Question about Neff Microwave Ovens
How do I replace the inner glass on a neff c67m70
5 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Neff H7871 inner glass broken
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Posted on Dec 07, 2008
  • 228 Answers
SOURCE: NEFF B6784N0GB - Inner door Broken - Replacement
use some silicone grease just a small amount to make it sticky this should do the trick
Posted on Oct 28, 2009
radar001
  • 1051 Answers
SOURCE: the inner door glass shattered and now no power
There's a safty switch which prevents the unit from operating if the door isn't fully closed. When the glass shattered a small piece may have blocked the switch from operating properly. Check around the door seals for any irregularities.
Posted on Mar 22, 2010
  • 3 Answers
SOURCE: how to replace inner glass panel on Neff H7871
Hi Bill, I am having a same problem I have managed to order the glass from:-
http://www.4neff.co.uk/cgi-bin/product.pl?PID=876912&query=Neff%20H7871N1GB%2f01&model=H7871N1GB&path=127858
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, the door should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slip in hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner door behind it.
5. Remove the 16 screws holding the inner glass with a special star type screw driver bit no T30.
6. Once you done that the glass housing holding the inner glass can be carefully prised free and taken off the inner door assembley.
7. Once you done that remove and inner glass, and be carefull to leave the glass glass seal intact, clean around the frame housing and the seal then replace the new inner glass and reverse the process.
PS. Becareful of the inner door once you've removed the outer door, as the hinges holding the inner door tend to shut quickly as there is less weight on the hinges.
It will do the job if you follow these instructions.Good Luck. AL
Posted on Nov 04, 2011
Neff c67m70
check the timer setting make sure its not on a set timer mode
Aug 15, 2014 | Microwave Ovens
Neff b6774N0gb/02. Inner glass shattered. replaced. Internal fuse blown. replaced. Now microwave working (heating water) for approx 5 sec, then switching off, beeping and showing E1 fault. Also display...
Usually if this model stops after approx 3 secs it is an invertor or mag fault. Check that the aerial cover is clean Page 3 of the breakdown part position 315. If this is really grubby it would be the cause of the door shattering. The PTC is not used on the microwave function so may be an additional fault. Check also the alignment of the door switches as this can also cause a similar fault. My best guess is if you remove the mag, you'll probably find scorching on it and it (and the invertor) will need replacing.
Mar 25, 2013 | Neff Microwave Ovens
How easy is it to replace the inner glass on a Bosch HTH B84K microwave
see the video and proceed according with common sense.
God bless you
Jul 31, 2012 | Neff B7740N0GB Microwave Oven
How to replace inner glass panel on Neff H7871 microwave
1. Open the door.
Oct 10, 2011 | Neff H7871 Convection/Microwave Oven
The inner door glass shattered and now no power
Mar 22, 2010 | Neff H7871N2GB Convection / Microwave Oven
Glass continually shattering on combination neff oven
That's a huge gap.
You might ask their customer service people to authorize the replacement of the whole door or the glass and the inner door panel where the gap is.
If they won't help you, you could clean it thoroughly, then carefully caulk the gap with high temperature caulk.
Oct 09, 2009 | Bosch Microwave Ovens
Hi, I am having a same problem I have managed to order theglass from:-
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, thedoor should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slipin hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner doorbehind it.
5. Remove the 16 screws holding the inner glass with a special star type screwdriver bit no T30.
6. Once you done that the glass housing holding the inner glass can becarefully prised free and taken off the inner door assembly.
7. Once you done that remove and inner glass, and be careful to leave the glassseal intact, clean around the frame housing and the seal then replace the newinner glass and reverse the process.
PS. Be careful of the inner door once you've removed the outer door, asthe hinges holding the inner door tend to shut quickly as there is less weighton the hinges.
It will do the job if you follow these instructions. AL (srahbah@hotmail.com)
Dec 05, 2008 | Neff H7871 Convection/Microwave Oven
NEFF microwave
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Neff Microwave Ovens
Oven Glass replacement HTHB84K
You can find their support and spares links via their Belgian site or British site.
May 22, 2008 | Neff B7740N0GB Microwave Oven
Microwave Ovens Logo
69 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
