Question about Acer Aspire All-in-One Desktop PC - Silver (AZ3100-U3072) (2771498)
Opening Acer Aspire AZ3620 All In One case,for a memory upgrade?
eagle338
  • 4889 Answers
SOURCE: memory upgrade
First thin you have to remember is if you want to have to memories in parallel...Then the new one should be of the same size and frequency(ex:133Mhz,533Mhz..etc.,)Then folow these steps:
  1. Turn off the computer and remove all power cords from the computer system.
  2. Locate the panel used for access to the memory modules. This is generally located on the bottom of the laptop computer. Refer to your laptop instruction manuals for locating the panel.
  3. Remove any screws that the panel in place and place somewhere safe to prevent losing it.
  4. Remove the panel from the laptop and set aside.
  5. If replacing or upgrading an existing memory module, remove the memory modules by undoing and module clamps and gently lifting the edge of the module to a 45-degree angle and then pulling the module out of the slot.
  6. Align the notch of the memory module with that of the memory slot and gently insert the module into the slot at a 45-degree angle.
  7. Once all the pins are in the slot, gently rotate the module down flat until the clamps lock into the module into place.
  8. Replace the memory access panel onto the laptop computer.
  9. Replace any screws or fasteners that hold the panel in place.
  10. Replace the power cord and power up your computer system.
Posted on Oct 13, 2007
  • 244 Answers
SOURCE: I want to upgrade memory of my laptop acer aspire 1691 from 512 to 2gb
it's easy to add memory.
Just open the door on the back of your laptop.
You can see 2 slots of memory.
Make sure that you know the type of your memory for your laptop. I believe is DDR (not DDR2).
Posted on May 08, 2008
Pyrhyc
  • 2028 Answers
SOURCE: acer aspire 7003wsmi
The memory is located under a panel on the bottom of the machine. The chips are very easy to replace. Go to the link bellow, it will tell you the max memory and the frequency that your machine will hold. The frequency is very important, it is the type of memory and will be in either pc or mhz, ie.. pc2700, pc4200, pc 5300 etc.. or 266mhz, 333mhz, etc.. Make sure you buy the right frequency memory or it won't work.
Posted on Jun 25, 2008
  • 21 Answers
SOURCE: how do i upgrade memory
How much memory you have right now, this model does have capability of upto 1GB , If you are running Vista on your computer try inserting a blank 1GB USB flash drive, and You will have 1 GB additional memory.
Posted on Jun 29, 2008
Pyrhyc
  • 2028 Answers
SOURCE: how to upgrade memory ON
Use the link bellow to find the max memory and the type of memory. The memory chips are located under a panel on the bottom of the machine.
http://patriotmem.com/
Posted on Jul 11, 2008
NEED MANUAL FOR ACER ASPIRE aZ3620-es30p
go to acer site and find youir model manual
Mar 13, 2014 | Computers & Internet
Can't turn on webcam on ACER aspire AZ3620-ES30P
  • Click "Start." Click "All Programs." Open the "Crystal Eye Webcam" folder. Click "Acer Crystal Eye Webcam" to launch the webcam and turn on the camera. If "Acer Crystal Eye" isn't available on the Start Menu, go to "Acer," then click "Acer OrbiCam."
  • Click the drop-down menu on the toolbar to change the resolution. Click the gear icon to change the settings.
    Click the camera icon to capture a photo. To turn off the Acer webcam, click the "X" button on the top of the window.
    Mar 13, 2014 | Acer Computers & Internet
    Can I hook up a netgear PushtoTV adapter
    Unlikely. This uses WiDi which tends to be found on supporting laptops.
    Nov 10, 2013 | Acer Computers & Internet
    Manual Acer Aspire AZ3620-es30p
    Will this model hook into my can't use hdmi or I just can't find it all I can see is USB
    Feb 04, 2013 | Acer Computers & Internet
    Need abetter graphic card for acer aspire 5251
    in Acer Aspire Series is using Intergrated Graphic Card.
    that mean if you wanna Upgrade your Graphic Resolution,
    you have to set to a bigger shared memory/RAM for Display Graphic Card/VGA memory from BIOS Setup.
    for example if you using RAM 2Gb, and you can make your VGA(Video Graphic Adapter) to 1Gb.
    But in My Computer Properties the RAM will Show only 1Gb.
    Because another 1Gb of RAM you've use for VGA.
    you can check it from dxdiag.
    (for opening dxdiag > Click Start > click RUN... > type dxdiag > and Oke/Enter)
    Jan 07, 2012 | Acer Computers & Internet
    HOW do you open an acer one to access memory slot and hard drive?
    Hi James, Here is a step by step video tutorial.
    Enjoy your new upgrades.
    Oct 22, 2011 | Acer Aspire One D255-2670
    What is the maximum memory I can install
    Memory Upgrade for Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop, the Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop takes the Memory Type, and comes installed with 0MB of Memory. You can upgrade your Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop to up to a maximum of 4GB Memory, the system has 2 (2 banks of 1) to install Memory, already with 0MB standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
    Jul 08, 2010 | Acer Aspire 5630 Notebook
    Acer aspire one AO751h keeps freezing is there any solution?
    let me ask you if all you have on your system is much and you like opening much application at the same time then if all this are found positive then all your work will keep on freezing ok.
    Solution is this upgrade your memory and probably your harddisk space so as to allow all this free flow ok.
    Mar 11, 2010 | Acer Aspire One PC Notebook
    Acer Aspire All-in-One Desktop PC - Silver (AZ3100-U3072) (2771498) Logo
    221 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Steve Sweetleaf
    Steve Sweetleaf
