Question about Dishwashers
Water will not shut off - Dishwashers
    Problem Solver:
  • 11 Answers
Does the water stop if the machine is unplugged from the electrical supply? If so then the fault lies in the pcb or level switch,
If the water continues to flow even after isolating electrically then a faulty solonoid valve is the problem.
Hope this helps- Kitcheneer
Posted on Jan 03, 2009
Tip
Eaton Home Heartbeat Water ShutOff Controller...
The Water Shut-Off Controller can be linked to HOMEheartbeat water sensors (HHBWATERSNSR) to automatically shut off your house's main water linein the event of a water leak. Simply place Water Sensors in high-riskareas for water damage. Then install your Water Shut-Off Controller onyour main water line and setup the unit to turn off if a Water Sensorbecomes wet. Then, when the icemaker malfunctions or the toiletoverflows your Water Sensor will become wet and your main water linewill close, minimizing the costly water damage.
NOTICE! This product requires installation of, and will only work with a HOMEheartbeat Ball Valve. Ball Valve installation may require professional plumbing assistance.
Important Note: Use of this product requires the purchase of the HOMEheartbeat Starter Pack
Review the User Manual at FixYa
on Jan 03, 2009 | Eaton Home Heartbeat Water Shut-Off...
WATER HEATER WAS LEAKING FROM BOTTOM OF TANK, I SHUT OFF WATER VALVE, AND SHUT OFF PILOT IS IT NECESSARY TO SHUT OFF GAS LINE GOING TO HOT WATER HEATER HAVING A NEW ONE INSTALLED TOMORROW
Yes, you have to shut off the gas going to the water heater. There should be an inline shutoff around it. Otherwise your going to be leaking a lot of gas which is very dangerous.
Apr 03, 2016 | Water Water Heaters
Where are the shut off valve to cut the water off
Should be on top of the water heater cold water supply.
Feb 23, 2015 | Water Water Heaters
How to change the water filer on a rf4267hars 25.5 ft
You must shut the water valve to change the water filter. If you don't havewater valve near the fridge, shut the main water valve for few minutes. If you turn the water filter to change without shutting the water valve, lots of water flooring the fridge and you do lots of work to remove the water inside the fridge. Shut the water valve, and then replace the filter. Then turn the water valve.
Apr 02, 2013 | Samsung RF4267HARS 25.5 Cu. Ft. French...
Water dispenser wont shut-off
Check the solenoid valve is not stuck open. It lets water in, pushing cold water out, and if stuck will not shut off.. It may even have a broken spring, but that is quite unusual
Apr 21, 2012 | Refrigerators
Where is water shut off valve on Rheem Electric Water Heater?
The shut-off is not on the water heater.
The shut-off is usually located on cold water pipe that enters water heater.
See image of shut-off:
http://waterheatertimer.org/images/Low-water-pressure-2-800.jpg
If shut-off is not located on cold pipe at water heater, then turn off water to house at water meter.
More resources:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Sep 25, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Need to clean single knob shower cartridge from what i read - where do i shut off water first? hot water running to bathroom - sink gets it - in shower, cold water good, hot water trickles - read lots of...
To clean it, shut off the discharge valve at the water
heater. Then, you shut the valve off of the main water supply. After which, you can start cleaning the single
knob shower cartridge. After the cleaning job, you can
open the discharge valve of the water heater, then, the
valve of the main water supply.
Nov 11, 2009 | Moen & One Handle Tub & Shower Faucet
HOTPOINT WD62 FILLS WITH WATER WHEN NOT BEING USED
All washing machines have a solenoid valve for turning on and shutting off the water coming in, one for the hot water and one for cold. It sounds like one of them has a slow leak.
Try shutting off the cold water supply to the machine for a day and see if the tub fills with water. Next try shutting off the hot water supply and leaving the cold supply on. This will tell you which valve is leaking.
This solenoid valve is something you can buy from an appliance parts company. In some cases, someone handy may even be able to disassemble it and replace a washer that is leaking.
Until it is repaired, you can get by with shutting off the water supply when you are not using the machine or shutting off the supply that is leaking. For example, if it's the hot water supply valve that is leaking, just shut off the hot and do only cold water washing.
-Vince
Oct 03, 2008 | Hotpoint Washing Machines
Dishwashers Logo
Top Dishwashers Experts
