Question about U-Line Wine Captain (2015WC) Wine Cooler
Uline model u-c01175B-00 ice maker - U-Line Wine Captain (2015WC) Wine Cooler
  • 1073 Answers
SOURCE: Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
not familuar with the brand but sounds like one of 2 issues
if it is overfilling making ice cubes larger than normal, adjust the ice maker fill time if it is possible
icemaker fills and cuts off but water valve seeps water after the fill causing the water overfill
one of the 2
Posted on Jun 24, 2008
  • 11 Answers
SOURCE: Uline ice maker
The trough gets refilled on each ice cycle, if it's circulating, then the water supply is adequate.Y
The exact model would be helpful, but you could call 1-800-779-2547 U-Line's tech line
or email OnlineService@U-Line.com for help
http://www.U-Lineservice.com
Posted on Dec 23, 2008
  • 286 Answers
SOURCE: uline ice maker clr2060- makes ice continuously,
This is a problem when the thermistor in your icebin is not being satisfied.Now there is a break in the serial number to find out if you have a thermistor or a mechanical thermostat. If the serial number is before 03 (first 2 digits is the year)and the 2 digits between the dashes is 11(the month) the replace the bin thermostat. If newer then you need to replace board and thermistors.
Posted on May 13, 2009
  • 286 Answers
SOURCE: Ice maker (Uline) just stopped working, not freezing, no noise.
U-line does make compressors as long as its not a r12 system. As far as the icemachine turn breaker off for a couple of min then try it. If same results then it could be a board.
Posted on May 15, 2009
  • 286 Answers
SOURCE: My under counter Uline refrigerator/ice maker suddenly trips GFI
I here this alot. If you have a compressor on a gfi the compressor after awhile would trip it. The compressor start amps is usually higher than the gfi is rated. So you have 2 choices. Replace the GFI and try to find one with higher amp ratings. Or install a normal outlet for your unit. Your code will usually call for a gfi, If it does then replace with a new gfi.
To explain the start amps on a compressor depending on your model could be 10 amps. This is for a split second. However the gfi can become week after time. You can also try to plug the unit into a normal outlet to make sure everything is good on the unit. I believe it is the gfi
Posted on Jun 11, 2009
Uline ice maker parts gasket part no. 3002
Most door gaskets can bought from a roll at appliance parts dealers, or:
www.appliancepartsonline.net
Dec 24, 2014 | U-Line Icemaker
ULine CLR2160S00 was making ice then the icemaking started to slow then none at all had refrigerant replaced last year and everything else seems to be working fine,,, just no ice
Does the ice maker get water? Could the fill line be blocked? I found on my freezer ice had formed at the end of the tube and once I removed the ice it has worked fine since.
Jun 22, 2011 | U-Line ULine CLR2160S00 Echelon Series 15"...
My uline keeps running and soda in cans freeze. Thermostat setting is at lowest but I also tried midway. Model ULN-CO75FWH-00
your thermostat is bloked or didn't see the reeal temperature, it must be replaced whit similar new one.
Feb 21, 2010 | U-Line Uline Origins Series...
The bin arm on my Uline Model 402 ice maker broke off. I have a replacement bin arm. I took off the front plate of the ice maker unit, but am unable to thread the bin arm all the way through the bin arm...
1st remove the icemaker from the unit. Then take the faceplate off.You might find that the support housing is fighting you.You should be able to move the arm into place as long as the icemaker is out.
Jul 19, 2009 | U-Line Uline Origins Series...
Uline icemaker compressor runs very hot - slow ice production
if the ice production is slow first try to set it on a warmer temperature. Now if its frosted up then you will need to defrost it. Also check the fan to see if its running. if yes is the condensor clean? If yes then check temperature in bucket. 10 to 15 degrees is ideal for this model.
Jul 04, 2009 | U-Line Icemaker
Wiring came unplugged need wiring scematic for uline ice maker
wiring diagram is on the back of the machine. If you have clear ice maker it may be on the back of the front plate.
Jun 01, 2009 | U-Line Uline Origins Series...
The door to my under the counter uline frig/icemaker doesnt shut good..It wont stay on the bottom hinge..
The hole on the bottom of the door might be cracked. What model is it? you might need a bushing for the door.
Mar 30, 2009 | U-Line Uline Origins Series...
Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
Nov 04, 2008 | U-Line Icemaker
Open Questions:
See all U-Line Wine Captain (2015WC) Wine Cooler Questions
U-Line Wine Captain (2015WC) Wine Cooler Logo
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
