Question about Generac 5871 Guardian Series Air-Cooled 10kW 120/240 Volt Single Phase Steel Residential Generator with EZ Transfer Switch
Generac 10kw 7.5 fuse blown
Blowing genrator controller board fuse
2 Suggested Answers
  • 2841 Answers
SOURCE: I purchase a Generac/Centurion 10kw
This is not a DIY job unless you know what you are doing. But here is a link describing how it is done. I will not be responsible for any accident or damage done from installing it incorrectly. I would advise you to call a qualified electrician. http://members.rennlist.org/warren/install.html
Posted on Oct 02, 2010
Generac gen 10000xp will not start not getting fuel
Is there fuel in the carburetor Bowl?
did you try running a separate gas line from a different gas tank to the carburetor?
Apr 01, 2014 | Generac XP10000E XP 10000 E 5932 Portable...
20 kw generac is blowing 7.5 amp fuse,and all lights flashing.
You have a short: Check the wiring harness, check for shorted fuel solenoid, pump, rotor windings. Do this before replacing the control board
Oct 04, 2013 | Electrical Supplies
7.5 amp fuse
check all the wiring make sure no corrosion or exposed wires other than that try replacing the button module
Jul 19, 2013 | Generac Guardian Electrical Supplies
Generac control wires
just 4. I install generac switches and generators
Apr 17, 2009 | Generac 100 Amp 120/240-Volt Transfer...
Guardian generac 10kw model 5502 does not output correct voltage
the instructions says the voltage regulator is automatic/digital. when you check the voltage is there any load on the generator? if applying load to the generator doesn't help, you can manually change the motor speed where the governor connects to the carborator, but it may change the frequency, but the regulator may fix it
Apr 12, 2009 | Guardian Electrical Supplies
Generac 5871 Guardian Series Air-Cooled 10kW 120/240 Volt Single Phase Steel Residential Generator with EZ Transfer Switch Logo
151 people viewed this question
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
dennys23601
Don  Farrell
Don Farrell
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
