Question about Samsung Televison & Video
Mode Not Supported. Resolution not supported. Change the resolution on the external device for samsung tv. How?
Series 45
headstrong
  • 233 Answers
SOURCE: not supported mode lcd tv samsung lnt4061f
with the PC input or analog SVGA the only 16:9 resolution it supports is 1920x1080, which can be difficult for some older systems to handle. However, on HDMI it should support all the standard HD resolutions.
Posted on Dec 29, 2007
Postalsusie
  • 40 Answers
SOURCE: Not supported mode error
Hi, boot up to an F8 and select safe mode. While there change your screen settings to 800X600.
The available resolutions in the windows operating system has to be compatble with the TV screen you are hooked up to. try lower settings first.
Thank you and god luck.
Posted on Oct 28, 2008
  • 11 Answers
This happens when you have a video signal that the TV does not recognize. If you have an High Definition source such as a Blue Ray Disc player, High Definition Set Top Box, Or a High Defintion Gamming System than use the HDMI output of such device, connect a HDMI cable to this output and put the other end into The input of HDMI on the TV. Make sure you have this device on before you select the input on the remote of the TV or the TV will say NOT Supported Mode.
Posted on Jan 28, 2009
  • 8 Answers
SOURCE: Mode not supported
TV's usually have a maximum resolution of 1366x768.
if your resolution is higher than then when you connect to the TV, it won't be able to display anything.
Posted on Mar 13, 2009
dsacco86
  • 1077 Answers
SOURCE: Dynex 19 LCD
I went over the specs of the TV.
The max input for the VGA is 1360x768 at 60Hz. Anything higher will make the TV go bonkers.
I would try to get the resolution at 1360x768, then change the frequency to 60Hz.
Posted on May 29, 2009
I connected the HDMI 1 input from my tv to the HDMI output on the Yamaha Rx-v673 but i do not get any signal going throught to the tv. when i try put my samsung input source as HDMI 1 the tv prompts me...
To connect a TV you should use the Rx-V773, not the 673.
With the 673 you can use TV only as input, not output.
However there is a firmware update for your receiver. Try it.
Nov 13, 2013 | Yamaha Audio Players & Recorders
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
Can not connect to tv
change your resolution to 600x800 and your frequency to 60mhz then change display from regular monitor to your TV, you can increase the resolution gradually to find resolution that your TV can handle.
Apr 19, 2010 | Toshiba Satellite U205 Notebook
Mode not supported
Are you giving the TV a resolution it can't handle? Change the resolution.
Dec 02, 2009 | Samsung HP-T4264 42 in. Plasma HDTV
Mode not supported
Mar 13, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
TV won't accept monitor input
Try changing your computers resolution to something much lower. Mode Not Supported is usually an error regarding the Display Resolution of the video card being set higher than the monitor is capable of handling.
Aug 14, 2008 | Samsung SlimFit TX-S3082WH 30" TV
Not supported mode lcd tv samsung lnt4061f
Dec 29, 2007 | Samsung LN-S2651D 26 in. LCD Television
Televison & Video Logo
2,409 people viewed this question
Jerry Greenberg
Jerry Greenberg
