 laptop
press hard disk and boot the windows
2answers
Laptop HP NX9010 will not boot, Will go to bios, powers off after that.
u must have to detect your hard disk.
check u detect your hdisk in bios settings.
then also try to boot option and select hdd .
3helpful
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Failure to boot
In these cases, I'd strongly recommend checking the RAM to ensure that isn't the problem. If the RAM is fine, then the issue is likely with the laptops motherboard. In which case, it would need to be sent back to the manufacterer.
Bios Access
just press delete button to access bios settings not F2 and escape button.
4answers
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
