SOURCE: replacing cartridges in canon pixma mx 310
Go to this page:
MX310 Support
Click on the "Support & Service" tab. In the "Search Our Knowledgebase" block, type in replace ink and click "Search".
There should be a link at #1 dealing with installing ink cartridges. Click on the link and it will show with pictures and animation how to remove and install them.
Thanks for using Fixya.
SOURCE: i refilled pixma canon mp258, message e, 6 and 1
hi....press reset button and colour or black button in the same time until the error gone...
please vote if this can help you....
SOURCE: my canon pixma mp258, the
I have this problem too...I can see is my ink inside the ink hose is stuck.....can't go in to the ink Cartridge....so that means problem is the ink ...stuck in the middle of the ink hose...if anyone how to run the ink in the ink hose...please help me..=]
SOURCE: my printer canon pixma mp258
Indicator appears blinking lights on the printer " P,O, 8′. That Mean The print head temperature above the specified value. You can replace the ink cartridge or refill the cartridge. Step to resolv this error Step 1 : Turn Off Printer Step 2 : Remove Cartridge Step 3 : Refilling the cartridge Step 4 : Reinstall the cartridge Step 5 : Turn The printer ON If it still does not work you can use the following methods How To Reset MP 258 error 5200 Step 1 : The printer is off and plug the power cord. Step 2 : Press the button STOP / RESET and hold, then press and hold the POWER button Step 3 : POWER button still press, release the STOP / RESET, then press the STOP / RESET 2 times in a state of the power button is pressed. Step 4 : Release both buttons simultaneously Step 5 : The printer will proceed in a while (a while), then the LCD panel will show the number zero (0) Step 6 : Computer will detect NEW DEVICE, Ignore it... Step 7 : Press the power button, then the printer will turn off Step 8 : Press the power button again, then the printer will be ready to use
SOURCE: error code 5200 on canon
Error 5200 indicates that the print head temperature has exceeded the specified value. Turn off the printer and then turn on if error still persist replace Ink cartridge or print head.
