Question about Compaq Armada M700 Notebook
D drive folder
.when i open mycomputer folder there is no dvd drive folder.it is becoming very difficulty to manage. and my drivers are lost ,please suggest me what to do?
  • Beeuwen Gerryts
    Beeuwen Gerryts May 11, 2010
    ok, i need you to clarify a bit.
    When you insert a dvd/cd does the autorun start up? or not? what i need to know is if your CD rom is workig or if it is broken.
    Say your dvd rom's drive is e: if you insert a cd, and in the address bar type e:\ can you access it or not? If you can, the problem might be an autorun virus. I've had many results by running "Trojan Remover" which can be downloaded for free. Try that and run a scan.
  • 54 Answers
Let me give this a shot.
1. Right click on MY COMPUTER from your desktop.
2. Click PROPERTIES
3. I assume you're using WIN2K so click the HARDWARE tab.
4. Click DEVICE MANAGER.
5. Under M700 it should be the 5th item down I believe. DVD/CD-ROM drives.
6. Expand that listing. You most likely have a yellow exclamation point there, yes?
7. Right click on Compaq DVD-ROM SD C2402 and if the option is there please click ENABLE. If your option is DISABLE please continue reading.
8. Right click on Compaq DVD-ROM SD C2402 again. This time click PROPERTIES.
9. The 3rd tab is DRIVER. Please click that.
(PAUSE HERE AND LEAVE THOSE PROPERTY WINDOWS OPEN)
10. Double click on MY COMPUTER on your desktop and proceed to your C:WINNTsystem32
11. In the folder C:WINNTsystem32drivers you are most likely missing redbook.sys and cdrom.sys  In the folder C:WINNTsystem32 you are missing storprop.dll (I HAVE BOTH FILES BUT MY FILE SHARING SITE IS DOWN.)
12. After the files get placed in the appropriate locations return to the DRIVER tab of the PROPERTIES window. From here or from the ADD NEW HARDWARE wizard of your laptop you'll be able to search for a suitable driver and barring some other crazy reason for this happening you'll now have those files.
In case you can not find the driver files:
Email:
seanmcgettigan@yahoo.com
Posted on Jan 14, 2009
Driver usb handycam dcr trv 19e
did this some time ago so i don't recall clear...
-download the XP driver from the website
-create a folder on the c drive and run it from inside this folder - it will decompress the files to a folder called Sony_usb
-run setup from the Sony_usb folder - install in compatible mode after warnings
-restart pc
-open device manager -right click on the icon with the question mark and select Update driver
-browse to the location of the Sony_usb folder
-you will receive x red message (don't recall what the warning was) click ok and another message will pop about compatilbel install - do the compatible install.
to sume up - do xp compatible install all across
hope this helps
Jul 30, 2012 | Sony Handycam DCR-TRV19 Mini DV Digital...
Pioneer dvd-rw dvr-k17 problem
dera ingrid 61
Please reinstall the drivers for the both of the problems,if you dont have any cd then plz visit the manufacture website and download the drivers, after installing the problem is not solved then plz try with another drive,if the problem persist then try by reinstalling the OS
Apr 25, 2008 | Pioneer DVR-107D DVD±RW Burner
The windows can not recignized the dv device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
May 14, 2011 | Teac CD-Rewritable W28E CD-RW Burner
My samsung trudirect dvd writer is not shown on mycomputer. please help me soon. thank you.
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
May 06, 2011 | Samsung TruDirect SpeedPlus DVD-RAM...
Gps has lost its maps, screen says can't unlock maps
There several reasons you may receive the message Can't Unlock Maps on your nuvi or zumo device.
  • Can you press OK and get to the Where To/View map screen?
  • Did you load maps to the unit using the MapSource or MapInstall program?
  • Did you load maps to an SD data card?
If one of the points above applies to you, please follow the steps below to clear the Can't Unlock Maps message:
  1. Remove SD card from unit, if applicable.
  2. Plug the unit into your computer with a compatible USB cable.
  3. Open MyComputer/Computer icon. (Mac users skip this step.)
  4. Right-Click on the Garmin drive and select Open. (Mac users can locate the Garmin drive mounted on the Desktop.)
  5. Open the Garmin folder.1
  6. Locate a file named gmapsupp.img
  7. Right-Click and delete file named gmapsupp.img
  8. Safely disconnect your unit from your computer to see if the Can't Unlock Maps message is gone.
1. Nuvi 1100/1200/1300/1400/1600/3700 and Zumo 665 users will open the Map folder instead.
*If the gmapsupp.img file does not appear in the Garmin folder, please create an unlock file for device.
Nov 28, 2010 | Garmin Nuvi 265W GPS Receiver
How to transfer mp3 to my phone?
>Do you have the data cable for you phone.
>If you have it means please connect the data cable to computer and the phone.
>if it is asking to install the data cable drivers means please insert the cd that came along with the phone and install the drivers.
>Then you will get a removable drive and it will appears on your mycomputer folder and please go ahed and open the removable drive and copy and paste the mp3 songs
---All the best-----------------
Nov 29, 2009 | LG VX-8700 Cellular Phone
A folder take too much time to open
Every folder in windows when "thumbnails" view is given saves file named "Thumbs.db" in which small photos are saved which for internal content, and also "desctop.ini" is saved in folder, sometimes some incorrect datas or very big ammount of information is saved in this file, try unhide hidden files and delete those two files manually, it will reset folder wiew and will become it faster. also you can create separate folder and move content in it and then delete old one but be careful dont use ctrl+a to mark all files, because it also copys those mentioned files and result will be same, you will still suffer from waiting folder to open, better to copy by drag and drop.
Sep 22, 2009 | Microsoft Windows XP Professional
I also lost my DVD drive, in my sony vaio VGN-FG58e laptop. It also have Pioneeer DVD-RW DVR-K_17 ATA and the error code is 39. Could you please suggest the solution.
To solve this follow these instructions:
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording application
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7)uninstall the drivers for cd drive and dvd drive from device manager and then
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that there is no yellow exclamation on the CD or DVD drive
Jun 14, 2009 | Pioneer DVR-107D DVD±RW Burner
"Mycomputer" not functioning
You have changed their place, they should be on drive C, try to right click on them, go to property and find where are they now.If you can, just replace them.
Nov 02, 2008 | Microsoft Windows XP Professional With...
Compaq Armada M700 Notebook Logo
111 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
