Question about Manfrotto 503HDV Head and 351MVB2 Tripod Video Kit
How do I release a Manfrotto 501HDV head from a tripod
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
Tip the tripod upside down, on the bottom plate where the head attaches there are 3 screws... they need to be loosened, and then the head will spin off.
Posted on Jan 21, 2015
randy320sgi
  • 121 Answers
SOURCE: base plate release lock
gavinobrien2,
Hopefully the camera isn't mounted. If the plate is bound because it is misaligned if may take some serious twisting. If it was cranked really tight just back it off carefully, you shouldn't need any type of lubricant or solvent based for seized or rusted metal parts, the release is sort of a cam it can get dust, grit or decal residue that might cause it to be tough to open. If the camera isn't a factor you can spray some compressed air (the can type for computers) which is super cold, directly on the cam to shrink it slightly then give it a crank - wear gloves and don't spray your fingers it can freeze your skin. If you are not comfortable doing that take it in to a camera shop and they may just do it for you. (tip - establish a good relationship with a reputable local camera shop by supporting them and buying your equipment from them, they know you and are willing to help with what they can or suggest the right equipment for you)
randy320sgi
Posted on Jan 12, 2009
  • 24 Answers
SOURCE: Breakdown Manfrotto 3265 ball head from 190xb tripod
IT SOME TIMES TAKES A LOT OF EFFORT TO SEPARTE THE HEAD FROM THE TRIPOD. MAKE SURE YOU REMOVE THE 3 LITTLE SCREWS FROM BELOW THE HEAD, AND MAKE SURE THE TRIPOD AND HEAD ARE NOT COLD. IF THEYA RE WARM THEY WILL SEPARATE EASIER.
Posted on Jan 30, 2009
SOURCE: Removing Tripod head from center post on Manfrotto Modo 785B
I have the national geographic branded version. Here is how you remove the head.
(1) remove the center post from the tripod
(2) lock the ball head with the trigger lock
(3) grasp the body of the ball head with one hand and the center column with the other.
(4) turn counter clockwise.
If you're intending to replace the ballhead, be warned that the thread is non-standard. I have a new "plug" with a standard 1/4" thread made for free by the machinist at my job. I don't know how you would go about adapting it without such a capability.
Posted on Feb 06, 2009
  • 685 Answers
SOURCE: my fluid video tripod head is stuck to the tripod.
Make sure you are loosening the 3 grub screws under the tripod head to release it from the tripod center column. there are the 3 slotted screw heads under the grey part of the tripod head. Make sure you back them all the way out before you start to loosen the head.
Posted on Jan 30, 2010
tscmusa
  • 95 Answers
SOURCE: which one is better 055xB or Manfrotto 3021
Manfrotto makes good quality tripods,never had a problem w a Bogen or Manfrotto product
Posted on Mar 26, 2010
How should a Manfrotto fluid head be stored? Up or down
Alisa
If you had a true 'fluid' head (which no manufacturer has made since the 70's), you would have stored it upside down with all controls 'unlocked' and at room temp.
As the Manfrotto 501HDV uses nylon washers, sandwiching ball bearing races to produce the variable drag ..., as long as you store it with the all the controls 'unlocked' it will not matter if it is upside down, right side up or laying on its side. The only other thing you really need to remember is to ensure that the counterbalance spring is released / set to lightest setting (this is the star shaped know located below the camera platform on the heads main body!!!
If this is not loosened off the spring will stretch and then not perform properly in the future!
Peter
Nov 12, 2013 | Manfrotto Photography
How should fluid heads be stored?
Alisa: With all 'video tripod heads'...., regardless if the are the original 'true' fluid heads (that actually used a liquid (oil) to achieve 'fluid' type movements) or a modern professional 'fluid' head (that actually uses a clutch mechanism like a cars transmission) or a fluid effect head like the Manfrotto #501HDV (which used nylon discs sandwiching a ball bearing race)...., always store with the pan and tilt mechanisms unlocked!!!! This means the camera platform should be positioned in the 'rest' position (not tilted forward or backwards), also ensure that any counterbalance mechanism is released so as to eliminate strain on the internal mechanisms!!!!
If you remember to do this and don't overload the head..., you will extend the life of your gear significantly
Peter
Nov 12, 2013 | Manfrotto 501HDV Pro Video Head Tripod
Friction control broke
Go to www.manfrottotripodparts.com, they might have a part to fix it. Or you could send it in and they could repair it for you.
Jan 28, 2013 | Manfrotto 501HDV Pro Video Head Tripod
Manfrotto 501 friction head assembly
Give us a call here at Spartan Photo Center and we might be able to help you if you can describe you issue a little better:
864-583-6835
Amanda
www.spartanphotocenter.com
Dec 08, 2012 | Manfrotto 501HDV Pro Video Head Tripod
How to mount plate
You have to loosen the tension knob on the right all the way, and then push in the red (plastic) button on the left as you slide the plate in.
Amanda
www.bogentripodparts.com
Nov 21, 2012 | Manfrotto 501HDV Pro Video Head Tripod
Lost quick release clamp on tripod (manfrotto)
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I've seen.
Jun 28, 2010 | Manfrotto Camera Supports 3405BN JR. BLK...
I have a Manfrotto 3265 tripod head. The quick
You can get the quick release lever seperately. Check the website for the part needed.
http://bogentripodparts.com/parts/head3265.htm
Hope this helps,
Andrew
Feb 17, 2010 | Bogen Communication Bogen Manfrotto 3265...
My fluid video tripod head is stuck to the tripod. help! note: i have the manfrotto 503hdv head, and the legs are actually manfrotto 055CXPRO3 i have tried tightening the head controls. i have...
Jan 28, 2010 | Manfrotto 503HDV Head and 351MVB2 Tripod...
Who do I contact to get repair of quick release's on 519 tripod
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I’ve seen.
Jan 18, 2010 | Bogen Communication Bogen / Manfrotto 519...
Bogen Tripods, changing heads.
I searched around and all I can find is this: http://www.manfrotto.com/Jahia/site/manfrotto/pid/2477
Jul 02, 2007 | Bogen Communication Bogen - Manfrotto...
Manfrotto 503HDV Head and 351MVB2 Tripod Video Kit Logo
241 people viewed this question
Top Manfrotto Photography Experts
JP Services
JP Services
Mitch Davis
Mitch Davis
Are you a Manfrotto Photography Expert? Answer questions, earn points and help others
