Question about Toshiba Tecra T9000 Notebook
Fgh zhfc
The area of triangle LMN is 18 ft2 and the area of triangle FGH is 24 ft2. If , what is the ratio of LM to FG?
In two similar triangles, the ratio of their areas is the square of the ratio of their sides. Let's assume LMN and FGH are similar triangles. The ratio of the areas of LMN to FGH is 18 to 24, or 3 to 4 or 0.75. We would then take the square root of 0.75 to get the ratio of the sides. I get 0.866. The reason it is the square is the area of a triangle is base times height divided by 2, and the base and height and sides of similar triangles are proportional.
Good luck.
Paul
Similar Triangles ratio of areas
Mar 12, 2015 | Office Equipment & Supplies
The plastic sleeve abo;ve the metal gate valve got striped do you have a metal sleeve to replace? I used this wand on the end of a 10 foot galvanized 1/2" pipe with a metal adapter . do you have a metal...
Hey there
this design seems ok but then they put a plactic adapter on the end...fail. on the inside of that plastic adapter you should be able to use a hex socket to remove from you extension wand. I suspect that the threading is 3/8" or possibly 1/4". You should then be able to match that up at a local pressure washer dealership. It will be 1/4" MPT x 3/4" FGH or 3/8" MPT x 3/4" FGH. Im guessing by looking at a picture of your wand only so still take this adapter out and check to verify the size. If you are having trouble finding the adapter then check here.
Pressure washer parts catalog quick links Pressure Washers High Pressure... Give them a call and they can help. The item numbers you are looking for are
1/4" MPT x 3/4" FGH Item # 3250
3/8" MPT x 3/4" FGH Item #3251
Good luck
Feb 24, 2015 | Orbit Telescoping Gutter Wand Set
My samsung flip phone, model no FGH/ZV40 is receiving calls but not text messages.
Try to call your service provider to check the configuration settings for your text messages. Asked them to refresh your account and verify the message center settings on the phone.
Jul 04, 2009 | Samsung Cell Phones
Pls reply
fghfghfg fgh fgh fgh fgh fghfghgf fg hfgfgh fg
Aug 27, 2008 | Acer Aspire 5100 Notebook
Fgh?
I/J/K/L/M/N/O/P :)
Whats This gh?
Mike @ Compurepair.
Feb 24, 2008 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
