Question about Beko Ovens
Wiring diagram to fit part 4410101001 in a beko electric cooker
I need a wiring diagram to fit this part
  • 26 Answers
SOURCE: conection of a beko electric cooker
Pretty normal problem with Beko.
You need a Philips 2 screwdriver to get a suitable grip on the screwhead.
Good Luck!
Posted on Nov 27, 2008
SOURCE: Beko D533 cooker only half working
where the power goes in there should be fuse links on both sides if they all in then its the thermal fuse inside
Posted on Jun 22, 2009
samrat_babui
  • 296 Answers
SOURCE: how to replace oven light bulb for beko DC543 electric cooker
hi
You may need to remove the glass cover by turning it anti-clockwise.
On some models access to the bulb is from outside so the oven has to be slid out of it's housing and an access plate removed.
chek this following steps..
Step 1 Make sure the bulb is actually burned out. Confirm the oven is plugged in and that a circuit breaker is not tripped.
  • Step 2 Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
  • Step 3 Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
  • Step 4 Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  • Step 5 Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back.
  • Step 6 Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb.
  • chek this usefull link
    http://www.espares.co.uk/advice/cookers-and-hobs/a/1/112/changing-your-oven-light-bulb.html
    hope u will b helpfull
    tnx for contactin fixya
    regards
    Posted on Jul 12, 2009
    SOURCE: beko dvc6531 cooker
    i can send u a copy of user manual if you need one you have to hold the first two buttons in then move time with up or down please email me if you need more info andyali09@btinternet.com
    Posted on Aug 30, 2009
    SOURCE: WIRING FOR AN ELECTRIC COOKER (I NEED A DIAGRAM) !!!
    Trying to wire up an electric oven. Good with electrics, normally. Sounds stupid bus there are no holes to place the wires into on the oven panel. In other words not like the speces on a plug or on the main live circut on the wall. Where do I put the wires????
    Posted on Oct 30, 2009
    Beko fan oven making noise
    If you have a problem with your cooker or oven then this diagnostic video will help you find the fault on your beko oven and i hope it helps you. i have put a link also so you can get the parts for your cooker
    cooker parts
    Need help fixing your appliances
    these repair guides will also help you find and understand the exact problem with your cooker
    How to Repair
    and if we really helped you you could always buy us a beer
    Buy Paul Beer
    Jan 08, 2014 | Belling XOU492 Electric Double Oven
    Beko oven
    If you have a problem with your beko cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
    cooker parts
    How to Repair
    Buy Paul Beer
    Jul 06, 2013 | Ovens
    HI I have a Beko Electric oven (model SCC 2632). It has a combined oven and grill element which i redently had to replace. Fitted it no probelm, but when it came to attaching the coloured wiring spades...
    Have a beko scc 2632 cooker. Need to know the colours of wires fom left to right of grill/oven element as it is different than the old element?
    Jan 29, 2011 | Ovens
    I ve got beko electric cooker model DC543 and the oven doesn't work
    This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
    Here are the 3 main faults to look for in your oven or cooker that is not heating
      1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
      2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
      3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. For all you Beko elements
      If this helped you why not get me a beer?
    Paul is from the Naturally he would appreciate beer How to Repair Home...
    Jan 15, 2011 | Ovens
    Have beko D533W electric cooker oven not heating up fan still working
    Generally speaking, if the fan is working o/k, then it is usually the fan oven element that has failed.
    This is usually located at the rear of the oven compartment behind a removeable cover.
    Nov 14, 2010 | Ovens
    Have a new electric cooker but the oven and 1 of the hob plates isn't working dc5422 beko
    hi chances are that the internal thermal cutout fuse has gone this fuse is situated on the right hand side of the cooker when you have taken the back plate off about half way down it has two wires attached to it and is screwed with a self tap on the right hand corner of the body of the cooker near the middle of the cooker. You can buy this part and have it delivered for about £6 so is a very cheap fix.
    Sep 17, 2010 | Ovens
    Beko dvc 62 ,all electrics tripped out ,put cooker
    The element has blown. It will cost you around
    May 16, 2010 | Ovens
    Dec 07, 2008 | Ovens
    Conection of a beko electric cooker
    Good Luck!
    Nov 26, 2008 | Ovens
    Electrical connections on indesit cooker
    Is it just a 2 wire connection element?
    Feb 29, 2008 | Ovens
    Ovens Logo
    32 people viewed this question
    Top Beko Ovens Experts
    Owen Barnes
    Kevin Getz
    Kevin Getz
    ray gallant
    Are you a Beko Oven Expert? Answer questions, earn points and help others
