Question about Neff Dishwashers
Neff Dishwasher switching off (sd11xt1f)
Strange problem. after 2 yrs of perfect use, my dishwasher switch off during the drying process. then it turns on again and so on for three/four times for every cleaning program. when it turns off no way to turn it on's like there's no energy. after some minutes the machines goes on again with the program. it looks like it turns on when there's a high temperature in it during the cleaning process...when the temperature goes down it turns on again. any ideas? thanks!
  • 75 Answers
SOURCE: Neff slimline dishwasher type S5946
hi there sounds like your wash pump has burnt out
Posted on Jan 11, 2008
  • 145 Answers
SOURCE: Door Interlock switch Maytag MDB4100 dishwasher
If the door is not latching well enough try adjusting the spring on the tub it's the male part that goes into the door latch. If that doesn't help you need to replace the latch. It's inside the door. The switch is mounted to the latch in the door so to get to it you have to remove all the screws around the outside edge of the inner door panel. Unhook power before replaceing latch or switch!
Posted on Apr 23, 2008
SOURCE: Neff dishwasher sticks on 1 minute
We had this problem with our machine.
There turned out to be a few things that caused it:
- Firstly, the float assembly (an orange looking float in a little chamber, visible if you take off the left-hand panel of the machine) was clogged - we cleaned this and it seemed to help.
- The heat exchanger matrix was full of debris - we tried to clean this but ended up damaging it and bought a new one.
.. these two things seemed to improve the cleaning and the machine worked for a while.
The real problem though (which caused it to pump out continuously) turned out to be a failed seal on the circulation pump.
If you look on page 4 of the following link:
.. you will see a diagram of the bottom of the machine - the part that failed was 171598, which you can see on the bottom middle-to-right hand side of the picture..
The rubber had perished very badly, and it was causing water to leak into the bottom of the machine, which triggers 'flood mode' whereby it pumps continuously and doesn't actually wash the dishes.
The part costs about £5 - fitting it is not straightforward though, as you need to strip the machine down which is a pretty involved job.
If you think you're up to it, the steps I followed were:
- Remove both side panels
- On the left hand side, remove heat exchanger matrix and float assembly
- Remove kick-panel under the front door
- On the right hand side, remove all wiring from the door to the machine (including an earthing wire which is screwed to the side of the machine) - note that there are two wires which go to push-on connectors which have to be removed separately - all the others go to connector blocks.
- Inside the machine, remove the wire baskets, spray arm and bottom filter.
- Remove the lid from the salt dispenser - and now the tricky part, you need to find something that will allow you to remove the large plastic 'nut' that holds the salt dispenser to the machine.
- Remove the two screws in the bottom of the machine (167241 in the diagram mentioned above)
- Now, shut the door and then disconnect the door spring mechanism from the left and right side of the door.
- Disconnect the string from the door closing mechanism from the springs at the left and right back corners, under the machine.
- Remove the two screws at the back of the machine which connect the top of the machine to the base.
- Remove the two screws at the front of the machine which connect the top of the machine to the base (these are quite low down, near the door hinges).
Now, you should be able to lift the top of the machine off the base, and will have access to the pump etc.
... re-assembly is the reverse of disassembly ;-)
This took me a couple of hours - it might be better to find somebody who will do it for you for fixed cost as it's a pig of a job.
For what it's worth, there seemed to be very few places where the machine could leak - and this looked to be the major one - and there are a few push-fit pipes which are worth checking out too.
Hope this helps somebody.
Posted on Jan 07, 2009
  • 10865 Answers
SOURCE: Neff dishwasher door problem.
The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
Posted on May 21, 2009
  • 457 Answers
SOURCE: looks like program in electronic dishwasher has
im a old bosch tech . the problem is the module or the drain pump is stuck. if this helps please give me a 4 thumbs up post thanks.
Posted on Mar 01, 2010
Water not heating
Your dishwasher does not HEAT the water. That function is done by the water heater located separately. Turn the hot water on at the sink associated with your dishwasher and wait until it is hot BEFORE activating dishwasher. The hot water will flow into the machine and provide the heated water to clean. As for the drying function, check the control switches. There may be a module that is replaceable but a service technician has the needed tools to determine electrical functionality. There is no visual test for circuitry issues.
Sep 22, 2014 | Neff Dishwashers
My dishwasher works perfectly but makes a loud humming noise through whole cycle
Remove the filters and look into the sump (if the back of the sump is 12 o clock) look at approx 2 oclock and you will see a hole that draws the water in to the circulation pump (sometimes covered with an extra piece of plastic that can be clipped off) put you finger in there and see if you can feel any obstructions, if so remove. (you may find that cling wrap or a dishwasher tab packet has got in there and is stopping the motor running to full capacity and/or making it noisy). Maybe take the spray arms off and check the holes in them are not blocked, as this will also cause strange noises.
Mar 21, 2013 | Neff 24 in. S4457 Built-in Dishwasher
When the dishwasher is drying the load it blows the electrical fuse
There most likely is a problem with heating element or a wire shorting
Nov 07, 2017 | Neff 24 in. S5453X1 Built-in Dishwasher
Dishwasher pump keeps running
This is caused by a water leak into the base pan,it will trigger the anti flood and the machine will continously drain out even with the door open,you need to establish what is leaking,if you leave the appliance standing for a few days it will start again as the water will evaporate however if the fault returns you will definetly have aleak on the appliance which will require further investigation.
Jul 29, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Neff dishwasher trips the electricity
It could be faulty wireing in the dishwasher connection or you could have a leak in the washer causing the wires to get wet. I would have an electrician have a look at it.
Dec 19, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Neff dishwasher takes 3 hours, fails to dry dishes
mine has just started to do the same thing.... not sure why :o(
Aug 18, 2008 | Neff 24 in. S5456 Built-in Dishwasher
There is no power going to the dishwasher. It worked perfect 2 days ago and now it won't work. Checked the fuse and the plug. Now what. 2 yrs old GE QuietPower2.
check the transformer from primary winding to secondary,maybe ist already defective.check the voltage in the secondary,check the switch .
Mar 13, 2008 | Dishwashers
Neff built in dishwasher model no: S4453N0GB/07 When you switch the dishwasher on all the relevent lights swich on, indicating the dishwasher is ready to use. but when you switch the start button it clicks...
We fixed the problem at home. The Start button had a loose connection.unscrewed the panel and pushed all the wires in and were able to restart the dishwasher.
Feb 29, 2008 | Neff 24 in. S4456 Built-in Dishwasher
Neff dishwasher water filling
there is a safety float in there to shut the water off most look like domes under the float is a safety switch take off the bottom kick and see if the float is on the switch if it is check to make sure the switch is good
Feb 18, 2008 | Neff 24 in. S5543X2 Built-in Dishwasher
Dishwashers Logo
50 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
