Hi, My Laptop IBM ThinkPad is unable to boot. Giving FAN ERROR. Seems to be problem with bios because the fan is working. Any service center in pune?
    Genius:
  • 1,913 Answers
Reset your bios to factory defults.
Posted on Jan 03, 2009
While trying to boot my IBM R51e Laptop (purchased in 2006), all i got is black screen with only power supply LED "on" (on below monitor side, LEDs notification area), no other LEDs are...
my conclusion is you have a BIOS failure.. that symptoms is typically a BIOS problem. just like mine. bring your laptop to the IBM service center.
Jul 10, 2011 | IBM (10l1433) (  10L1433)...
Evey time I try to boot my ibm thinkpad type 2647 nothing happens and the fan keeps going from high to low any ideas?
Whe you switch on the laptop please go to Bios and check the hard disc is dictacted or not. Other wise when you switch on the computer please press F11 button 4 to 5 times and select the boot option from the hard disc. If it not working need to show service center.
Sep 23, 2010 | IBM ThinkPad T23 2647 Notebook
When booting up the screen displays FAN ERROR
Is the fun running? you can first confirm that before you alter anything in the Bios. touch on the fun air exit point you will feel it if its running.
Regards
May 05, 2010 | IBM ThinkPad T30 2366 Notebook
IBM T42 gave fan error, replaced and can not get it to reboot
make sure the fan is pluged in correctly and you didnt unplug anything else such as memory or etc or bump the cpu... did you put any thermal paste on the cpu when you put the fan on it? its needed to bond the too together to make a better cooling system there maybe a setting in your bios to disable fan monitoring or cpu temp etc have to look at your bios to see
May 27, 2009 | IBM ThinkPad T42 Notebook
IBM T42 gives Fan Error message and stops
The fan may be faulty or clogged with dust.
Check the fan to see f it spins freely and remove dust from the heatsink fins and fan assembly.
The specification in the manual for the T40 series shows the largest hard drive is 80 Gb.
It may be possible to install a larger hard drive, but check with Lenevo first.
May 25, 2009 | IBM ThinkPad T42 Notebook
Laptop fan does not engage when hot, but spins up upon boot
hi this is due to the fan settings in BIOS Program has been not correctly mentioned,so u cant find the fan setting in BIOS Program reset the BIOS Program it will helps u to activate the fan setting.when u got the fan setting u can solve the fan problem in ur laptop.In ur laptop fan is giving u the problem but the BIOS setting is creates the problem reset BIOS Pgm and then u can fix the fan problem without changing the fan again.
Thank u
Dnt Forget to rate me
Apr 21, 2009 | IBM ThinkPad A21m 2628 Notebook
LPT1 not working
Hi looking at your description it seems more like a drive error as a opposed to lpt1 problem, I've never known a lpt1 port to stop boot.
Sata drives are notorious for bad connections, could it be that the connections to your drive have worked loose?
I hope this helps, if not please let me know thanks.
Jan 05, 2009 | IBM ThinkPad T60 Notebook
IBM Think pad T21 Notebook can not boot!! Help please
Run IBM BIOS Setup
Utility to reset the time and date.
Jul 17, 2008 | IBM ThinkPad T21 Notebook
ERROR 0271
Are you a computer whizz? (do you know a lot about computers like me?)
Could be the Cpu fan (Central Processing Unit)
That could be lethal to the laptop.
Just as well it's a IBM other wise . . .
As for the error it means the time and date are not set.
soloution: run the bios setup utillity to reset time and date.
1358
Jun 25, 2008 | Acer Aspire 5610-4648 Notebook
T30 fan error
Well, the fan is either unplugged from it's socket, froze up, or completely clogged with dust, etc and is giving the bios reason to shut down.
Also tho, tell me, does the time and date keep needing to be reset?
Could be a cmos battery. Some of the older thinkpads were like that, although my T30 has never shown this problem.
Good luck
Oct 15, 2007 | IBM ThinkPad T23 2647 Notebook
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
