Question about HP LaserJet 2420 Printer
HP 2420 Faded Print outs
Please can you help resolve an issue I have with a HP 2420 laserjet Printer. The printer pages are grey and faded despite having replaced the toner cartridge.
Thanks
    Sergeant:
  • 366 Answers
Check (and remove) the "economode"in "Printer Preferences" (right click on Printer applet) normally in "Paper /quality" Tab
Posted on Jan 03, 2009
HP Laserjet P3015 fade
This could be because of few reasons, The Ink powder is not rotating inside the drum to give you the correct output.
Remove the Toner and Shake it a bit. Try to print.
Check for Firmware update available for your printer. There are Fixes released for known issues.
Click on the link below to find solution for all Print Quality related issues for your printer
HP Laserjet Print Quality Solution
Hop this Fixes the Issue
Regards,
Sean
Apr 22, 2013 | HP Laserjet P3015X Printer
The IT Dept. at work gave me a Laserjet 2420. When I print something, it appears that ink is stuck to the roller and will reproduce faded lines further down in the page. I would describe it as the toner is...
Faulty cartride or fuser causes ghoost image in print outs. Primary level:check with another cartridge. Secondry level: Remove fuser assm out, check teflon sleeve surface deposited with toner?. replace teflon sleeve if available if not replace fuser assm. In fuser modes we can increase/decrese the temparature of fuser.
Note: only service engineer can replace the teflon sleeve.. user not advisable
Sep 21, 2011 | HP LaserJet 2420 Printer
Sir ihave printing problem when i print a page on the left side margin impression faded there is some faded portion of teflon roller crieate this problem please assist me how to solve this problem ...
sir ihave printing problem when i print a page on the left & right side margin impression faded please assist me how to solve this problem regards KULDEEP SINGH BISHT
Aug 09, 2010 | HP LaserJet 1020 Printer
LaserJet 2420 Printer: hp 2420n 13.20.00 jam inside rear door...
i have 2420 dn printer..printer reddy mode the power on...but not initlizing...13.20 paper jaming error coming but paper is not jam..hw to resolve
May 06, 2010 | HP LaserJet 2420 Printer
Printed pages contain contain traces of (faded)
I solved this by indicating I was using Recycled paper in printer properties.
Gisele
Jan 08, 2010 | HP Color LaserJet 2600n Printer
Printer name :hp Laser jet 1300 the print
this printer prints a multipage document on 1 page everytime
Oct 21, 2009 | HP LaserJet 1300 Printer
Hp 2600n faded printing
you need to take the scanner out (not very easy to do)unless you are a printer tech.
and clean the mirrors.
Sep 14, 2009 | HP Color LaserJet 2600n Printer
Hp laserjet must manually push button to print
Please print a configuration page from the control panel of the printer
- Menu > Information menu > print configuration.
- Check for paper handling details.
Following setting should reflect.
Tray 1: Any size / Any Type
Tray 2: A4 size / Plain Type
If the above settings are not reflecting in the configuration page, please change accordingly by browsing on the control panel of the printer to:
Paper Handling Menu >
Tray 1 Size: Any
Tray 1 Type: Any
Tray 2 Size: A4
Tray 2 Type: Plain
Let me know if that helps to solve the issue.
Regards,
Nikhil.
Jun 14, 2009 | HP LaserJet 2420 Printer
Hp 2420 vrtical line in page
This issue can be due to fuser. I am sure you have changed the toner cartridge.
To confirm its a fuser issue, please perform the following:
1. Try printing a configuration page from tray 1, pull the top cover, as soon as the media is 60-70% inside the printer.
This would stop the paper before reaching the fusing assy.
2. Remove the paper and check if the line exist.
If exists, fuser is not faulty.
If it does not, then transfer roller, laser/scanner assy is faulty
- If fuser is faulty, perform the cleaning page as following
1. go to configure device > print quality > create/process cleaning page
perform cleaning page 5-6 times, however, if the line is due to fuser, then fuser needs to be changed.
Let me know the next update.
- Nikhil
Nov 21, 2008 | HP LaserJet 2420 Printer
LaserJet 2420 pdf printing issue
Hi within the driver printing preferences you are able to change the graphic mode if you do this it may help. Without seeing what you are trying to print cannot give a accurate answer so try this and get back to me if this doesn't work
Hope this helps you and please rate me
Thanks J
Dec 04, 2007 | HP LaserJet 2420 Printer
HP LaserJet 2420 Printer Logo
516 people viewed this question
Seeker5211
Seeker5211
