Hi I have a fisher and paykel clothes washer model WA75T65GW it is displaying what i assume is an error code. green lights 3 and 4 light up along with red light 8 and it beeps continuously. Could you please tell me what this means?
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
(00011001) Phase 5 IW - LCD Initialisation Error
The Intuitive Display has detected a problem with the LCD. Liquid Crystal Display
Primary Source: IW Display Module
Action: Replace IW Display Module
Posted on Oct 28, 2012
SOURCE: fisher paykel washer
Sounds like you could need a new out of balance switch or bracket, also try to make the clothes evenly spread in washing machine on rinse if they clump up on one side of the bowl they will cause out of balance :)
Posted on Sep 07, 2008
BIKER T
  • 909 Answers
SOURCE: Fisher & Paykel washer GW712 won't spin
There is an issue with your drainage area. Best to remove the pump and check for the obstruction in the line or at the impellar.(If the water is not completely drained, the pressure switch wont send a low level to the timer to allow a spin).
Posted on Sep 14, 2009
  • 343 Answers
SOURCE: iw712 fisher and paykel washer has fault code 37 w...
37 is drain error..There could be electronic reasons, but the most common problem is that there is a clogged pump or something is jammed in the pump impeller... Empty the machine of water and lean back against the wall so you can get access to pump, which is clipped to the bottom of the drum..Try turning the fan and see if the pump is blocked'/jammed.....Disconnect the wires and rotate the pump motor anticlockwise...It will be prevented from turning by a small plastic latch. Unlatch and remove pump motor...Remove any detritus and refit pump motor....If the motor resistance is less than 33 ohms (230volt) or 7ohms (110volt)..the pump motor itself might be the cause of the fault code, and should be replaced......This is a very simple job for a tech...Good luck....Nomess
Posted on May 24, 2010
  • 30 Answers
SOURCE: Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
Posted on Jun 08, 2010
SOURCE: Fisher Paykel Washer IWL 12 error codes 130 & 240
Had the same problem cleaned the terminals worked for a bit and came back. The problem is that the little circit board that the plug goes onto that sits between the winding of the motor the copper tracks are so small and they corrode. If you are handly with a solding iron you can replace the tracks with small wire, its mainly on one leg of each of the transistors that are all parrelled up. You can tell because it goes black. Or the easy way just take off the motor unpluging the sense plug then the three main power connectors Yellow, blue and red making sure you mark the correct order to put them back on. The sensor board just pulls out of the windings with a little arrow to but it back in the right place and buy the small board it has the part number on it to find it on the web. I only has three bits on it can't be expensive. Soldered mine up works a treat make sur you clean up the plug aswell, it mainly played up in humid weather.
Posted on Dec 22, 2010
Intuitive type. error code 241 appears what does this mean and can i fix it myself
Hi i googled error code on fisher and paykel and found this link-->
http://www.searspartsdirect.com/washer-repair/error-codes/fisher-paykel-aquasmart-top-load-washer-error-codes.html
If you scroll down the page in the link the error code 241 says
"Motor control module failure", Unplug the washer and replace the motor control module. OR
"Display module failure", Unplug the washer and replace the display module...... Good luck...
Mar 11, 2016 | Fisher and Paykel Washing Machines
Machine beeps 3 lights on and won't pump water out
can you take a picture of the lights that are on so I can work out the error code thanks
Jan 29, 2013 | Fisher and Paykel Fisher & Paykel Washer
My fisher & paykel smart drive excellence 7.5 washing machine squirts water in a few times and then stops and beeps and displays 3 lights red orange and (short wash) green as well as low and med speed...
Although slightly unclear these are the only possible error combinations for the leds on the machine as you look at it with red always on the end right hand side.
(11) 1011 (Green - nil - Orange - Red) - pressure problems perhaps a blockage in the tube to bowl.
(13) 1101 (Green-Orange-nil-Red) - pump is faulty
(15) 1111 (all lights on) - display module is faulty
I do not recall that the leds across the spin speed actually means something.
Good luck
Jun 06, 2011 | Fisher and Paykel Washing Machines
F & P Washer GW612 Wont drain fully unless you repeat spin a couple of times and then wont rotate have taken motor to be tested was (low?)Have replaced no improvement First and fourth light flash and...
Kate - firstly the windings of the stator when measured is 32 Ohms, earlier models was a lot lower between B-Y-R.
The washer will pump - rest pump (Cycles) during the spin cycle, if however it overheats then water will not be fully pumped out. A possibilty is the hose into the drain or sink is too high, or blocked somewhere.
In most cases the washer will indicate an error code.
The LEDS 1st & 4th from the right im assumming 10010000 = Fault code 144 - either you have a loose connection under the display/push buttons panel or you have a faulty motor control module
May 11, 2011 | Fisher and Paykel Fisher & Paykel Washer
Tub fills but there is no aggitation model gw612
Hi just read your posting,Now, does the machine show an ERROR CODE and beeps?If it does show an error code it will be in a number in your LCD DISPLAY if you have that model or a series of lights will light up.Now these lights will be in a row of 8 lights.Starting from the left to the right which ones are lit when the machine beeps?Is it the 2nd and 4th or the 1st and 5th ---etc---?Please reply with additional information and I am sure I can help you.
Aug 24, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher/Paykel WA37TG1 washer. goes through the wash cycle and the rinse cycle. stops at spin cycle and beeps. lots of suds left on clothes. have unplugged and let sit and start again. this got me through a...
Hi just read your posting.Now when the cycle beeps a series of lights will light up indicating an error code.The lights will be in a row of 8 lights.Starting from the left to the right which lights are lit?Is it the 2nd and 5th or the 3rd and 7th ---etc----?Or do you have the display model and an error code is on the screen?Please reply with the additional information on the questions and I can help you further.
Jul 20, 2010 | Fisher and Paykel WA37TG1 Top Load Stacked...
I have the fisher & paykal excellence 6-5 smart drive model gw609au when i first turn it on the seconds green light is flashing and it is trying to fill up but starts and stops all the time then just...
Hi Damian just read your posting.Your fault on your machine is the out of balance switch is faulty.Do you still require help?Please reply and I can guide you throe the repair of this problem.
Jul 02, 2010 | Fisher and Paykel Fisher & Paykel Washer
Our Fisher Paykel washer shuts off during wash cycle and makes a beeping noise that intermittently comes and goes. There is also a small leak at the right front part of the washer.
Hi just read your posting.I need to know the model number of the machine.Also when it beeps do any lights light up or any error code appears on your display if you have that model.Please reply and I can help you rectify this problem.
Jun 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
Doesn't drain in rinse mode
Hi just read your posting.Now when it stalls in the rinse cycle does it start to beep and light up a couple of lights to indicate a fault code? Or do you have the LCD display model that shows the error code.If your machine shows some light on the same line of lights, there are 8 in a row , which ones are lit? Is it the 2nd and 4th or 1st and 6th--etc .Also if you have the LCD display model what is the error code?Please reply for further help.Hope this helped.
Jun 05, 2010 | Fisher and Paykel GWL11 Top Load Washer
FP GLW10spins but clothes are still wet and lights/beeping are on
Most likely your filter is blocked, check out where this is and clean out well. Second there could be block in your exit pump preventing the water from being pumped out. If possible call or see your dealer for help, but you could do the thing yourself. You can click on troubleshooting above in blue. There should be several solutions for your model. The washing machine companies do not tell you how to do these things, so they can send in their techs to make more money.
For new buyers - ASK WHERE THE FILTER IS, WHAT ARE THE VARIOUS CODES, SERVICE. Where is the tech sheet?
Feb 26, 2009 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
