Question about ASUS 3 Motherboard - M4A88T-V EVO/USB
M4A88T-v EVO memok blink - ASUS 3 Motherboard - M4A88T-V EVO/USB
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: Hooked everything up all new
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Posted on May 16, 2011
ASUS Motherboard M4A88T-V EVO/USB3 won't post
Specs say it is a dual channel platform for the memory slots. It requires two DIMMs to take advantage of this, but you would have double check the manual if it will run with a single DIMM.
Feb 04, 2013 | ASUS Computers & Internet
Blue sceen ASUS 3 Motherboard - M4A88TD-M EVO
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Tracey Laidler.
Yes you are quite correct BSOD or Blue Screen Of Death is normally due to a memory fault. However drivers are as big a culprit, especially seeing as though you have changed memory modules and processor.
Install all the drivers for this mainboard.
Also enter the BIOS/CMOS by tapping the Delete key during first powering on the computer.
Once in the BIOS/CMOS select the option to load defaults.
Check if that works.
If not then take it a step further by clearing the BIOS/CMOS by removing the silver button cell from the mainboard for 10seconds before reinstalling it in the correct orientation.
Take care!
Dec 15, 2011 | ASUS 3 Motherboard - M4A88T-V EVO/USB
Just powering on my new ASUS M4A88T-V EVO Motherboard to check if I have my connections done right, Receiving two short beeps then no beeps, Trying to find out what that means
2 Beeps? maybe Parity circuit failure
it is responsible for generating and checking the parity bit on the system memory when parity checking is used. This circuitry is not working properly.
This code usually means a problem with either the system memory or the motherboard.
Try to reset the cmos remove the battery. if not check the memory,try clean the gold surface of the memory using pencil eraser.
Sep 23, 2011 | ASUS M4A88TV EVOUSB3 Motherboard
Hooked everything up all new components, everything meets specs, computer will not boot. M4A88T-V EVO/USB3 motherboard.
May 16, 2011 | ASUS 3 Motherboard - M4A88T-V EVO/USB
I have an asus m4a88t-v motherboard with an AMD phenom II x6 1090T processor that I just built. When I turn it on, it powers up but nothing shows up on the display. There are no beeps from the motherboard...
make sure the battery in mother is good and double check fuse. what it is you have a 3x2gb corsair is over loading your mhz ram get a higher battery for higher performance and see what happpens.
Feb 17, 2011 | ASUS 3 Motherboard - M4A88T-V EVO/USB
My system is hooked up correctly. i have all the wires in the right place. my screen doesn't acknowledge the mobo or gfx card.us all parts compatable everything snapped into place.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
don
Feb 12, 2011 | ASUS 3 Motherboard - M4A88T-V EVO/USB
I have M4A88T-M LE + AMD Athlon II x4 640 CPU. 2gb x 2 1333 DDR3 Corsair RAM. I have assembled the comp myself today. My Computer does not show anything on the monitor. Monitor is connected. Power is...
Does your monitor show anything at initial power on and then go blank, if so try booting into Safe Mode...Right click on your screen, select Properties and reset your video settings
Feb 11, 2011 | ASUS M4A88T-M Motherboard & AMD Athlon II...
I Have A Compaq Evo N600c Laptop No Power Help!!!
Yeah it could be. Always use the correct adapter mentioned for your laptop. Otherwise it could harm the inner wirings and the motherboard. Always go for the right adapter. If it was any motherboard problem, atleast it would've blinked. So this might be the problem of your adapter or may be of the power button.
Apr 18, 2010 | Compaq Evo N600C PC Notebook
How to reset 8 blinks compaq Evo N160c
we have different brand of laptop and different functions keys... first read the manual and find out about the reset.... and if you can't find go to site and look for support... good luck!
Nov 16, 2009 | Compaq Evo N610C Notebook
Evo n610c
The computer's power light may blink to indicate that there's a problem with the power from the AC adapter.
Mar 25, 2008 | HP Compaq Evo n610c Notebook
ASUS 3 Motherboard - M4A88T-V EVO/USB Logo
29 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
