Question about Dayton Heating & Cooling
Vaillant boiler pilot sparks but there is no flame
Natural gas boiler it does not fire
  • 41 Answers
SOURCE: yellow pilot on heater
soleman13au
Rank:master_s.gif Master
Rating: 90%, 19 votes
Hi mitalee1
All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this. If you can get to the top of the pilot light it may help to give that a blow out too.
To clean it out internally you only need to remove the front panelling. Just follow the screw configurations *** you go. I asm not familiar with that type of heater so thats about the best I can do. Regards Bryan
Posted on May 07, 2008
SOURCE: natural gas patio heater
make sure there is no dust dirt spider webs in the pilot hood if u have a nice blue flame coming from the pilot and u held the pilot knob down for at least 30 sec
and it still doesn't work then u have a bad THERMOCOUPLE
Posted on Oct 08, 2008
  • 832 Answers
SOURCE: boiler won't fire even though the pilot is lit
Check if the ignition plug works. Upon putting your boiler on, a spark will normally trigger the
the firing. Then, check the ignition transformer if it works. Check the secondary voltage which is between 15000 to 20000 volts to trigger the ignition plug and the boiler to fire. If no spark,
have your ignition transformer replaced to make it work.
Posted on Sep 21, 2009
billyvangogh
  • 108 Answers
SOURCE: big old Hydro Therm boiler rolls out flame at
This may be normal it's hard to tell from your description , The flame could possibly rollout for a second or 2...depending on the venting , how far the vent is from the chimney etc....you shouldn't hear a "Mini Explosion" you may hear the gas ignite with a bit of a woooosh...depending on the size of the boiler this could be quite normal...Boilers can be dangerous when they get plugged up or dirty....although Hydrotherm makes an EXCELLENT Cast Iron Boiler...I would still have it checked by an expert to be on the safe side....you should also have a "Slow Opening" valve which would eliminate that problem if the valve is working correctly , but it's possible it was replaced at some point with a regular opening valve and this could be the reason as well
Posted on Nov 01, 2009
SOURCE: Temco DV6400N fireplace will not turn on. Pilot
Do you have a remote that turns the unit on and off
and has different heat settings? Could be the batteries are bad in remote
Posted on Jan 02, 2010
Slant fin boiler galaxy natural gas, pump starts and runs. Igniter comes on . Pilot lights. Burner lights. Runs for seconds. Burn shuts down. Igniter starts pilot light, pilot goes out and on and on
The flame sensor, which is located in front of one of the burner flames is probably oxidized and needs cleaning or replacement. If the unit can't "sense" the flame, it will continue to cycle.
Jan 22, 2017 | Slant Fin Heating & Cooling
Glo warm heater
the regulator IS not only the issue, but it's a major safety benefit,..the pilot flame is non adunstable..get a cheap regulator(like the ones for the outdoor bbq's)
Mar 16, 2008 | Heating & Cooling
Boiler won't fire the pilot is lit.
Flame sensor not picking up flame and won't release /open gas valve
Mar 16, 2016 | Hydrotherm Gas Fired Boiler Hvx-105 Power...
I have a 2006 jag camper 29' and my furnace won't ignite
When you hear the "click" can you observe the pilot assembly to see if any sparking or a hot surface igniter is glowing, it is likely a spark type, if so and you have 24 volts to the gas valve I would suspect a spider or web has obstructed the pilot orifice, this is very common to find after sitting unused, if no spark I would suspect the ignition module, you can try using a flame and aim fireplace lighter to see if the pilot assembly is putting any gas out, but be careful and keep well ventilated as propane is heavier than natural gas and will settle on the floor.
Jan 09, 2015 | Heating & Cooling
Vaillant Gas boiler/furnace not firing up
There is a thermocouple heat detecter in the pilot flame clean it 240 sand paper is ok. replace if not working.
Oct 22, 2014 | Water Heaters
Its a vaillant condensing gas boiler, it is showing problem with ignition, it won't fire up. fault code 28
f:28
air in gas
gas rate low
could be gas valve faulty,ignition transformer,ignition cable.
if there is a spark then its your gas valve,if no spark then check continuity on harness and spark generator,also check earth to appliance
Oct 19, 2009 | KDS Valiant 6380iPTD-01 Notebook
How do I light pilot on Vaillant boiler
turn and push in button on your honeywell gas valve hold it in and spark lighter cont to hold for 20secs then ease finger off button very slowly pilot sould stay alight if not try again in 2mins best of l;uck
Sep 29, 2009 | Water Heaters
Boiler won't fire even though the pilot is lit
Sep 21, 2009 | Heating & Cooling
Pilot Flame will not ignite
Clean the pilot tube of rust or other debris.
Jul 10, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Water heater pilot light
it also sounds as though the pilot injector could be blocked so when the boiler comes on it extinguishes the pilot & then when the burner goes off boiler shuts down, or also the pilot rate maynot be set right, so when the main burner kicks in it robs the pilot of the gas it requires.
It could be that, or there is lack of ventilation for the boiler, so you get flame lift off when the boiler fires?
Dec 14, 2008 | Water Heaters
Heating & Cooling Logo
23 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
