Question about Sony VAIO VGN-FJ270/B Notebook
Key came off
All key clips are different I can see. I have a sony vaio vgn fj-270 that the key AND clip came off. Id like to know how to put the clip back on and the key. Since one came off, they all seem to be coming off at one time or another. Not all go on as easily.
The clip is in 2 parts, identically but on opposite sides of the keys.
none of the sites you sent to help me were helpful at all
Try www.laptoprepair101.com
Posted on Jan 24, 2009
Sony webcam driver
can you post the exact model/serial #. of ur sony vaio
Apr 27, 2014 | Sony Computers & Internet
To Whom This May Concern, I am 99% sure I have a problem with my fan. When my computer is on for extended periods of time or if I have alot of webpages open it starts making this awful noise that almost...
As a solution I suggest that you change the power scheme settings and check the operation. Follow the steps to change the power scheme settings:
1. Click the Start button, and then click Control Panel .
2. In the Control Panel window, under Pick a category , double-click the Performance and Maintenance icon.
3. In the Performance and Maintenance window, under or pick a Control Panel icon , double-click the Power Options icon.
4. In the Power Options Properties window, in the Power schemes box, click the down arrow and then click to select the desired power scheme.
5. Click the OK button.
You may also clean the notebook fan area.
Regularly wipe the exterior of the notebook case with a clean, soft cloth to prevent a build-up of dust that could interfere with air circulation of the cooling system.
Provide adequate air circulation to prevent internal heat buildup.
Leave a space of at least 8 inches behind the back panel of the notebook
Dec 12, 2010 | Sony VAIO VGN-FJ270/B Notebook
Can sony vgn-fj77gp/b support webcam with windows 7?
refer to the follow page
http://www.getpcmemory.com/drivers/download-sony-vaio-vgn-series-notebooks-windows-xp-drivers/
Aug 13, 2010 | Sony Port Replicator for Vaio FJ Series
Function key doesn't work, how to fix it?
Install VAIO Event Services (Notebook Utility) and restart the Computer.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFJ170B&upd_id=2002&os_id=7
Jun 25, 2010 | Sony VAIO VGN-FJ170/B Notebook
Screen Opening
There are clips that are holding it into place. Take a flathead screwdriver and put it in an area where the front bezel meets the back bezel. Twist the screwdriver around and it should loosen some of the clips, do this in a few places and then enough of the front bezel will be loose to where you can remove the front bezel to the screen.
Once you do that you can remove the screws from the left hand side and the right hand side. Then remove the cable from the back of the LCD and remove the plug from the inverter on the bottom of the screen.
You can now put the new screen in.
Apr 27, 2010 | Sony VAIO NS Series VGN-NS110E/S Notebook
The computer shuts off when the screen is adjusted forward.
The LCD Display Cable Is Most Likely Pinched Or Already Past the Pinching Point and Has Broken Solid Connection, causing the Short and shutdown when screen is moved or flexed...
The Hinge Area (Left Side)... Needs To Be Examined... And If No Short/Pinched/Frayed Cable In That Area, You Need To CHeck The Display Cable Where It Connects To The Back Of THe Screen... Reseat THe Ribbon Cable...
Nov 25, 2009 | Sony VAIO VGN-FJ270/B Notebook
Fan went out. how to repair myself
First you need to find out if you can purchase the fan,
http://www.sparepartswarehouse.com/Sony,Vaio-VGN-FJ-FZ-Series,Laptop,Fans.aspx
Now you need the Vaio VGN-FJ Series Service Manual,
http://tim.id.au/laptops/sony/vgn-fj.pdf
(PDF file download. Advise letting it download all the way, before looking through it)
Now post back if you need me to guide you. Looking at the procedures you need to follow can be daunting, if you've never done this before.
(Me? Oh yeah)
Nov 12, 2009 | Sony VAIO VGN-FJ270/B Notebook
Sony vaio vgn-TX750P how to open the case to swap the hard drive
here you go mate i found u this coz i know how much of a pain in the arse sony vaio's are :
http://laptoplogic.com/resources/detail.php?id=43
GOOD LUCK LADS!
Aug 08, 2009 | Computers & Internet
My laptop doesnt detect USB Pen drives (sony vaio VGN-FJ 270)
Go to start->control panel->system->hardware->device manager. Expand Universal Serial Bus controllers. Right click on every USB root hub and select uninstall option. They will be reinstalled on next restart.
After that plug USB pen drive to usb port - go to start->control panel->system->hardware->device manager. Click Universal Serial Bus controllers then click on Action tab (the one at the top of Device manager window and select scan for hardware changes.
If that will not solve the issue try different USB port.
Make sure you have latest service pack installed so Windows would install proper drivers for the device.
Let me know if this is not solved
May 26, 2009 | Sony VAIO VGN-FJ270/B Notebook
Sony VAIO VGN-FJ270/B Notebook Logo
80 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
