Question about Zyxel P870HW51A v2 VDSL2 Wireless Gateway 1 x VDSL WAN 4 x 10100BaseTX LAN IEEE 80211bg 54Mbp Router
Blinking power button problem for Zyxel P870HW51A v2 VDSL2 Wireless Gateway 1 x VDSL WAN 4 x 10100BaseTX LAN IEEE 80211bg 54Mbp Router
Upgrade did not work. Now the power light keeps blinking. What can I do?
3 Suggested Answers
SOURCE: ZyXEL p660HW-T1 V2 Blinking lights won't turn to steady on.
sdaewedqewq
Posted on Oct 24, 2008
garethmt
  • 116 Answers
SOURCE: ZyXel Prestige 660HW T1, power light blinking
It's dead, sorry. You could TRY removing the power cord, holding in the reset button and powering it back up with the button HELD DOWN for at least 10 seconds. That will factory default it, so I hope you know how to program it all again! (please don't contact me and complain if you don't...)
Posted on May 27, 2009
ZYXEL G4100 SYS LIGHT NOT GETTING STABLE
The WAN cable may be too long.
Your ISP may have issues.
The router may be getting too hot due to inadequate ventilation.
Mar 26, 2014 | Zyxel G-4100 v2 WirelessHot-Spot Gateway -...
Tip
HOW TO CONFIGURE STATIC ROUTING ON LINKSYS ROUTER
Show Routing Table button will open a chart displaying how data is routed through your LAN. Use the example below on how to configure a static routing:
STATIC ROUTING:
192.168.2.2 192.168.1.2
ROUTER C ----------------- ROUTER B ----------------- ROUTER A--------------PUBLIC IP ADDRESS
192.168.3.1 192.168.2.1 192.168.1.1
ROUTER A: Gateway Mode ROUTER C: Router Mode
1STENTRY 1ST ENTRY
DESIP: 192.168.2.0 DES IP: 192.168.2.0
SM: 24 SM: 24
DG: 192.168.1.2 DG: 192.168.2.2
HOP COUNT: 2 HOP COUNT: 3
INTERFACE: LAN INTERFACE: WAN
2NDENTRY 2ND ENTRY
DESIP: 192.168.3.0 DES IP: 192.168.1.0
SM: 24 SM: 24
HOP COUNT: 3 HOP COUNT: 2
ROUTER B: Router Mode
1STENTRY
DESIP: 192.168.1.0 WAN IP: 192.168.1.2
SM: 24 SM: 24
DG: 192.168.1.2 DG: 192.168.1.1
HOP COUNT: 2 DNS: DNS of 1st router
INTERFACE: WAN
2NDENTRY
DESIP: 192.168.3.0
SM: 24
DG: 192.168.2.2
HOP COUNT: 2
INTERFACE: LAN
1stRouter must be set on Gateway Mode
2ndRouter must be on Router Mode
Use Static Routing
Select Entry
Destination IP = IP Subnet of the 1st Router
Subnet Mask = Subnet Mask of the 1st Router
Default Gateway = Interface IP
Hop Count = 1 + n
Interface= Connection to the 1st Router
Hope this help everyone.
on Jan 26, 2010 | Linksys Wireless-G WRT54G Router
I need to access CCTV over internet.I am using Zyxel router (model P600R T1 v2) which having a static WAN IP provided by ISP.Can please guide me on the steps.Thanks.
first you need to forward TCP ports in your router pls write down which TCP ports used for video , audio and control in your DVR and configure to forward this tcp ports in your router
it can be do one step using disable the DMZ and it will make less sequrity in your internal network
Apr 11, 2013 | Zyxel Prestige 660HW Wireless Router...
Zyxel P660HW-D1 Router. Which settings need to be changed to turn it into a repeater and connect with my main broadband router.
Can't use a router as a repeater in a wireless sense. You could set it to AP mode and run an ethernet cable from a lan port on your other router to the WAN/uplink port on the Zyxel. If it doesn't have AP mode then you could have it in gateway mode run have a different subnet on the Zyxel with DHCP.
Oct 29, 2011 | Zyxel P660HW-D1 Router
I have p-660hw-t1 .but for 3 days i failed to login on console or firmware. and also reset the device and with password 1234 but couldnt login. now wht should i do?
try doing the reset again
To perform a factory reset: 1) Power off the router, 2) Hold down the recessed reset button on the rear of the unit (keep it held down) 3) Power on the router with the reset button still pressed down. 4) You will notice all the LAN lights flash at the same time which will indicate that the router has reset - this takes up to 30 seconds. 5) When all the LAN lights do flash simultaneously you can let go of the reset button. Your router is now reset. The default IP address is "192.168.1.1" and the default password is "1234".
Mar 10, 2011 | Zyxel P660HWD1 v2 WirelessADSL2+ Gateway...
We have been using the zyxel G 4100 v2 for 3 years. Last week we found out that we could no longer use our web based password to monitor our accounts. Did someone hack our system. How can we recover our...
Just reset it! At the back of the router is a small hole with th word "RESET".With a toothpick or some like press gently for 30 seconds and wait for the router to start up again.Log in to http://192.xxx.xxx and start a new configuration.
Jan 01, 2011 | Zyxel G-4100 v2 WirelessHot-Spot Gateway -...
How to configure 4 Lan + 1 Printer +internet connections
If all your connections are wired, you can use one of the three following solutions.
1. Purchase a router with more then 4 LAN ports on it.
2. If the printer or any of the computers have a wireless network card, then purchase a wireless router and simply connect 4 LAN cables and 1 WLAN.
3. Purchase a hub. Connect 3 computers to the first 3 LAN ports on the router; connect the hub to the fourth LAN port and then connect the last computer and the printer to the hub. In essence both your computer and the printer will share the same IP address (the IP given to the hub) and they should work.
In any of these situations, connect the internet connection to the WAN port of your router.
Thanks,
Pat
Apr 02, 2010 | ASUS RT-N13U IEEE 802.3/3u IEEE 802.11b/g...
Serial number overlap after factory reset
There is a work around for this issue. The account logs can be sorted on date, which puts the latest entries on top of the pile, irrespective of the S/N.
Jan 05, 2009 | Zyxel G-4100 v2 WirelessHot-Spot Gateway -...
Zyxel P870HW51A v2 VDSL2 Wireless Gateway  1 x VDSL WAN 4 x 10100BaseTX LAN  IEEE 80211bg  54Mbp Router Logo
112 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
