Question about AOC CT720G 17" CRT Monitor
Pincushion and h size problem on aoc 17" 771s
I can't adjust the pincushion and the h size please help.
thanks,
Albert
  • Anonymous Apr 22, 2009
    mine too. i cannot adjust the pincushion to balanced(50) settings. even the V-Center settings is stuck to 100. in short, the image is all messed up..I hope AOC can give a real good solution to these problems! it really pisses me off!
  • nhellzkie May 07, 2009
    my OSD always pop up and my pincushion and V-Center i can't adjust always in 100% plsss help me
One of the buttons on your monitor is partially shorted. trust me, ive encountered this problem many times.
Posted on Aug 27, 2009
My AOC 771S monitor less that a year old, displays half screen (vertical) and the display adjustment (V-size) is already 100% full What can I do?
Posted on Jun 27, 2009
  • 109 Answers
Most probable cause is damper diode and/or hi voltage capacitors in the flyback circuits..
Posted on Mar 09, 2009
Cannot fit to screen size
You probably need to install a display driver for this monitor on your netbook. http://us.aoc.com/monitor_displays/e950swn
Dec 05, 2012 | AOC 19" LED Monitor e950Swn Black
Can you adjust pincushion, overscan on Sony kdf46E3000?
Steve, I am not an expert on this model but I can provide a link to the manual that may be helpful. It is a PDF format and the pages that refer to your issue are 32-36. I hope this assists you in resolving your issue. Thanks for using Fix Ya.
http://www.retrevo.com/d/ds/progress?doc=422217ceb653da53024f151f0e38f2ce&rk=0.4228925186481609
May 15, 2012 | Sony Bravia Kdf-46e3000 46-inch 1080p 3lcd...
I can't adjust my "
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes hope this helps
Aug 13, 2011 | Computers & Internet
Need schematic diagram for AOC 5 En model (white 15 inches color monitor) - thank's
my AOC crt monitor 5En model has this problem. it has over width the compress button (<> ) is no longer functioning what particular component should i check or adjust inside the circuit? please i need ur help..
Nov 21, 2009 | AOC 5 En 15" CRT Monitor
Help me fix to the set up of my monitir AOC 7f 17''
Good morning! kindly try the following:
-mouse pointer on the screen, right click the mouse, then click the Properties, then click Settings tab, then click Troubleshoot or Advance which will guide you in setting your screen display. best regards.
May 04, 2009 | MPC Computers AOC 7F 17" CRT Monitor
I have a JVC AV-32F475 and the picture is now hour glass shaped.Any info on repair would be great.Thanks CHRIS.
Sounds like a pincushion problem. There is a knob or setting you can adjust for this problem. More then likely, a resistor has burnt out near the pincushion control, and trying to adjust it will not help very much.
Nov 13, 2008 | Televison & Video
My Sharp Aquos TV Model LC-30HV4U (1) has a large black triangle in the middle of the TV screen, and (2) the letters of words that appear on the screen are in reverse order and so are illegible.
if you the reset option once you try resetting ...
if you still persist the problem i think there will be some problem in the tube in that area ...
Sep 05, 2008 | Televison & Video
Can't Fix Pincushion
If the menu is appearing then it should be able to adjust the Monitor, provided you have replaced the micro switches. Check for continuity by pressing the buttons. I don't think that there is any prolem with other components.
May 05, 2007 | Samsung SyncMaster 793DF (Silver, Black)...
AOC CT720G 17" CRT Monitor Logo
1,424 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
