My laptop restarts every couple of hours.
My laptop (Samsung) restarts every couple of hours for some unknown reason. I suspect that the problem is with the operation system, because my antivirus (avast) finds something in the file:
Windows\System32\Drivers\asc3550p.sys
But I do not know how to be sure in it and what to do.
Thanks in advance!
Elis
  • g00ey May 11, 2010
    Try to get e.g. a ubuntu dist, burn it on CD and boot up the computer up from the CD. The key idea is to boot up your computer from a clean system that you know is free from viruses, rootkits et al. I recommend that you use something more elaborate than DOS boot/safe-mode so that your GFX card is properly engaged with high resolutions and all.
    Now leave the computer on for as many hours as you need to get convinced that it will not reboot.
    If it does, then your problem is hardware or BIOS related. If not then there is a problem with your windows installation.
    Problems with the Windows installation could be anything from rootkits, viruses to malfunctioning drivers.
    I know that some windows dists (esp the 64-bit versions) reboot the system if any kind of software tries to tamper with the system kernel. This tampering is not only done by malicious programs but also buy legit software as well, examples of non-malicious software are Sandboxie, Macrovision (DVD/Blu-Ray copy protection), some drivers, ...
    Try to get all software out there being used for rootkit removal/detection. Try popular software such as VundoFix.exe, ComboFix.exe, get WindowsDefender. Download F-Secure's rootkit scanner and scan the computer.
    From then on check all the running processes manually and try to understand what is running, check it regularly so that you learn the system. If something new and suspicious comes up that you cannot relate to eny recent installation/update, check it up, run HiJackThis and go through the logs. You cannot always trust the Antivirus software, some viruses go undetected and some are false positives, you have to use your own judgement. google any suspiciouls runnig process. Remember that rootkits cannot be detectd easily.
    Genius:
  • 1,605 Answers
Asc3550p.sys is a spyware. you need to remove it.
go to the following link and downlaod the "serach and distroy"
http://searchdestroydownload.com/
run it and remove the spyware.
hope that helps.
Posted on Jan 03, 2009
Recently our laptop (4yo) shut down unexpectedly after being used for 45min to 1 hour! I was wondering what the issue is? Is there anything which can be done by us? We are out of warranty.
things that happen to older laptops are that over time there tiny processor power supplies build up with lint from the air that is passed thru them sometimes even making the tiny cooling fans in there stop , then its only a matter of a few minutes and it overheats and shuts off , after several hours cool own it will restart , but wont stay on long , then the cycle repeats . if its caught in time and no power supply parts are ruined sometimes a Pc repair shop can dismantle one and clean it
Dec 03, 2015 | Samsung RV520 Laptop
MODEL SRL551DP turns itself off after about 4 hours
HI, The reason could be:- The exterior draining tube at the back was blocked with slimy gunk above a plug that should have been taken out before delivery to its first owners. The drainage blockage probably caused the blown fuse.
Worth a look!
Good luck
David
Dec 05, 2017 | Samsung Refrigerators
Toshiba Satellite a305-s6916 force closes at windows loading
You have to make sure that the thermal Fan is working correctly. if it doesn't work please contact nearest toshiba service center
Dec 17, 2012 | Computers & Internet
I have a 2001, Panasonic 27
Suspect either bad solder connections somewhere or a issue in the power supply of the set----set will shut down for a number of reasons--it monitors voltages inside and if some go high or low it will shut down.
May 16, 2012 | Televison & Video
Samsung printer unrecognized by PC
you need the driver for it for some reason it must have been uninstalled http://www.samsung.com/us/support/owners/product/CLX-3175FN/XAA#
Feb 26, 2012 | Samsung CLX3175FN AllInOne Laser Printer
Hi there. i have the closest model, to LE-32B450C. Samsung LE-32C450. i guess..its europe model (im from greece). I bought the 32' TV a couple weeks back.. and now im messing with a shut down problem....
I have a few friends in the UK with the very same TV and no problem at all.
I would suspect either a power supply fault or a bad connection somewhere and I would return it for a replacement.
Mar 01, 2011 | Samsung LE-32B450C 32" LCD TV
Unknown device
Update your Unknown device while in you device manager
Update the device then shut down and restart
or
Uninstall the device from device manager ,right click on the device then uninstall,
Shut down and restart,
the device will be automatically found by your Operating System and reinstalled automatically too,
Hope this helps,
Cheers Misterdj
Aug 05, 2009 | Acer Aspire 4520-5582 Notebook
Dell inspiron 1720 reboots randomly
there are several reasons why a pc restarts: 1. there might be a virus that causes this, thry to scan your computer using the updated anti virus. 2. your power supply might be faulty, if your pc frequently restarts the 12volts supply is having a problem, you need to replace the power supply. 3. operating system error, you need to repair your OS. what i have suspected from the problem you relayed is that your power supply, you need to replace this.
Apr 29, 2008 | Computers & Internet
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
