My sa-ptx7 when press remote it says remote2 and won't work the remoter try trun off and on but not working its a Panasonic
2 Suggested Answers
SOURCE: Remote malfunction - panasonic dvd stereo system
The remote control and main unit are factory-set to “REMOTE 1”
mode.
If your remote control affects other equipment during operation, you
can switch to operate in “REMOTE 2” mode.
To switch to “REMOTE 2” mode
1 While pressing and holding [AUX] on the main unit
Press and hold [2] until “REMOTE 2” appears on the
main unit display.
2 Press and hold [ENTER] and [2] for at least 2
seconds.
The main unit and remote control are now set to operate in
“REMOTE 2” mode.
To return to “REMOTE 1” mode
Do steps 1 and 2 above but use [1] instead of [2] for both steps.
(“REMOTE 1” appears on the main unit during step 1.)
The remote control cannot work with the main unit if their
modes are different.
“REMOTE 1” or “REMOTE 2” appears on the main unit display when
you operate the remote control.
If “REMOTE 1” appears (The main unit is in “REMOTE 1” mode.)
Press and hold [ENTER] and [1] on the remote control for at least
2 seconds.
If “REMOTE 2” appears (The main unit is in “REMOTE 2” mode.)
Press and hold [ENTER] and [2] on the remote control for at least
2 seconds.
Posted on Mar 11, 2009
Remote control not working
HERE ITS ON PAGE 22, YOU MIGHT WANT TO KEEP THIS MANUAL FOR FUTURE USE..........
MANUAL
Jan 14, 2013 | Panasonic SC-PTX7 Home Theater System With...
My Panasonic SA-PTX7 doesn't open cd tray. help
I really like my SC-PTX7. But when that happens to mine I reset the unit. unplug, wait 15 seconds, plug back in, fixed!
hope that helps.
Nov 11, 2010 | Panasonic SC-PTX7 Home Theater System With...
NAO CONSIGO USAR MAIS O CONTROLE REMOTO, COM ISSO NAO CONSIGO FINALIZAR O DISCO......QUANDO TENTO USAR O CONTROLE APARECE NO DISPLAY " CHECK REMOTE ". E NAO SAI DESSA.
Há algum tempo o meu Gravador de DVD de mesa Panasonic DMR-E55PL-S vinha apresentando a seguinte mensagem de erro sempre que eu clicava qualquer comando através do controle remoto: CHK REMOTE2 Havia entrado em contato com o técnico da autorizada Panasonic de Niterói e ele ficou devendo-me uma solução. Como possuo outros 3 gravadores de mesa (2 Pioneer e 1 Samsung R121), apesar da contrariedade, não esquentei muito a mufa. Hoje, porém, encasquetei, e resolvi tentar, mais uma vez, resolver a má função. Após "ene" tentativas malogradas pintou o insight: - "Cacildas! Se eu faço tanta pesquisa para dirimir as dúvidas dos companheiros, por que não o faço também, para mim"? Assim, digitei no "gluglu": CHK REMOTE2 Panasonic Entre outras dicas, saquei esta: Question: - "Whenever I press any button on my remote control, I get this error message on the front panel display - CHK REMOTE2" Answer: - "Just hold ENTER and press the number indicated on the display for a few seconds, and it will fix the issue". Basta clicar ENTER e pressionar o numero indicado no display do painel frontal do gravador por alguns segundos - isto resolverá o problema. (Clicar ENTER e pressionar o número 2 no controle remoto). Tal dica serviu para o meu DMR-E55PL-S como também para o DMR-E85HS - do **** "flashcode" - devendo servir para outros modelos Panasonic da mesma linha. Soçarba... Mr. Walker
Aug 25, 2010 | Panasonic DMR-E55 DVD Recorder
Panasonic SA-HT820V need universal remote that can control radio
My remote works for the most basic functions I need it for. But there are things that don't work, like the Menu button. After looking online just now, there is a website to order new parts and accessories for this system. Here is the website, http://www.pstc.panasonic.com/EpartR/PartsListChoice.asp?validate=1.
If you order a new remote, maybe that will work. Not sure if it's worth it for you but that's what I'm going to try. And here is the remote you need, EUR7722X20. Good luck!
Mar 03, 2010 | Panasonic Televison & Video
II have panasonic home theater SC-PTX7, it
Go to the website and enter the model # for Help.http://www2.panasonic.com/consumer-electronics/support/ Good Luck
Aug 30, 2009 | Panasonic SC-PTX7 Home Theater System With...
Panasonic DVD Stereo System (SA-PM91D) REMOTE MODE 1
press the enter and number 1 button on remote simultanously
Jul 19, 2009 | Panasonic Televison & Video
Remote controle
Easy to fix. The DMR E55 has 3 remote control code settings and your remote can be set for any one of them. The error you are getting at the moment means that your remote is set for one code but your DMR E55 is set for another. Why do Panasonic do this? The reason that Panasonic do this, is because if you have several Panasonic units, you can operate one of them from your remote without all of them responding at the same time. Ok, so how is it fixed? Turn on your DMR E55 and press FUNCTIONS then select SETUP. Then select OTHERS. You will see the remote option on the right which will say DVD 1 or DVD 2 or DVD 3, Try setting it to a different code and press return. You should get it to work...
Sep 19, 2008 | Panasonic DMR-E55 DVD Recorder
Remote control
Which universal remote do you have? Any of the Harmony remotes should be able to control the panasonic.
Mar 08, 2008 | Panasonic sa-ht930 Home Theater Audio...
I had the problem where when i would try to use my remote, it would say "check remote2". I've got a DMR-E55. I called panasonic and they told me to hold down the "enter" and "2" button for about 10 seconds. then it worked. hope it works for you too.
Jul 09, 2007 | Panasonic DMR-ES10 DVD Recorder
43 people viewed this question
 Grubhead
Grubhead
