Question about Nintendo Professor Layton & the Curious Village Games for DS
How to draw a cross with 17 pins outside and 16 inside
I have tried for days to solve this problem. The clue is to draw the cross diaganally but I still cant find the answer. Any help would be appreciated.
  • nic010181 May 11, 2010
    which puzzle number is this?
  • 4 Answers
The cross needs to be drawn at an angle. start at the pin on the far left 3rd from the top and take the line to the top row 3rd one in. Take it down at a 45 degree angle one pin and then back up at a 45degree angle to the 3rd pin from the top left (in a V shape) then take the line (you should be 3rd pin from left on the top row) take it to the 3rd pin down on the left and repeat the V indentation, repeat around the pins and you are there....
Posted on Jan 03, 2009
Will not display outside temperature even though I changed the battery on both the inside and outside unit
Find reset pin hole on base unit. Push in with a paper clip. Pin hole may be in battery compartment.
Mar 13, 2015 | La Crosse Technology TX37U-IT 915MHz...
What is the pin position 2003 dodgecaravan
what pin, name it. inside car, outside, engine ,transmission,brakes.
suspension, where? we have not a clue as cars have up to 3000 parts....
Jun 11, 2014 | 1997 Dodge Caravan
Draw a flowchart to enter a number from 1 to 7 and display the corresponding day of the week
1 rem zero out all variables housekeeping
10 let a=0
15 clear $today
16 rem get input
17 input a
19 rem choose corresponding day of the week
20 rem case structure
25 if a=1 then $today="sunday"
30 if a=2 then $today="tuesday"
rem ect til saturday
rem use data created
40 print "today is";$today
Apr 27, 2011 | Computers & Internet
I have a Rheem heat pump/air handler; it draws 2.9amps with only the fan running, 13amps when the heat pump is running and 38amps with the heat strips on. My question is why the unit draws that many amps...
Sounds like it must be about a 2.5- 3 ton system. The 13amps has to be the compressor draw -normal. and 38 on the strips- normal. 2.9 fan -normal.
You may want to check your wiring to see where the outside unit gets its power. Theres nothing inside that can draw 13 amps. That almost has to be the compressor power wire.
Jan 27, 2011 | Heating & Cooling
Don't know BIOS password
Here's how to reset password
Resetting a Toshiba BIOS Password KeyDisk will reset the BIOS password on Toshiba laptops.
Older Toshiba laptops can be convinced to boot without their power-on BIOS password by attaching a dongle to the parallel port which crosses a number of the pins. The pin out is:
Pins 1-5-10 2-11 3-17 4-12 6-16 7-13 8-14 9-15 Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
Jul 25, 2010 | Toshiba Satellite A105 Notebook
Outside unit turns on but inside wont. fan is real hot
I would suggest replacing your induced draft motor. You can perform an amperage draw test to verify it's integrity first. Also check your high limit snap disks before spending money.:)
Sep 07, 2009 | Cross Furnace Draft Inducer Blower 115...
How to solve no 100: seven squares
There are 28 PINS. Count each PIN starting from left to right on each line. (1 to 28 )
Square 1-- Join together PIN No's ( 1 -- 2 -- 6 -- 7 )
Square 2 -- Join " " " " ( 4 -- 12 -- 21 -- 27 )
Square 3 -- Join " " " " ( 5 -- 9 -- 11 -- 15 )
Square 4 -- Join " " " " (3 -- 10 -- 13 -- 19 )
Square 5 -- Join " " " " (8 -- 16 -- 23 -- 28 )
Square 6 -- Join " " " " (14 --18 - 20 -- 25 )
Square 7 -- Join " " " " (17 -- 22 - 24 - 26 )
Hope you can complete this Puzzle now ----------- GOOD LUCK
Apr 01, 2009 | Nintendo Professor Layton & the Curious...
1998 rav 4 ecu pinout location
sorry never done one so i havent a clue,in the good old days the tach connected to the coil wire but now with all this fancy electrics ,Well what happens is they call it vehicle security so they dont have to release the diagrams and this is done to stop people like myself from by passing the immobilisers when we service a vehicle.Because no doubt as you are aware on new cars that if you drop the oil the immobiliser cuts in.Change the battery and the same thing happens.So what happens to keep the dealers in work ,yes you have guessed it no wiring diagrams ,multilayered circuit boards and wires all the same colour to stop people like me from soldering the two outside legs together of a big switching transistor together to make the vehicle general mechanic friendly.Also encrypted software is used to stop the fault codes from being read ,they throw up the wrong code ?? try asking dealer to install then post where he connected too .,best of british with it
Mar 03, 2009 | 1998 Toyota RAV4
Green light keeps blinking? Any clues
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 23, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Manual?
The connections are show between the last 2 PCI slots. The connector is CN1A.
Here are the connections.
1 & 2 = G Button
3 & 4 = HDD Led + to pin 3
3 & 9 = Power Led + to pin 9
6 & 12 = Speaker + to pin 12
11 & 13 = Power switch
14 & 16 Reset switch
17 & 18 = G Led + to pin 18
15 is keyway [no pin]
[2 4 6 8 10 12 14 16 18]
[1 3 5 7 9 11 13 15 17 ]
Sep 14, 2007 | Chaintech 7NJL3 Motherboard
Nintendo Professor Layton & the Curious Village Games for DS Logo
403 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
