Question about Kohler Home
Kohler Cimmeron Toilet model 3497, replace seal 1016219
Replace seal 1016219
3 Suggested Answers
  • 63 Answers
SOURCE: Master bath toilet replaced with a Cimmeron class
Kohler is correct. The most likely cause of this problem is an obstruction in the common vent stack that both toilets share. When you flush the old toilet it need more air to flush and will get it from the easiest source (your new water saver toilet). First adjust the float level in the old toilet so it won't use as much water or just stick a brick in the tank to take up space.Second, run a snake down the vent stack from the roof to check for obstructions. Birds will sometimes nest in there.
Posted on Mar 16, 2009
  • 82 Answers
SOURCE: Kohler 1-piece flush valve seal replacement.
That is a tricky one. Tighten the tabs, twist into place, then tighten a bit more. They are a pain in the a$$, but with patience you will get it done. Good luck
Posted on Dec 30, 2009
Aqua piston toilet keeps running....
Kohler customer service has provided a free seal (yellow) to replace the original seal (red)on the bottom of the Aqua Piston. The yellow seal is a big improvement over the red seal, but the toilet tank still leaks. I am ready to return the toilet to Home Depot.
Sep 20, 2013 | Kohler Cimarron Comfort Height elongated...
Kohler santa rosa fills, shuts off, a little water leaks from tank, toilet refills and repeats the leakage into the drain.
There is a rubber seal at the bottom of the flush valve that covers the openning at the bottom of the tank. If this rubber seal has perished slightly then it will leak water into the toilet bowl. This rubber seal need to be replaced to form a proper seal to prevent water leak.
Dec 27, 2011 | Kohler - Toilet - One-piece - Santa Rosa -...
Memoirs leaking from seal between tank & bowl. Just replaced the gasket and still leaking
In 2008 I bought the Memoirs model that Lowe's was selling. I've had multiple tank/bowl gasket leak problems. When I went to get a replacement gasket this weekend, Kohler had changed the style of the tank/bowl gasket assembly in the current Memoirs model that Lowes sells. I wonder if this is because the old gasket assembly is known to be defective and prone to leaking?
When I called Kohler, it took two customer service associated, but I was granted a WHOLE NEW TOILET with the new style of tank/bowl gasket assembly. I just had to have the receipt for the (3 yrs ago) purchase. Kohler e-mailed a letter for a replacement toilet within about 15 minutes and before the end of the day, I had a whole new toilet in my bathroom.
I'm not a contractor. Just an average homeowner, so I can't say for sure that the old style (large, black, plastic rectangle on the bottom of the tank and a rather thin gasket ring) was defective or not. (At first Kohler offered only a replacement tank, but after hearing the number of times both I *and* plumbers have replaced the gasket, they did authorize the replacement of the entire toilet.)
Apr 10, 2011 | Kohler Home
Dec 28, 2009 | Kohler K-3489 Cimarron Comfort Height...
Master bath toilet replaced with a Cimmeron class 6 confort height toilet. The master bath toilet backs up to the hall bath toilet - same wall. The hall toilet is very old. When the old toilet is flushed,...
Mar 16, 2009 | Kohler K-3489 Cimarron Comfort Height...
Kohler Rialto flap valve leak
if so cut 1/4 inch off the bottom of round part of flat valve
Feb 23, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Home Logo
415 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
