Question about Whirlpool Cabrio Platinum High Efficiency Gas Dryer with Steam cycle
To change the drying settings from the default settings on my whirlpool cabrio platinum gas dryer
  • 18 Answers
SOURCE: Autodry cycle never stops
you need to replace a t-stat. one of your t-stats are blown. im drawing a blank but its the one with four terminals on it
Posted on Feb 04, 2007
  • 14 Answers
SOURCE: whirlpool gas dryer #LGR4634JQ1 not drying or shutting off
MIGHT NNED A NEW IGNITER
OR GAS VALVE SWITCH
STEVE'S APPLIANCE
516-300-3249
Posted on Apr 06, 2009
SOURCE: Keep getting error message AF druing drying cycle and I've cleaned the lint trap.
check for clog or kink in dryer vent
Posted on Jun 10, 2009
  • 7 Answers
SOURCE: whirlpool gas dryer #lgr 4634 jq0 not drying and rattling noise
is the dryer tumbling
Posted on Jun 12, 2009
SOURCE: whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
Posted on Oct 14, 2009
I have a whirlpool cabrio gas dryer that take along time to dry. It has a code of F1 stored on it.The dryer vent is clean.Is the control panel bad.
change gas valve coils. for f1 error, if dryer is running don't worry about it. in future if your dryer beeps and flash f1 error you can unplug dryer get main control board out check dry solder on motor control rely it it is dry solder you can solder and you good to go or not solder problem then you need new control board. good luck.
Jan 21, 2017 | Whirlpool Dryers
Why is my Whirlpool cabrio platinum dryer leaking water, and taking over an hour to dry clothes?
Is this an older dryer? Long drying times are often caused by lack of good heating or poor air movement through the drum. Air movement depends on a properly turning fan and a clear exit of hot moist air to the outside vent. Check and see if you get a strong blast of air from your outside vent. If you don't, you may have a fan problem, plugged vent, or kinked vent tube. The water leaking could be because you don't have any drying going on due to the aforementioned problems.
Feb 05, 2016 | Whirlpool Cabrio Platinum High Efficiency...
We need to take apart our Cabrio Platinum Dryer to get it down our stairs.
Whirlpool cabrio dryer repair - YouTube
? 5:22
https://www.youtube.com/watch?v=aIxL38nnOLU
Sep 22, 2012 - Uploaded by Michael Steiger
Whirlpool kenmore safety fuse dryer not lighting GE Maytag. ...Dryer Troubleshooting - Not Drying or Taking ...
How to disassemble a Whirlpool Cabrio dryer
washerdryerrepairhelp.com > Dryers > Whirlpool > Whirlpool Cabrio
Jun 9, 2012 - How to disassemble a Whirlpool Cabrio dryer. Dryers ... If you need to take the drum out, there's a panel that holds it into place similar to the Maytag Neptune design. ... we respect your privacy and take protecting it seriously ...
How To Take Apart a Whirlpool Dryer ' Appliance Aid
Dec 21, 2015 | Whirlpool Dryers
Squeaking Cabrio dryer when running
The squeaking is due to the drum glides or as some people call them slides, being worn or broken. Easy fix and very inexpensive part
Mar 25, 2014 | Whirlpool WGD8800YW Cabrio Platinum High...
Whirlpool cabrio dryer not drying. Sounds like its running but no air coming from exhaust.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Sep 08, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My whirlpool cabrio gas dryer is not heating. it is just a little over 1 year old is there a reset button for the ignitor what is your recommendation it dryed the sheets until they were damp to the...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 27, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool Cabrio Platinum High Efficiency Gas Dryer with Steam cycle Logo
26 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
