Question about Panasonic NN-2505A Microwave Oven
Replacing bulb for microwave
I Have a Panasonic model no. NN-K652BBPQ microwwave oven and the bulb needs to be replaced can you tell me how you go about it as i cant see how you access the bulb short of taking the cover off.
  • Panasonic Master
  • 9,098 Answers
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You should be able to download your owner's manual from Panasonic.net by choosing your region & country, then Support.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Jan 03, 2009
I need to replace a bulb, the glass cover and the bulb holder for a Panasonic Model NN K652BBPQ. Where can I order these parts please.
Panasonic.com appliance parts.com do agoogle search for panasonic microwave oven parts etc. the internet is your oyster the end result is your pearl
Dec 16, 2014 | Panasonic Microwave Ovens
Change light bulb panasonic inverter nn-h965bf
We recommend you have an authorized service center location replace the light bulb. Authorized service centers can be found in the below link.
www.panasonic.com/repair
Welcome to Panasonic Online Repair
Mar 23, 2014 | Panasonic NNH965BF Microwave Oven
Magic chef overthecounter microwave external light doesn't work
This microwave's replacement countertop light is F60305H00AP. This can be obtained by going to www.panasonic.com/parts.
The instructions for replacing the bulb can be found in the below link.
http://service.us.panasonic.com/OPERMANPDF/NNSD277SR.PDF#page=28
Mar 02, 2014 | Panasonic NN-SD277WR - NN-SD277WR...
Instruction manual panasonic nn-k652bbpq
The manual for NN-K652BBPQ does not come up on any Google search or on the Panasonic website I recently bought one second hand and I would like to know how to use it, could you please advise me on where I can find one? Thanks
Sep 14, 2010 | Microwave Ovens
Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. Next........do the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
Martin
May 10, 2009 | Panasonic NN-S540 Microwave Oven
Panasonic inverter model no NN-S540
You can download your owner's manual here.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 12, 2008 | Panasonic NN-S540 Microwave Oven
Have a Panasonic Micro nn-T790 SA, need to replace light???
If you don't see an access panel inside the oven, you must remove the outer cover to find & replace the bulb. Be sure to unplug the oven first!
Many models use halogen lamps. You must not touch the new one with your bare skin as the oils will shorten the bulb life.
If you don't have your owner's manual, you can download it here: http://service.us.panasonic.com/OPERMANPDF/NNT990SA.PDF
May 17, 2008 | Panasonic NN-T790SA Microwave Oven
Panasonic bulb nn a753
First, get the bulb part #F612E4W00AP or equal. Next, you should find a few screws around a plate in the unit through which the light shows through. Carefully remove them and the glass lens. When replacing the bulb, be sure it is in securely.
Dec 15, 2007 | Panasonic NN-T774SF Microwave Oven
Lightbulb no longers turns on!
They do this to avoid liability from your exposure to the instantly lethal voltages present in and generated by your microwave oven. For important safety and disassembly tips, search on Yahoo.com (not Google) for all this at once (copy & paste): microwave disassembly.txt safety.txt The oven must first be disconnected from the power line. The outer cover is held in place by several screws on the back and sides, then you lift up and back from the rear to remove it. You need to avoid the sharp metal edges on thge cover and inside the oven. Note there are also catches built into the top & sides of the cover which must be re-engaged upon reassembly, or the cooling efficiency will be compromised. Once the cover's off, if there's any chance you might come into contact with any of the high voltage connections, the high voltage capacitor should be discharged for safety's sake. Once the bulb is located, it can be unscrewed and replaced.
Nov 22, 2006 | Panasonic NN-T990SA Microwave Oven
Panasonic NN-2505A Microwave Oven Logo
293 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
