Question about Reebok Exercise & Fitness
My reebok z8 treadmill is showing error code1 or 7, what does this mean.
We have recently had to change the main fuse in the treadmill and since then on the display error code 2 or 7 shows!
5 Suggested Answers
  • 33 Answers
SOURCE: my treadmill is showing an E1 error code, what
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make fixing it child's play: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
SOURCE: new free spirit treadmill - L5 code what does it mean?
Yeah - the sensor is the problem... It is magnetic... You can find it next to the wheel on the belt - It is fairly small.... There is a metal disc in the wheell on the belt that is a magnet.. As it passes by the sensor - the sensor registers the magnet and can simply calculate speed based on the frequency of the passes... Sometimes the sensor slides too far back and ergo can`t register the magnet passing by - Then you get the L5 error...
Follow this link to a picture!
http://www.angelfire.com/nm/nickm/freespiritl5.html
Posted on Jan 18, 2011
SOURCE: I've just bought the Reebok Edge 2.2 Treadmill
In order to change the speed increment, you will need to unscrew the front of the console from its housing by undoing the screws at the rear of the console, the front part will then lift off. On the circuit board underneath there is a black slide switch, switch it to whichever setting you want (M or K) and it will read in that measurement.
Posted on Mar 01, 2011
diodeic
  • 1622 Answers
SOURCE: My reebok 8000c treadmill has
Hi,you will need too contact a reebok 8000c treadmill expert for help. You can use the link below for help...Take care..
http://www.treadmilldoctor.com/RBTL060080-REEBOK-8000-C-FRONT-ROLLER
Posted on Apr 07, 2011
What is fault code E03 on Raebok Z8 Run treadmill
E03: This indicates a fault with the mounted speed sensor on the drive motor. Contact technical support.
Official Reebok Fitness
Mar 02, 2017 | Exercise & Fitness
Error code E-02 on a reebok z8 treadmill
Hi. Have error code e2 on reebok z8 can you advise what this is.
Thank you.
May 31, 2014 | Reebok Exercise & Fitness
Reebok z8 error E03
I can not adjust my tension on my machine
Feb 27, 2014 | Exercise & Fitness
My Reebok Z8 Treadmill says 'E-02' on the display screen. It is constantly beeping and fails to work, How can I fix this?
Run the software calibration for easy diagnostic, and fix it. The speed sensor, can be dirty or faulty, test with s.calibration. see the diagram attached.Read you owner manual or go HOOD cover motor and follow the instruction.
Oct 23, 2013 | Exercise & Fitness
Treadmill error code
see the video and proceed according. Of course you must lube the rollers bearing front and back.
God bless you
Sep 18, 2013 | Reebok Exercise & Fitness
Reebok z8 won't turn on
see the video and fix it. see too the block diagram
God bless you
Jan 19, 2013 | Exercise & Fitness
Z8 reset
1)adjust the reed switch, clean , and tight the wires connector very welll, see the diagrams
2) Tight the ribbon cables, from keypads. tight the display board vs lower board.
3= Try again and proof.
God bless you
Jun 14, 2012 | Reebok Exercise & Fitness
Z8 is showing L5 cant seam to fix this
Dear Sir:
I will try to help you, please use the steps with patience and carefully: You must need some basics tools; Included Dvom (Digital Voltemeter).
Instructions Things You'll Need for to Reset Code:
  • treadmill (all models applicable)
1.
    • 1
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
    • 2
Press the "ENTER" button three times to access the treadmill's error log.
    • 3
Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
    • 4
To view the treadmill
Oct 19, 2011 | Spirit Fitness Z8 Treadmill
Reebok treadmill Z8 error E-01
Dear Sir:
Thank you by your request, I will help you inmediately.
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Thank you in advance, sincerely. God bless you
If you need further assistance, contact me
E.CUADRA
MANAGUA, NICARAGUA. C.A
Sep 28, 2011 | Exercise & Fitness
Exercise & Fitness Logo
1,142 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
