Question about DeLonghi EN680.M
DeLonghi EN680.M Nespresso Lattissima Single-Serve Espresso Maker
My water button of the machine is not illuminate , its not working
  • 123 Answers
SOURCE: instruction manual for delonghi combi espresso/filter coffee maker bc0255
http://www.delonghi.co.uk/pdf.php?key=Coffee%20Machines
Your manual is listed on this page and you will be able to download it.
Good Luck.
Posted on Apr 10, 2008
SOURCE: Delonghi Espresso Maker Issue
check the water temp and make sure the grind is not to fine. if both of these checkout ok then it may be a weak pump. you will have to find a replacement pump.
Posted on May 05, 2009
  • 279 Answers
SOURCE: I am housesitting and can
The idea is to froth the milk as the espresso is brewing.
Posted on Sep 18, 2009
MNfisherman
  • 11896 Answers
SOURCE: Replacing the pipe unit
the pipe will pull on and push on. It should have rubber connections. I first would remove the 4 screws on bottom. Should only need a screwdriver and a needle nose pliers. I haven't seen a diagram or repair manual yet.
Posted on Oct 24, 2009
espressonist
  • 1711 Answers
SOURCE: My delonghi lattissima is not piercing the
First you need to check the capsule container. Make sure that there are not any coffee remains both the liquid of dry coffee since will blocked the capsule to sit in proper place and thus to be press correctly. If you find anything you need to clean them very well with a warm wet sponge (remove machine from plug).
The second possibility is that one part of the lever and capsule container have brake either a plastic part or a metal rod or a spring moved out of place. In this case you need a new capsule container which you can find in this link.
Here is also you machine parts diagram.
Posted on Jul 31, 2011
Delonghi
For De\'Longhi En520.W Nespresso Lattissima Plus Coffee Maker Team De-Brewerz.com says:
1. Your coffee maker might suffer from water pump, water sensor or PC board failure. Claim the warranty if recently purchased. If you are in India then contact us @ www.De-Brewerz.com
Now you can order all De Brewerz Stuffs online in India @ www.fabkaart.com
Aug 29, 2014 | De'Longhi En520.W Nespresso Lattissima...
Delonghi problems
Try filling both water and the milk container with the correct decalcifying solution - just slit the 500 ml that results from the 1:1 mixture and - without the coffee capsule - press the cappucino button. Instead of cappucino you will get the decalcifying solution running through the entire system including the connector for the milk container (unlike the recommended decalcification method where you use the extra nozzle). Good luck - worked for my machine which only produced steam but no milkfoam...
Aug 02, 2014 | De'Longhi En520.W Nespresso Lattissima...
Delonghi problems
Try pressing all 4 buttons on top of the machine simultaneously after turning on the machine for a few seconds. That resets all volumes to the original factory settings.
How obtained A download a manual?
Go to this site to get a manual. It is listed under CUSTOMER SUPPORT. :-) Here is the link to the website. http://www.delonghi.com/en-us/products/coffee-and-espresso/coffee-makers/nespresso-system/lattissima-pro-en-750mb-0132192224?gclid=Cj0KEQjwrqieBRCln82Rgufz7I0BEiQAPNjAIwPVQ5e68guS8rRE8O_Lry_tcDMQOapRV2KTlEHJuIkaAqS_8P8HAQ Lattissima Pro EN 750 MB
Jul 20, 2014 | DeLonghi Coffee Makers & Espresso Machines
How to programme it for larger cups of coffee
Press/Hold the large cup button until u reach the desired measure of your coffee... Release it when u think it is enough for your large cup..
Feb 09, 2013 | Nespresso DeLonghi Lattissima Plus...
Our machine does not puncture the Nespresso capsule - so we only get murky water.
I just had the same problem with my new (less than one month use) Nespresso U. (the top of the capsule doesnt puncture and only water comes through). I called Nespresso customer service and a very helpful man suggested I run water through three times by pushing the top slider open with the Longa button pushed and then closed without a capsule in the chamber. That released the air bubble and now I am enjoying a wonderful cappuccino again! The customer service is fabulous, there was never a suggestion of charging me and I was told that Nespresso will send me a free loaner machine if anything goes wrong in the future that can be readily fixed over the phone. The Nespresso U is the best thing I ever bought.
Aug 25, 2010 | Nespresso C100B Essenza Single-Serve...
Water button orange light appear even after descaling
I had the same problem too.
Do repeat the descaling with water only. After the descaling the Lattissima shuts down. Just wait some time after shutdown before restarting the Lattissima again. The orange light will be turned off.
Hope this helps you too!
May 01, 2010 | Nespresso Lattissima 660.R
Coffee tastes very acidic
Hi kdimof,
I realize you posted this problem over a year ago, but I was curious to see if you were ever able to resolve this problem, or find the exact cause.
I have the same issue you describe. I descaled my Lattissima for the first time using the Nespresso descaling solution. And now, two months later, I cannot remove the chemical smell/taste of the descaling solution. I've run numerous descaling cycles with just water (as per Nespresso's customer service advice), with no success. I was forced to accept a refurbished machine (even though my Lattissima was only 3 months old). The refurbished machine is currently on the way. We'll see if I have the same issue when I descale this one.
Thanks, Redfran
May 14, 2009 | Nespresso Lattissima 660.R
DeLonghi EN680.M Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
